2 hours ago, dieselfan1 said:
Your old one was built there too.
Actually the 2018 was built at the Ft. Wayne plant.
Up until yesterday morning when I shredded them I had the papers to prove it.
In the picture the truck looked like a crew cab I thought all crew cabs were built in Mexico My 2018 crew cab was built in Mexico My 2018 double cab fort Wayne.
But if your sticker says it was assembled i in fort Wayne Guess I was wrong
Sent from my Pixel 3 using Tapatalk
17 hours ago, Penguin VII said:
I don't know how you didn't switch brands. I would have left GM had that happened to me.
eh I have had that happen before on a previous truck, intermittent problems are a ****** for sure but mine turned out to be a bad starter, replaced the starter and never happened again.
hmm, mine was built in good o'l Flint
77,000 miles. No catch can. I’ll be addressing this after I finish my trans overhaul. Might just pull the engine and replace it if I can find a lift out for the right price.
Is your truck v6?
2,800 mile round trip to ColoRADO. Truck never skipped a beat, other than the small doe that tried to ruin our trip about 8 hours into the drive somewhere in Nebraska. Very impressed with how it did, but man I wish I went with the 6.2!
  • Like 5
Pic of said damage, luckily it wasn't significant enough to stop us from some amazing riding in the mountains.
Y’all tired of people on cellphones in traffic, rubberneckers, lost Uber drivers.. I have the solution within this very video.. turn your volume up and enjoy..
Getting ready for a road trip.  Added new D-
Rings to the bed of my truck and to the tailgate.  The ones in the bed are bolted down and can take a lot of weight.  The ones on the tailgate are mainly for the cargo net.
I added mudflaps and a new cabin air filter.  I used Rust-Oleum bedliner to paint my toolbox and painted surface of the tailgate that did not have the spray liner.  All of the D-Rings and other hardware are stainless steel, but I sprayed them down with the bedliner too.  Like the gritty flat surface.  The tool box was bare aluminum... It always stood out and now it matching.
My wife has approved my suspension upgrade... Now just trying to see what to go with.  Got a quoted for $1800 to put fox 2.0 on front and back.  I am looking at more.  I don't care for looks... I need something that will make driving to my hunting spots more comfortable.  It's in the mountains.
Edited by jaimeastin
On 6/13/2020 at 8:18 AM, cbrsilv15 said:
Finally got to hand wash, clay and paint sealant. I’m pretty sure it’s the first hand wash since last fall. ??. It’s bad, considering I’m a detailer on the side. I never have time to work on my own stuff.
Man... Now that is a shine! Fine work Sir!
Guess that good ol gm battery has had it. First replacement part other thank oil and filters 76k 2017 time for new one
    • I hope to high heaven this is wrong. My Chevy farm trucks frame is lasting way longer than a newer Nissan Titan XD I got for a steal, and it only pulls trailers. A decade younger and it's frame is already way rustier than the waxed Chevy I drive across longs and ditches. Also, hasn't Ford been having tones of troubles with rusted frames?
    • Batteries don’t always show signs of a few years ago my vehicle started fine in the morning and took me to work. After work the battery was completely dead and I needed a jump. No, I didn’t leave anything on and the battery was only a couple months old. It was replaced under warranty.
    • AFM is confirmed in the Corvette engine, so I'm assuming the higher volume trucks will get it as well
    • If his battery was that bad I would think it would have been showing signs before this that were ignored. Stinks that it happened the way it did in rush hour traffic, but this seems like a pretty fringe scenario. I don't mind it that bad and never turn it off. The only slight annoyance for me is the slight delay between brake to gas, but I have gotten used to it and figure if it can save a little gas why not.
    • That is a good correction. I think “severity” was probably the wrong word for what I meant. What I really mean is closer to event priority, relevance, and actionability — not “this code is severe” or “replace this part.” I agree that a truck can have a lot of trivial or historical communication codes, and if the product starts pushing alerts for every stored or low-value event, people will ignore it very quickly. So the alert logic would need to be filtered. For example, I would not want a random old communication code to generate a push notification by itself. A useful alert would probably need to be based on things like: - new vs historical - active vs stored - repeated vs one-time - duration of the event - whether it happened near the driver-marked symptom - whether it happened together with voltage drop, reset, bus-off, misfire, oil-pressure change, etc. - whether the same pattern repeats under similar conditions So instead of saying “severity,” maybe the product should organize events by affected system and priority. For example: Misfire event: Show misfire counts / roughness first, then fuel trims, RPM/load, DFM/AFM state if available, coolant/oil temp, voltage, and related DTCs. Oil-pressure event: Show oil pressure first, but only in context — RPM, load, oil temperature, coolant temperature, DFM/AFM state if available, voltage, and baseline comparison. Communication event: Show which module/network/message dropped, whether voltage dropped, whether the recorder reset, whether it was active or historical, and whether it repeated. Voltage/reset event: Show battery voltage, crank/wake/sleep state, module reset, communication dropouts, and what came back online first. That also solves the display-order problem you mentioned. The main report should not always show the same fixed list first. It should show the system that appears abnormal first, and then the supporting values for that system. I also agree that the truck already has an oil pressure gauge and MIL. The point would not be to duplicate those. The value would be in showing what else was happening before and after the warning or symptom. For example, if the MIL comes on for a misfire, the truck already told the driver there is a problem. The useful part would be: - which cylinder or bank looked abnormal first - whether it happened after an AFM/DFM transition - whether fuel trims were already moving - whether oil pressure or voltage changed at the same time - whether the same pattern happened previously without a MIL On the OBD port point, I think you may be right for a consumer-facing version. OBD is much easier for the average owner: - easier install - easier removal - inside the cabin - easier phone connection - easier data download - easier to include a pass-through port for another scanner OBD is also the right place for DTCs, freeze frame, VIN, calibration information, Mode 6, and normal scan-tool parameters. The reason I was looking at ECM-side recording is that some events may be gone by the time someone plugs in a scanner, and some powertrain-side network evidence may not be available the same way through the DLC. But I agree that if an OBD-based version can capture enough useful evidence for most owners, that is probably the cleaner consumer product. Maybe the split is: - OBD/DLC version for most consumers - ECM-side version only if it proves it adds evidence that the OBD version cannot get - shop/pro version if deeper powertrain-side event evidence is actually useful So I would not want to force the inline approach if the OBD workflow solves most of the real-world problem. Your last point is probably the key product requirement: the report should be specific to the system showing the abnormality. Not “here are 50 parameters.” More like: “Misfire-related event detected. Here are the misfire/fuel/DFM/context values.” or “Oil-pressure-related event detected. Here is oil pressure compared with RPM/load/temp/baseline.” or “Communication event detected. Here is what dropped, when, and whether voltage/reset happened first.” That is a much better way to think about the report.
