2.25 Ready Lift
275/60/20 Falken Wildpeaks
RRW RR5-V 20 x 9 - 0 offset
No Rub
So long story short the retailer called me back and said the Dirty Life rims were on backorder, so they upgraded me(more Expensive) to the Fuel Vector in Bronze for no extra charge, not the best pics but got them on my truck tonight and so far i really like the look, need to get better pics with some more light haha
17 x 8.5
+7mm offset
265 70R17
No rub with mudflaps installed
From this
To this, so much better...
And all three sets of wheels, the XD Hoss have my factory SRA's for summer use
Edited by creimes
2018 Quicksilver Sierra 6.2 with max trailer package
20x9 moto metal MO970
part# MO97029067318
+18 offset
Nitto Ridge Grappler
LT305/55 R20
2.5" front leveling kit from KSP (top mount - ended up being closer to 3")
1" rear lift (Readylift 2" blocks)
Slight rub on drivers side sway bar at full turn left.  Nothing at full right turn.  Had to zip tie fender well carpet in a little too.
Edited by chadande
20x12 -51 vision rockers on 33x12.50 Federal Couragia Mt
3 inch Motofab Leveling Kit stock blocks in the rear
It rubs so bad but did a NorCal mod on one side and I ran out of daylight gotta do the other side tomorrow ?‍♂️ but after the NorCal it doesn’t rub at all
600384bd00c129da1a90bb86f4fc0c0f.jpge948d812ef17e4db481d69392ecdfb23.jpg14e27716156b48a15bf48e3d8c128750.jpg
8 hours ago, pillman said:
Very nice! What wheel and tire size here? 4/6 drop?
Thank you and yes 4-6. Wheels are MRR T228’s in 22x10, the only size they come in for our trucks. I don’t remember if it had 305/40’s all the way around here (which will rub in the front) or if it has the 305/40 rear and 285/45 front, which is whts on it now. As soon as they show up I am going to 17x10 and 17x7 Welds and drag radials.
Sent you a PM! Thanks
Before:
OEM 20x9, 275/55 r20s
After:
Fuel Tactics 18x9, 1mm offset. Michelin A/T 2s, 275/70 r18. 2” level, slight rub before zip ties.
Longtime lurker, first time poster. Thanks to everyone for all the wheel, tire, lift posts and pictures!!
Edited by txrangersfan
Newbie ;-)
4 hours ago, txrangersfan said:
Before pic:
Looks much better ?
BTW, I meant the "after" is better.......lol
Edited by Shakeydeal
    • Hello All!   My 2019 Colorado 3.6 LT, 4WD Crew Cab has approximately 77,500 miles and I recently began experiencing the well-known transmission shudder between about 30 and 65 mph. The problem had worsened to the point that I could no longer attribute it to road conditions - and I had decided to bring the truck to the dealer - when recently, I experienced a sudden loss of power while driving at maybe 40 MPH. Several warning lights flashed, the “Check Stabilitrack” message appeared, and the Check Engine, Stabilitrack, and Traction Control icons remained illuminated. The truck regained driving power, but it stayed in a low gear with unusually high RPMs for the speed. (limp mode?) Because I was only about two miles from home, driving slowly, I was able to make it back and run an OBD-II scan, which showed fault codes U0101, P0700, and U0100. My next trip in the truck was to drive it to the dealer the following day. That trip began normally, but after about a mile I experienced another loss of power, along with the same warning lights and the same “Check Stabilitrack” message. As before the truck remained driveable, but again operated at an abnormally high RPM-to-speed ratio and seemed stuck in a single gear. About a mile later, the dashboard lit up once more, this time displaying “Check 4WD.” Soon after that, I arrived at the dealer. I have verified that the truck still has its original factory transmission fluid, which means it has never received the corrective fluid exchange outlined in GM Technical Service Bulletin #18-NA-355.  That was Thursday of last week and I've heard nothing yet from the dealer.    According to Technical Service Bulletin #18-NA-355 and the build date of my truck, my truck should have the newer LV fluid. I've done a little research and read something about a problem with the wiring harness as well.   Anyone have an insights into this situation?  Thank you!!
    • Having bumper and other body damages can be very frustrating, especially as a result of a parking lot collision/bump. Our team wants to learn more about the damages to your truck so we can look into ways we might be able to help. When you get the chance, please fill out our support form with more details: https://s.gmc.com/support-request . A member of our team will follow up with you as soon as next available. We want to get you enjoying your truck to the fullest again.
    • Did you even read this article?   Even the title of the article says "U.S.-Iran Deal Doesn’t Mean a Swift Return of Oil and Gas Flows"   Remember, crude oil prices are based on FUTURE purchases by the oil companies.  Gas prices are based on FUTURE purchases by the station.  This article stated that many of the oil producing nations have to restart their processes to get the oil produced.  Then the oil has to be shipped to wherever.  And it doesn't get there overnight.  And most of that oil is not coming here. Check out this site:  https://afdc.energy.gov/data/10621   A graph will pop up to show where the US imports their oil from.  Notice that there isn't a lot of import from OPEC and Iraq.  Most of the US import comes from Canada. The US oil produces are selling their oil on the open market, which is why the US fuel costs went up.  So you're correct, the US oil companies are going to slow walk the price downward.
    • Having codes and an engine light with no hints on what might be causing it is nothing short of frustrating. How long have these concerns been present? We want to know more so we can look into ways we might be able to help you. When you get the chance, please fill out our support form with additional details on your experience so far. A member of our team will follow up with you as soon as next available: https://s.gmc.com/support-request
    • Knowing the life of your brakes is a highly important status to keep track of. If you suspect your brake sensors need attention, please fill out our support form with additional details on your experience. When did you last take it in for inspection? Our team will follow up with next steps as soon as next available. Please include your username and GM Trucks Forum in the form as well. Support Form: https://s.chevy.com/support-request
