Mozzer Posted March 12, 2019 Posted March 12, 2019 May do, but would need to know for sure that the shock cannot bottom out inside as that would be lethal. Sent from my Moto Z2 Play using Tapatalk
goeb34 Posted March 12, 2019 Posted March 12, 2019 Mine is at 2nd stop, but yes that would make sense.My guess is stock shock is most likely worse as it has softer damping so compressing bump stop more when hitting a bump in the road.Sent from my Moto Z2 Play using TapatalkWhat’s your wheel/tire set up
Mozzer Posted March 12, 2019 Posted March 12, 2019 What’s your wheel/tire set up Mine is standard 18" rims & tyres at the moment. Sent from my Moto Z2 Play using Tapatalk
Mozzer Posted March 13, 2019 Posted March 13, 2019 Ok, confirmed it sits on the bump stop.There is 1 3/8" shock travel left with one wheel jacked up, that all goes away with the weight on.Sent from my Moto Z2 Play using Tapatalk
MBSierra17 Posted March 13, 2019 Posted March 13, 2019 4 hours ago, Mozzer said: Ok, confirmed it sits on the bump stop. There is 1 3/8" shock travel left with one wheel jacked up, that all goes away with the weight on. Sent from my Moto Z2 Play using Tapatalk Which would imply what, unless you're at the top setting, you're on the bump stop?
Mozzer Posted March 13, 2019 Posted March 13, 2019 I'm on the second setting, need someone to chime on who is set on 3rd or 4th.I was able to feel the bump stop by poking my finger up under the dust boot. Oo, er Missus [emoji16]Sent from my Moto Z2 Play using Tapatalk
Yondu Posted March 13, 2019 Posted March 13, 2019 I'm on the third setting and it sits on the bump stop.
Mozzer Posted March 13, 2019 Posted March 13, 2019 Wow, so it's more like a spring helper than a bump stop. It must have an effect on how well the shock an function.Sent from my Moto Z2 Play using Tapatalk
Criscone Posted March 14, 2019 Posted March 14, 2019 Trim the bumpstop in half. Sent from my iPhone using Tapatalk
Snowcamo Posted March 14, 2019 Posted March 14, 2019 Trim the bumpstop in half. Sent from my iPhone using Tapatalk·Have you done this·How did it change the ride·Any bottoming out?
FlipZ71 Posted March 14, 2019 Posted March 14, 2019 The bump stop on these are fairly soft. I had found the same issue and decided the set up just didnt have enough travel for me . So I fixed it . The bump stop is to help slowdown the shock on hard its. Cutting it down wont help the ride , it will just increase the chances of damaging the shock on hard hits. 1
Yondu Posted March 14, 2019 Posted March 14, 2019 The bump stops are adding a certain amount of progressive spring pressure. As far as how much, it depends on how compressed they are. There is a approx 1" difference between the top and bottom setting on the Bilsteins, so on the bottom setting it's safe to say they are compressed a bit. I don't know anyone who has had them on then took them off to comment on the ride quality change so it's impossible to say. But they can't be so soft they don't affect the ride yet actually protect anything. 1
FlipZ71 Posted March 14, 2019 Posted March 14, 2019 34 minutes ago, Snowcamo said: What was your fix? Thanks 1
Mozzer Posted March 14, 2019 Posted March 14, 2019 Now that's a fix [emoji1786]Sent from my Moto Z2 Play using Tapatalk
