Can’t remember from when I installed the 5100 but I want to lower the front shock to the bottom ring for stock ride height so I need to take the spring off for that? Wanting to do that tomorow but need to know if I gotta get a spring compressor first
Yes you need spring compressor.
I have a :
2017 GMC Sierra 1500 Crew Cab RWD
I’d really like to run a 35 but I am not a big fan of 4+ inch lifts. Unless there is some sort of coilover UCA combo I am missing. So I guess I’ll have to settle for something in the 33 range, ideally 305/70/17...Have people gotten away with that tire set up with the 6112 shocks?
On 4/25/2019 at 3:30 PM, Sierra Dan said:
4600 and 5100 are built identically on the internal side other than a longer shaft for the 2" of lift.
Not looking to start something here but as of today (maybe different in the past) this is false information. I've called Bilstein twice now and spoken with two different dudes who have confirmed that the valving is indeed different.
They keep their valving specs on lock down but they confirmed it's different and that the 4600s have softer valving, by how much? No clue!
...SOOO for someone who isn't looking to increase height on the front (which is clearly the minority) 4600 is probably the way to go!
Ok starting to go cross-eyed, I have a '14 GMC 1500 Z71, having Bilstein 5100's put on Thursday, planning to go with the highest setting, what's the biggest tire size I can go without rubbing, or with minor trimming on the factory 18's? Kind of eyeing 285/65/18's or 275/70/18's in BFG AT2 or Goodyear Duratracs
I have LT275/70/18s, no lift Ko2s and no rub. 2014 silverado CC 4wd. So you should be able to do at least that.
I think I want to go somewhere between stock rake and level. Anyone got pics using the 2nd notch? Thanks.
Thanks, went with the 5100's at the highest notch, and the 275/70/18 BFG KO's, only rubbing is one right turn at full lock, I just need to tie back the inner fender liner and it looks to be no rub after that, very happy with the ride and looks, a little stiffer than stock but I always felt the stock ride was too soft anyway, should have done this from the get go, with a tape measure it's 1" higher in the rear after the install
Edited by Ryan A
I went with the 2nd notch.  I think looks good and I wanted some rake.  The truck ride better than the rancho factory shocks E1850EC0-6284-404B-89A8-2385D19E3CA2.jpeg.d12faf0cd2bd6ec6127f9111cf74922b.jpegks
Thanks! Looks great!
Hey everyone, I need some help figuring out what to do with my truck:
2017 Z71 CC 90,000km
Installed Airlift 5000 at rear last year
Front end now looks stupid low, and front suspension feels dead. Rear suspension feels just fine now with the air bags.
It seems like the 5100 will be the best bang for my buck. Should I install a full kit on all 4 corners, with new coils up front? Can I just get away with installing the 5100 up front?
Anyone know of a good deal for a set of 5100’s right now? Looking to buy in the next week. Thanks.
It won’t be quite within the week but probably in about a month. I’ll be taking mine off and putting 6112s on. They have about 20k miles on them so I’ll do $120 for the pair
Added Bilstein 6112s on the highest notch today. Rear has 5100s and 2.25” blocks (1” of lift). It turned out exactly like I wanted it to be.
affb9d5190a9c38ff9cfc01ece3c909a.plist
    • I find it amusing the OP doesn’t realize this threads heading includes several engines. He should have posted in the off topic section if he wanted a more narrow focus. I really appreciate and find amusing that he actually pointed out one of my many vehicles. The Odyssey. That happens to use 0-20 oil. I love pushing his buttons.
    • Maybe, but it seems he is the only one that has backed up data to prove what he is stating. I think he is doing this more because he enjoys it and wants to get the information out to us. He's got the knowledge and access to the proper equipment and having the funds doesn't hurt.  I would love to do what he is doing and would do it if and when I hit the Powerball.  I'm not a Tribologist by any means but love to learn what I can.   I would bet there would be doubting people out there if a completely independent lab with high quality work and highly respected in the automotive industry, put out information like this.  The world can't be pleased, one just has to take the information that they are given, do more of their own research to find actual lab data to back up what they are trying to figure/find out.  Most don't bother, they just want to believe what they first see.     I don't have the minimax but my 6.2 in my 2019 Silverado with 64k miles shows excellent UOA results with 0w-20 and for my own purposes 5w-20.  Since not much of a change using 5w. I liked the data sheet information on the SS 5w-20 and figured I would give it a try.  Still the same viscosity at 100℃.   In the end we all just do what makes us happy, life is too short to get upset over trivial social media.   On a side note, I do feel GM has dropped the ball and just cares about the bottom dollar and not quality anymore.  "Like a Rock" has been long gone.  Seems "Built Ford Tough" has as well.
    • Better than stock but that's like putting lipstick on a pig
    • Hello, my 3 month old Sierra Elevation wont recognize a trailer with electric brakes? All the lights work correctly, but no power to the brakes?   This is the factory installed brake controller. If you manually push the knob, the display shows the power % but does not light up like my 2022 silverado.   I have an appointment with the dealer, but was checking to see if anyone else has seen this issue.    Thanks,
    • Been using SS 0w-20 from new, but wanted to change to the 5w-20 because I liked the data on the data sheet, to me it seems like a little better product. But as you can see, not much difference. This is also with running a mix of 10 gallons E85 to a tank topped with 93. It isn't a flex fuel vehicle so any higher I get a CEL for running lean on both banks. Yes my mileage takes a hit. Instead of 20 mpg I normally get on trips I get 17mpg. This is also using EaO17 filter.  What is amazing is I have the AMSOIL cone filter on it since I have the GM Performance intake installed and that air filter has 44k miles on it.  I just take it out and shop vac it off once a year.  I use the upholstery tool on my shop vac.  Works well.
