Looking for Help...Plasti Dip All Terrain Bumpers
SierraBrad
Just looking for some help with this...looking at PlastiDip'n my front bumper on my 2015 All Terrain to protect the painted bumper for the winter from stone chips off sanded roads. I am wondering how hard it comes off after an entire winter? Will it be enough to protect it? Also looking at doing my OEM oval chrome side steps to protect them. Looking for any advice or experience you have had with PlastiDip. My climate for winter is cold, living in NB, Canada!!! Thanks.
Wouldn't say we have anything near a hard winter here in KY, but my plasti clear coat has lasted for ~17 mos or so without any issues. It's due a redo, but still holding well actually. And it has DEFINITELY cut down on chips. Big time. Not clear bra performance, but far from clear bra price as well.
Be sure to apply a decent amount. Say 4-6 coats, and you'll be able to pull it off with ease. If you do have trouble, just remove the bumper and remove the plastics and you can use the dip removal stuff from dipyourcar.com. Stuff works like a miracle! But they say not to get it on black plastics, only reason why I suggest removing the bumper so you can remove any plastics from getting hurt
Good advice. I did same to mine, came right off after a year+ and a winter. But does do weird things to rough black plastic. It eventually clears up, but it took months for me.
  • 3 weeks later...
Did you ever do this. I was thinking of doing this to my front bumper over the chrome to protect it. I might but the clear bra for it and then dip over it for extra protection.
My main concern is what it will do to the sensors.
Also how many cans did it take and does the clear dip yellow?
Going on 2 years, no problems. Didn't yellow, 2 cans plus one glossifier. Has held up rather amazingly.
The more you apply the better. For a front bumper on our trucks I'd say use 4 cans at minimum. 6 would be ideal in my opinion. Dont forget to prep the bumper by washing it and wiping it down with alcohol or xylene. If you apply the dip thick enough it offers great protection. I dipped my whole truck matte clear (using the dyc sprayer not cans) and will be doing it again after winter. I did redip my bumpers and grill white to match my truck after I peeled it a few weeks ago.
Honestly cans arent ideal for big areas because it the end result is usually streaky and uneven. For chrome make sure to apply 2 light tack coats, then 2/3 medium coats, and finally 1-2 heavy coats. Heavy enough to where the dip almost runs from too much product but not quite. This will result in a smooth finish.
Also the dip will stay fine for a long time. DYC recommend spraying a fresh coat after two years and peeling after 3 years max. If you do happen to spray the dip too thin, once it comes time to peel it buy some Goo Gone. Spray on the Goo Gone and let is soak for 5-10 minutes and use a pressure washer to spray off the dip. The Goo Gone reliquefies the dip to make it come off easier.
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
