I don't leave them on year around but very easily could and probably would, except I usually use the trailer hitch a lot more during the summer. If this one ever needs replacing, I will get the model that you can use while towing and just leave it on year around. They will see almost like it's day time back there with these.
Thank you sir I will pick them one up then, I would say they will not use it much in the summer with the longer days, but it sounds perfect for them for Fall and Winter.
Good deal - they will love it. And in case they want to remove it for any reason, it literally only takes like 30 seconds to remove or put on. Just unplug and pull the hitch pin and remove - that's all there is to it.
Edited by NoProblem
Okay they came in and got them installed.
Drilling into the plastic was very easy. I chose to follow what was done earlier and use the same mounting location. The set I got from Amazon didn't come with a mount template so I guessed.
I'll take a picture of what I used to drill with later. The instructions did have what should be used. I didn't loosen anything or unbolt anything for the drilling.. just went for it. I have small hands so I was able to thread both bolts just fine. I used needle nose pliers to hold the nut while I drilled down the screws. Took me roughly 1 hour including the wiring. I am an electrician by trade so it was easy. I wired into the actual reverse wires going to the reverse bulbs.
Over all I am very happy with the look and the performance at dusk... very nice.
Few pictures... Enjoy!
IMG_20161215_161222344_HDR_zpsokyas2kz.j
Edited by Arth
  • Like 3
looks good. what size hole did you drill ??
I used a 1 and 3/4 quarter sized drill... thing. It was in my drill kit. Like I said I will get a picture of it later.
Edited by Arth
Looks Awesome...Do the tow mirrors provide a good amount of light?
Planning to take some pictures tonight.
Here are some pictures...
Reference picture. My tail lights were on the whole time and it wasn't completely dark.
Back up lights only.
Tow Mirror Cargo Lights only.
Tow Mirror Cargo lights and reverse.
Lot of light back there now.
What did you use to drill out the holes with, a spade bit??
Can the hole be round or does it need to be cut out square? ( I don't know what the back of the light looks like, to pass through the hole)
Did you pull out the taillights to wire into the reverse lights, or did you tap into the trailer harness? What did you use to make the connection, are those t-tap things ok to use?
Thanks
Thanks
^^^ that last post didn't work right, sorry
Supposed to be a question for Arth, hopefully he'll see it
Edited by 15_silverado
Sorry for the delay here is what I used to drill with. For power I tapped into each light individually.
Hey Arth, nice job! The lights look great. I was thinking of doing the same mod. Would you be able to post photos of the view from the rear camera? I am looking to see how clearly things are lit up for the camera.
Thanks.
Thanks OP. I just did the mod myself with a couple changes.
Decided to tap into the trailer wiring instead of each tail light. Grounded to the bolt conveniently located next to the hitch harness. Resulting in only one factory wire tapped into via 3m t tap.
Also trimmed the tab off the back side of the light since it was a little closer to the bed side then I liked.
Super bright for their size. I left the wires secured behind the plate so I can disconnect for state safety inspections.
Sent from my SM-G930V using Tapatalk
  • Like 4
Thank you for the nice comments everyone...much appreciated. I'll do my best to give you how I did it-
The lights I used are these- http://www.rigidindu...-lighting/20641
However, I just found them on Amazon for like 92.50..
The Rigids come with a round template and I used a Harbor Freight Step Drill. I think you can by the whole set on sale for like 8.99 for three of these gold plated step drills. Then just locate the center, mark, drill out and they slide in. The lights are square/rectangular shape on the back side. I've included another pic from the underneath for reference.
Also, I did not remove the plastic steps. I did loosen the screws that hold them in and warmed the plastic a little. I pulled the top down when it came time to put screws in the top of the flush mounts to put the nut on the back.(I'd just use long needle nose pliers to put the nut and washer on if I were to do it a again) Then I put the step back in and used long needle nose pliers to hold the nut on top and bottom while I tighten them down. Spliced, soldered, heat shrink, put back in OEM factory sheathing and reinstalled both rear taillights.
Then, second issue came up for me, factory back up lights were a dull yellow compared to the Rigids, so I ordered some new LED's for back ups in the OEM sockets which now are as white as the Rigid's.
While I was at it, I changed my license plate bulbs to LED bulbs as well.
I have about 5 hrs of labor and wiring.
Mark
Wish I could find them for $92 got a link lol
Sent from my XT1585 using Tapatalk
Looks like the price jumped on amazon. I paid $92 a few days ago, now $123
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
