2018 Console in my 2014 is installed and everything is working like it should thanks to phil’s Harness!
Very nice!!
Do the Green, black, grey and brown cables all have the same style connectors on the end?
Cables are all the same color. The USB ends are different and are keyed to connect to specific ports.
Your HMI has (2) Ports you can use for USB Data. Green and Black ports. If you have a Glove Box single - USB, the green port is used for that.
If your center console has a Double USB, you can loop in and out of this hub to feed the inside compartment hub. This will allow you to retain the glove box USB if you have it.
So - Black to Grey. This will plug into the black port of the HMI (disconnect the existing cable that’s plugged in). Grey end plugs into the front hub. Then get a black to Brown. Black plugs into the output of the front hub and brown to the console brown plug.
There are some reports of some that say their hub is not looping the data signal out... in this case, you may have to omit the glove box USB and use the green port from the HMI for that.
so cable 19119050 would be black to grey? which goes from HMI to the 2 port usb in?
19303285 would be the black to brown?  Which goes from 2 port usb out to brown plug?
Yup
Also, one of those cable part #s has been replaced with an updated part #. Just FYI.
I think I got that covered, it looks like 19303285 was replaced by 84022323?
Yup.
I appreciate everyone’s patience. Working hard at getting these out tomorrow!
I would really like to know where people are finding the Center Console unit itself! I want to swap out my 2016 Chevrolet Silverado Jump Seat for the Center Console but haven't been able to find one anywhere.
Thanks!
    • I have finally paid off my mortgage and can now purchase a new truck. I would greatly appreciate any opinions on the purchase of a new 2026 GMC Denali 5.3L or 6.2L with the Denali reserve package. I am not interested in the 3.0L.  Or should I go buy a Ford?   Thank, John
    • One of the few things I enjoyed about my time in the midwest was taking off on weekend drives. Unlike home, where we are boxed in by mountains and water, those rules don't apply to the inland plains. Roads connect and sprawl everywhere. While Minnesota is flat, it's not completely featureless and there are fast moving rural roads with curves and slight elevation changes. I used to relish heading out in a particular direction with no set destination, no curfew, and weaving through little townships, wherever the roads would take me. Along farms, lakes, or through the deciduous trees... It was beautiful in its own way, and the seasons were so distinct there. Fall drives yielded amazing shows of color and contrast. Summer drives rewarded with the and amber evening glow of the prairie (and lots of juicy bugs).    I do a lot of that here in my home state too. But it's much less mysterious/intriguing. I've traveled most roads in the region, and every road that's fun to drive within a good radius of my house. But every drive, even on the same old roads, is still enjoyable. I know where I can lean hard into the throttle or really throw the car into a curve. There are exercise loops for when I just need to keep certain cars limber, and much longer routes to settle in and enjoy a drive and put some miles on. All the mountains and water make for some really awesome roads for spirited driving. But not all my driving is spirited, for example, that's not really enjoyable in my pickup or this Blazer (that's still here...).   Sometimes a good drive is followed by a ritualistic wash before tucking the car away...
    • 'GMAuthority' is reporting the 2027 HD's will have the L8S 6.6L gasoline V-8.  There was some talk here about the L8S awhile back.  Not sure what changes it will have now as it seems the 2027 emissions regulations have changed from what was originally proposed.  The big question will be is L8S just a stopgap for the last 2 years of the current T1 HD platform or will it carry forward to the next generation 2029 T1-2 HD's?    I assume the L8S will still be a Gen. V engine.
    • New engines will still be using DEF. You just won't have the limp modes occurring when you run out of DEF now.
    • I am not a NOCO fan for a charger I would leave on a battery 24/7. The reason is, it doesn't really float. It waits until the battery drops to a certain voltage and then charges it back up to 14V. It's better than no charger I guess.
