Hey Phil, I’m new to this site. I just bought a console for my 15 Silverado and I guess I need to buy your pnp harness. I need help with what ordering one. Any help is much appreciated. Thanks Paul
Hey Paul. Welcome! I’ll send you a PM (Private Message) to get more info.
How long is your wait list right now?
There is no waitlist for this. Just standard 2-3 day lead time.
I have a 2018 Silverado crew cab with black interior with the silver trim
does anyone have a correct confirmed parts list for a complete swap. Being a 2018 gmparts doesn’t give me many options and keeps saying “oops that part was not found”
I just want to confirm before ordering the console assembly does infact come with the wireless charging lid, and that it’s the new 2018 mode that supports all phones.
Also need to confirm the upper trim panel trim panel has silver trim.
All the side panels I can fine come back cocoa.
Sorry guys I know this has been asked a lot but not having much luck searching the previously posted lists.
Edited by Jrhoads88
The console part numbers you need are:
84288042
23467516
22817347
84092079
84288042
23467516
22817347
84092079
Thanks man! Can you confirm this console comes with the wireless charging lid?
Yes that is off of a 2018 with wireless charging.
84288042
23467516
22817347
84092079
What is the difference in consoles between 84288042 and 84288040? This list for black interior/silver stitching has 84288040 for the console:
Both just say "Console - GM" on GMPartsNow but 84288042 is $28 more.
84288042 has code GAJ which is considered a premium package console.
Any idea what the differences are?
84288042 is a jet black/medium ash gray
84288040 is a jet black/dark ash
Thanks
I can also price match gmpartsnow if anyone is interested
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
