13 hours ago, mack14 said:
The console was complete with the armrest.
As stated earlier I had to order the side panels, front console trim and the mounting bracket.
I went to my local dealer where I purchased my vehicle and sat down with the parts manager and went through many part numbers to come up with the ones that we ordered. some of the part numbers were superseded a couple of times.
Thanks
If anyone does this mod and removes a gray jump seat with the lower storage compartment, please contact me if you'd like to sell it. I have the WT interior and would like to have that lower storage compartment that the LT trucks have.
Found this thread through a google search and decided to sign up.  Wanting to go to a full console as well.  I just bought a 2015 2500 Crew a few days ago.  Was wanting to know are these console interchangeable from a 1500 to a 2500 or vice versa.  Same mounting brackets, etc, etc?  They appear to be the same just wondering.  My brother inlaw has a 2018 1500 with my exact colors that i need so i was just gonna use his Vin# and order his.  Anybody ran across this?  Looking forward to being a member here.  Tons of useful info here, see lots of stuff i wanna do already.  Thanks for having me....
Welcome! Glad you found us! Physical fitment is the same between 1500, 2500, 3500. There will be will differences in the electronic hardware such as USB Hubs, Wireless Charging Lids, and features such as Car Play (Apple) and Android Auto. Also, I’ve seen some 2500/3500 trucks with (2) - 12V Plugs and a USB Hub - missing the 110VAC. So while there are some differences in these options, physical fitment is the same.
If you are buying all new, I would recommended getting 2018 stuff, so that you’re not spending more $ swapping parts out later.
I’ve got a video on the swap here. But be sure to read the very first of this thread as I show differences in the jump seat connector for some 2014-2015 trucks.
Thanks for the reply Mr. Gamboa.  I have watched your video several times. thats how i found this site as well.  Thats a very good video you did, even dummies like me can do this swap out.  I saw your parts list and I think your colors and trim is what i have on mine.  My window sticker says Jet Black Interior and i have the silver trim throughout.  Unless there are different shades of black?  Do you have some kind of contact info? I'm not a Facebooker or any other social media type fella, kinda still in the stone age i suppose.  I guess i would need to wait to see what console i end up with for you to see what i need is that correct?  Anything else you might need.  The console i was gonna order is from a 2018 1500 LT using his vin or maybe your parts list.
I’ll send you a PM (Private Message). Check your inbox and see if you see it.
I think I replied to it. Lol,  still trying to learn to navigate this site.
Please help! Can someone email me the address or instructions on how i can order the harness? I can't find an order site any place. Thanks! in advance
Ordering is done via PM. Send me a PM and will validate your truck and will send you ordering instructions.
I am new to this site how do I send a (PM), Am I overlooking the address (PM)
Just sent you one :). Look in the upper right corner for an icon/envelope looking thing?
I’d like to correct some info on fitment. I had the opportunity to help a local member who has a 2500, Signal Cab, Long Bed Truck. The fitment was ok. We were able to get the console bolted in... BUT, there is a gap up at the front.
My harness build still worked fine, but you can see a small gap up front. I am unsure if there is a center console that is specific to 2500s that might just slightly longer. We also check if there was any play in the 15mm bolts... not enough to close the gap.
Here are some pics
Might be more to do with the fact that it's a regular cab, center seat mounts might be slightly further back. Does GM offer a regular cab with a center console?
Good info.  The Vin I am using to order mine is from a 2018 1500 Crew.  Anybody have any info or experiences with using a 1500 crew console for a 2500 crew?  Haven't ordered just yet.  Wondering if his issues is the regular cab?  Sounds about right.  Anyone?
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
