FHLH's 2016 Silverado CC LTZ Z71
FHLH
there is a 30 second install video at BullRingsUSA.com that shows exactly what is involved. It's pretty straight forward
  • Replies 57
Welp. Added some wheels and tires
Falken 285/75r18 Wildpeak A/T3 wrapped around Pro-Comp Series 5034 "rockwell" 18x9 0 offset wheels.
69f82206b67fd68c8bc911e2d3665869.jpgf2e0ae2161a8b736f1fe14de50a4cc39.jpg514334a5aee1b5f1d5f9bbb50c06bfaa.jpgeda1654768372b418b6e8e5bbbf4f89f.jpg
It was dusk when I took these so they are not the best. I’ll get some sunny shots. I’m really not a fan of black wheels.. but I really like the simplicity of the Procomp 34’s
Took a few more pics of the 285/65r18 Falken Wildpeak wrapped around Pro-Comp 5034 “Rockells”
b3e3b744b9a5d72dbd6b4214605f497b.jpg766a33239e8506bfd95300188dfd6921.jpge5b6624a7fd7867544211f1d505a3dec.jpg341aeb6fc4f58b36f6c079aa33bdee51.jpg
Any rubbing with just the 5100's for lift in the front? I'm debating lowering mine back down by getting rid of my RC spacer I have on the top in addition to the 5100's. Currently have 285/70/R17 which is 32.76 supposedly.
With the +0 offset and 285/65r18 Wildpeaks, I have not seen or heard any rub. I'll take some lock to lock pics tomorrow and post.
These Falken tires are supposedly 32.6" tall. I run 50psi (they hold 80psi for heavy loads, but this is a 1/2 ton) upfront and 48psi out back so I'm not sure they hit 32.6" tall.... but  I don't see why the 285/70r17 wouldn't work in a standard 1.85 Bilstein setup. I was thinking about this exact setup before I got a killer deal on the Pro-Comps.
Awesome thank you!
Here are my lock to lock clearances
Front liner
Rear liner
For today’s mods, removed the lower air-dam and added a magnaflow (it’s a lil loud)
Front liner
Rear liner
Did you keep the resonator and flapper or remove those too?
Here's the Magnaflow cold start. It's a bit much, but I'm currently enjoying it. Not too loud if I'm not on the go pedal. Magnaflow 12619 Cold Start video
3 cats, flapper in place, but AFM disabled.
New updates: removed the factory running boards
Then I decided the Black Pro Comps were not working for me. So I got these!
I really like how it turned out. Have always liked these wheels
  • 3 weeks later...
You ever thought about running spacers with those rims.   One guy on here got away with 1" spacers without cutting his studs.   I'm contemplating those 285s on my GMC rims like yours with a 1" or 1.5" spacer on all 4 corners.
My 275/65 Nittos come real close to hitting my UCAs at full lock.  I'm talking 1/2" or less.  How close are those 285s?  I'm talking full lock and hold with a bungee or a friend...it makes a difference.
