I'm looking to replace the film on the driver's side mirror, and install some on the passenger side mirror.  Would like to completely cover both side mirrors, edge to edge.  Was getting blinded by the passenger side mirror, the edges of the driver's side mirror, and the "blind spot bubble," on my way home from working "graveyard shift."  I may just tint them with regular window tint.
Is that merely a tint or the photoreactive material that darkens when hit by headlights from the rear?   Will it work if covered in standard window tint?
Not sure what it actually is, was already on the truck when I bought it.  Not looking to cover it, going to replace it, edge to edge.  Actually looking for same stuff, or something like it.
Ok.  Just be aware.  It may be something more specialized than just a tint.   I’m sure there are others here that will know for sure.  I may be wrong but hate to see you do something that might ultimately be worse.
The driver side has this Dimming feature on the higher trimmed trucks. This is a DL3 mirror and is reactive to the headlights hitting the rear view mirror.
  • Confused 1
WAIT!!!  You're saying that it's part of the mirror?  Looks more like it's a polarizing film laid on the mirror.  Man, I wish that they would have done that to the entire mirror, and have it available for the other side.
And I was following this thread in hopes of something new...
Too bad, it would be nice to have a film that anyone could apply.
2012 2500hd 6.0l CCSB 4wd
The outside mirror is tied to the interior auto dimming mirror, I’m pretty sure. It’s an electronic dimmer, kind of like an lcd screen. When power is applied, via the sensor in the mirror, it darkens. When it’s unpowered, it’s nearly invisible.
16 hours ago, pickmeup said:
A place called the Tint Depot .comm. sells a anti glare film for your inside mirror and both outside mirrors and is priced at $25.00
Yeah, I found them, before.  But I'm not looking for anti-glare, I'm looking to not get blinded by the sun, off both side mirrors, with the sun at "my 6."
Like others above are saying. That is the auto dim feature on the mirror. It looks like it is stuck in the on position. Mine only does that at night. It helps cut down on headlight glare at night. The drivers side and rearview are the only mirrors with this feature at night.
  • 4 years later...
Where I can buy this type of films, I toke my truck to a Carwash and the film flew out. I need both sides. Can somebody help, thanks.
check with a tint shop or a Auto glass company ( that replace auto glass )or dealership ??
    • IMNTBHO;  the worst thing for the 6L80 is to be lugged down to low engine rpm while in high gear......AKA, to save fuel.   I rarely use D on my '16 with the 6L80 and use M mode to keep engine RPM above 1500 at the speed I'm driving, which is also benefiticial for the tranny because line pressure is kept up because the pump is actually turning a decent speed, and it's not always hunting to drop to the next gear to lower the engine RPM's.   Never above 30mph.............M3, maybe M4 if just driving thru a small NoDak town Never above 40mph............M4 Never above 50-55mph.............M5   This is way better for the tranny and the engine.........especially if AFM is still active.   262K miles on my OEM 6L80 as I type this.
    • If they had nuclear material for "11 nukes" we'd have seized it.    Our military has been rendered either too weak/dumb to seize it, or they don't have it. Your pick,K-nut. Because right now we're fighting over who gets to toll oil tankers in the strait.    I hope you're man enough to admit you've been taken for a ride when it's finished.
    • I hope you’re man enough to admit that you were wrong when it’s finished.
    • And you're obviously full of it too.  Apparently anything he does is perfect to you.  Don't you think this whole ordeal would have been better if he had maybe thought it all through first before bombing Iran at the request of his bffs in Israel, Saudi Arabia, and Qatar?  They are the ones that had the biggest issue with Iran.  Thus they have been pouring the platitudes and giving gifts/bribes to him.  Had he thought about the consequences of what would happen to the Strait before starting anything, we wouldn't have this issue.  Now he is stuck with no way out of this mess.  But you have your head stuck way deep in his rabbit hole to see anything else.  So no, I don't have TDS.  I see what he is.  The derangement is yours from no oxygen in the rabbit hole.
    • Bringing of the fact that every President has said the same thing. They can’t have nukes. I guess you missed that before epic fury they said they had enough product for 11 nukes and weren’t giving it up. That not political or polarizing. The opposition of that is and giving aid to the enemy. The mandate is decades old through many administrations. The difference is TDS.
