And we've got a 2019 Chevrolet Silverado LTZ Order Number
Zane Merva
Executive Editor, GM-Trucks.com
5/21/18
This is might not be the most interesting of updates but we had to let everyone know we finally have our 2019 Silverado order number. This at least proves that the system is working and accepting new truck orders.
And our number is............Order # WDPP57
Check out how we ordered our 2019 Silverado here. If you have access to GM's order tracking system, can you keep us in the loop?
We hope to take delivery of our 2019 Silverado LTZ in late July or early August.
I am slightly jealous. It’s gonna be hard to hold out until next spring.
Do mods get free rides?
Ryan B.
I want to order one but I want the standard bed.  The short bed is a waste for me.  Hopefully it will be available to order soon.  I see the RPO code for the 3.0 Duramax is LM2.
The standard bed would be great for the crew cab.  The short bed is also a waste for me.
Crewcab?
Ryan B.
1 minute ago, RyanbabZ71 said:
Crewcab?
Ryan B.
Correct,  Crewcab with a standard bed is what I want to get.
My Salesman is telling me that currently the system will not allow you to order a CC with the 6.5 bed,.
Anyone validate this ?
Correct. Only Crew Cab short bed is open to order right now.
On ‎5‎/‎21‎/‎2018 at 4:13 PM, Zane said:
Zane Merva
5/21/18
Any idea on when is your truck is expected to be built? week of?...
There is a pic of a Sierra elevation with this setup, so it will be available
Friend who works at the Fort Wayne plant captured this photo today
Ryan B.
No week of yet. I don't really know, but from what I've heard and seen in the startup playbooks, I expect sometime in August.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
