1 hour ago, Donstar said:
Stock tire on a  factory 20" wheel is 275/55/20.  I think this is a comfortable riding and good looking tire size.
I have that exact size with black factory wheels. They do look good, but "comfortable" is not the word I would use. Passable fits better but they run smooth without vibration and handle well enough at 32 to 33 PSI. Any more pressure than that and it gets to riding like a buckboard.
Looks is what gets everyone into hating their ride. My truck came w 22”’s, had dealership downgrade to 20”s then had to order new rims, made the mistake going back to 20”’s cause they look good but wish I had gone to 18”’s just more side wall would give me smoother ride and more sidewall protection too. 20”s tow less too.
Absolutely agree
To the OP: wheels and tires are cool and some are really sharp, but if you go bigger/taller it will show up in less responsiveness. It just takes more energy to turn bigger meats. I would look into a lot of the suggestions here on tuning to get more out of the engine. These Gen V engines are pretty good across the board. Somebody out there must have something for the 4.3.
A lot of good and bad info I'm hearing. IMO spending thousands on forced induction or gearing to change your stock truck into something it is not is a huge mistake. If you want the bigger engine trade that sucker in and apply those thousands to get what you want. Tuning and CAI is cheap stuff that can wake up a sleepy machine. 6 or 8 speed trannies are the secret sauce that avoids having to do these more expensive add on's. The trans multiplies power and the tune optimizes shifting the available gears to get you there.
If you do want to tow be aware a tire with E load rating will handle the load better and I know for michelins can be aired yup to 80PSI if need be to safely carry a load. And they will have less rolling resistance than a smaller heavier mud tire so more MPG.
Edited by Pearl2017
7 hours ago, newdude said:
Performance/speed shop.  https://www.procharger.com/      https://www.procharger.com/dealer-locator   It would take some custom work to get the 5.3 kit I'd imagine to work.  We've got a place up here in NY that would be great at making that type of thing happen.  https://www.berg-racing.com/
Custom tune.  Never out of the box plug in tuner.  BlackBear Performance, or a local LS/LT engine specialist.
So the out of the box tuners aren’t worth it? I’m sure I’ll have to rely on a experienced tech somewhere to help but I was hoping some of these new plug in programmers were easier to use now. I’ll definitely look into the tuning to E85 and possibly 4.10 gears or 3.73...
Right now I have some 275/55/20s. I switched from the small factory 17s hoping to get a better and sportier ride and look. I ended up getting a rougher ride over 70mph on the interstate! I’m definitely opting for a 2.5” leveling kit so when I get some better tires, they don’t rub. I see know that I need a taller tire. My old ram that I used to have was all ready for me with the Hemi and Laramie 4x4 Edition. I’m just chasing some extra HP to get me through a couple of years.
There’s a procharger place about 80 miles away in Decatur, Al! I’ll call them up. Thanks
3 hours ago, TXGREEK said:
Absolutely agree
I once thought that 20's with a 55 aspect would be like wagon wheels until I experienced my daughter-in-law's Yukon XL and my son's High Country both with factory 20's.  I believe premium quality highway tires on 20's will give a nice ride and wouldn't hesitate to have these on my own truck.  Unfortunately, changing tires and wheels is not as simple as  trying on shoes. I was able to try the different sized rims with similar tires on similar vehicles.  If I relied solely on what I read and didn't have this recent experience I too would be anti-20".
I’ve got the 16 Yukon XL, wife loves it but did notice harsher ride once I got ride of the factory tires and then put these Michelin Defenders on, they’re 27/55/20. I’d like to change them but what’s a better tire?
My 18 GMC Sierra 6.2 rides on 275/60/20 and rides harsher with new BFG KO2’S. Need the AT’s cause I’m off-road in grassy areas often.
Btw, both vehicles aired at 35 psi
The harsh ride on this combination surprises me.  Good to know as I thought this would be the ideal wheel and tire!  I believe my positive experience on 20's referred to earlier was with Continentals and BF Goodrich highway tires.  I have Defenders on my 17's.
It rode very smooth with the continentals. I’ll let you know once I switch them out.
They look good! My offset may be throwing it off some though. I’d like a taller tire like that.
Thanks! Yeah once I hit 70mph the truck is shaking so bad.....
    • Yes, I used my multimeter to probe all of the wires at the MAF, both with the sensor connected, sensor disconnected, key on engine off, key on engine running, etc etc etc. I probed all of the wires again at the PCM, at the connectors, etc. All voltages are what they should be according to the service manual/wiring diagrams. All grounds are good, less than 20 millivolts from the battery negative under load. Both at the connector of the MAF, at the PCM connector etc.      I know this throws a pretty big wrench into things, but this truck was acting up before the swap. I don't have very much information, if any on what was causing it, but if you cleared all of the dtcs it would do the same thing where it would crank, fire, then die. And it would do the same thing a dozen or so times, and eventually it would start and run, but the difference is that it would run and actually be drivable. Whereas now if you can drive it at all, it goes into reduced power mode almost immediately, and even then it's not running correctly. When you come to a stop at a light it stumbles down to for 500 RPM before catching itself and returning to the smooth idle. And if you go more than about 50% throttle then it immediately goes back to doing the misfire thing.    Like I said, I know that throws a wrench into things, and unfortunately I was not able to pull any data or anything like that before I did this work, so I don't have much to go on.    I'm trying to not fixate on one particular thing as the cause of the problem, but it seems like all avenues are pointing me towards the PCM. Like I said I have tested the wiring extensively (see above), and during cranking the sensor does produce seemingly legitimate values at least according to my multimeter, but as soon as the engine fires those values quickly descend into gibberish. I've tried it with multiple different known working sensors, I have done literally every test I can think of multiple times on the wiring (probing the signals, probing the pins with the sensors unplugged, probing the pins at the PCM, voltage drop, voltage drop under load, continuity, ohms, and double-checking everything against the wiring diagrams/ proper values in the service data.)    Another thing that pushes me towards a possible PCM failure is, I have noticed in troubleshooting a little bit taking a break and coming back, that when I leave the truck to sit for a while and cool off, it starts and runs smoothly when I first start it up. However once it warms up. It starts having problems. For example, when I went out to the truck this morning after it had been sitting overnight, I was actually able to drive it down the block. And then once I got on the throttle a Little bit after going about a thousand ft, it started misfiring again. I pulled it back into the driveway, shut it down, and started it back up. It idled smoothly. As soon as I touched the throttle it did the misfire thing again. From then on as soon as I started it it would misfire. I shut the truck off and went to go get a coffee and do a bit more research. When I came back out I started the truck up and it immediately went into the smooth idle. After a couple of minutes of playing around with it, it would not idle smoothly anymore. Let it sit a couple of hours, rinse and repeat. This makes me think with temperature change something is going wrong inside the PCM. I have the PCM out of the 2007 donor vehicle and I'm thinking of getting a one-day subscription to the ACDelco programming service to try and program that and see if it helps.   Like I said, I'm really trying to not fixate myself on one potential cause, but it seems everything is pointing me towards PCM failure. I would really like to try to confirm that, but unfortunately I don't have an oscilloscope or a signal generator to do the GM service procedure where you feed 5 khz into the signal pin.
    • Ahh, sorry about that - I got some bad info. Newdude is correct. That's what I get for working 13 hours straight ... on my "vacation", lol.   Should've checked the files I had instead of the internet.   Anyway ... this is GREAT news, since this would've been an absolute friggin nightmare to get working.   I don't think the lack of VVT is causing this - you've got another issue. Wiring, I'm betting.   I'm telling you right now, your computer isn't bad. If it worked before the swap, it's working now. You need to do some more (better) diagnostics and figure out exactly what you're missing. Did you test every wire directly at the MAF? Have 5V reference? Ground? If you're reading ZERO g/s, your Hz isn't much use - it's going to be the wrong value anyway. The MAF is not working, and you need to find out WHY.   I got this off the net, so VERIFY first: Pin A: Black (BLK) wire, Circuit 552, serves as the Sensor Return (Ground).  Pin B: Tan (TAN) wire, Circuit 472, carries the Intake Air Temperature (IAT) signal.  Pin C: Yellow (YEL) wire, Circuit 492, is the primary MAF Sensor Signal output to the PCM. Pin D: Pink (PNK) wire, Circuit 339 or 539, provides Ignition 1 Voltage (Power).  Pin E: Tan/Black wire, Circuit 552 or similar, often associated with the Intake Air Temperature ground or signal return.  Global-A list: https://postimg.cc/KKJnQC85
    • Correct....the end user can't reach to Realtruck directly like they can if they purchase a Bak, Undercover, etc...  It has to go through a dealer.
    • It is 4wd. shop told me it is the slip yoke. But not sure.
    • No, I did not tune out vvt. From what I read it should still be able to run without it, it'll just lose some torque/power.    I can see how that would make it not run correctly, but why would that cause the faulty MAF readings?   EDIT: I just ran a quick test and checked, and as I expected, the computer sees that the VVT cam phaser solenoid is not present, and throws a code for it, and does not try to change the cam angle at all. Commanded position just remains at zero, 100% of the time. This makes me think that the VVT is most likely not the cause of the problem though if anyone has a different/better explanation, I'm all ears.   UPDATE: I was able to find that my scan tool does indeed support reading the frequency (hz) off of the MAF (I thought it wasn't supported but turns out I just didn't know where to look for it). I noticed that regardless of engine state it always however this Is not what I observed with my multimeter. Like I said before, the MAF seems to put out a normal signal during cranking and then the signal drops to a very erratic reading once the engine is running. It seems from what my scan tool is telling me that the ECM is not recognizing this at all, and just reads 0 Hz 100% of the time. This pushes me towards the the PCM itself is faulty. I I have the PCM out of the 2007 donor vehicle, which I may try to connect and program (it's only ~50 bucks to get the software for a one-time programming)
