9 minutes ago, ausomecasey said:
Looks good! How is the power with the bigger tires? I can’t decide between a few different tires with a size of 275/65/20 or 285/65/20, and I’m worried how the 5.3 8 speed will handle the heavier tire.
Both those sizes I believe are LT tires too. So yes performance will hurt.
Handles it just fine in my opinion, love the 8 speed.  My other vehicle is a '16 Z06 so I know what power is and the Silverado is plenty fast when u want to get up to speed or get around a Ford truck getting in your way, lol.  Of course it's all subjective to each person.  This truck was a replacement for a '17 silverado with the 5.3 that was not lifted and had stock tires and rims and I could not tell u the new one feels slower because of the bigger rims and tires, feels just fine ?
Edited by Ken Reagan
Hahaha! I was assuming I’d probably feel the same way, so it’s good to hear I don’t really need to worry about power loss in my situation. Thanks!
I wouldn't think you would, before test driving it I was worried about that same thing and then when I went for the test drive I was pleasantly surprised.
7 hours ago, Ken Reagan said:
Here is my baby, had her for about 2 weeks now, LOVE IT!!!!!!!  This is my first lifted Silverado and just love it.
*****EDIT ******
Just got a call from dealership, my Katzkin leather is in and the AMP steps, WOOOOHOOOOOOO
Truck looks awesome bro !!  Black & red combo goes very well imho.  To the earlier poster, to each their own.  I like both chrome and black rims.  They each have their application but again everyone has there own taste... Cheers ?
On 9/18/2019 at 5:06 AM, tanner709 said:
any better details shots of that front end? specifically the grille area, quite unique.
x2 !!!
SmartSelect_20191012-123743_Gallery.thumb.jpg.e62ba8e265f51fb92dc4f36432e49db8.jpgSmartSelect_20191015-215136_Gallery.thumb.jpg.4656c529fce19ff5bc0fe4141db9b63b.jpg
*****EDIT ******
Be sure to come back with some pics of your AMP steps!
Sure will, I'll post up some of that and the seats.  Did a solid black seat with the 4 wing spots in red.  Going to look amazing!
Hate to ask this in here but this thread gets alot of action and technically I am asking for a picture, lol.   Could someone post pictures of the version screens (there is a few) for there radio that has the IOR version, this is the cheesy version that does not have the climate control app?  Thanks guys.
P.S. the truck is at the dealer getting the AMP power steps installed, woooohoooo!
1 hour ago, Frank DeVoe said:
Thrilled to now own this beauty. No immediate big plans, just happy to have a new vehicle, as my 20 year old jeep has had enough.
Congrats on the new LTZ!
You are going to love them. Amp steps are a must for a lifted truck especially when you have kiddos. Mine have worked perfectly since I installed them.
Very cooooooool!!!!!  Love the black on black too!
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
