19 hours ago, becker87 said:
Got rid of the duratracs today and put a set of cooper AT3 XLTs on. 275/70/18. Have already seen my mileage jump back up. Duratracs are a great tire off road but just don't spend enough time there to justify the negatives3fc54a9080bc5543f4043505887e7cc8.jpg07552c1fef9b838788b22ce14bc97116.jpg
What do you feel was the MPG loss with the Duratracs?
2 hours ago, STX30MAC said:
What is that on the hood? I want one. Do they make it for GMC? Is the bumper molding different also?
Auto Ventshade Lightshield Hood Protector and Air Designs bumper guard.
Amazon has the Lightshield for the Sierra.
On 2/29/2020 at 7:18 PM, Ryguy said:
Put in work today, trimmed a few trees on the farm. I like using my truck!
Truck looks awesome. 33x12.50-18s?
On 2/17/2020 at 8:42 PM, FrankK986 said:
2020 RST Crew Cab Duramax 2c6273a1c05f4d8adf2097da0089af59.jpg33a9252d2dd1bcccaf2e99989b231aef.jpg
This truck photographs well but looks even better in person. Nice meeting you the other day, Frank...
Wow - thanks! What a small world. Great meeting you and let me know if you have any questions on my build as you get closer to pulling the trigger. Happy to help.
35 minutes ago, thundar56007 said:
Nice truck just got a Rally RST myself with the 6.2 , is this lifted at all?
A Rally RST?
9 hours ago, mafd2 said:
A Rally RST?
New trim for the 2020’s:
The Silverado Rally Edition is offered on the Custom and RST trims and features a sporty look, available in Black, Red Hot, Silver Ice Metallic or Summit White exterior paint. The street-focused edition includes a body-colored grille, black Rally stripes on the hood and tailgate, black Chevrolet tailgate lettering, black badging, black Bowties, black exhaust tip(s) and black assist steps.
47 minutes ago, paulny said:
Give me your badges and exhaust tips now!!! Nice truck. I have a 19 AT4 and need those things but so far i am too lazy to do it myself.
Had a 2014 Silverado LTZ that was a great truck with absolutely zero issues. Traded for a 2018 Sierra SLT Z-71 that was a complete POS vibration issues and the dreaded 8 speed issues. So I rolled the dice and jumped on this 2020 AT-4 with the 6.2 and the 10 speed so far I am loving it. Keeping my fingers crossed that it holds up. I sure love the way it looks.
Edited by Ltz73
Mistake
I’ve got your twin! Hot truck if I say so myself ?
    • I am new to this… but I saw some of your replies to another person doing the same as me… trying to replace the temp control actuator in my 05 GMC SIERRA, And can NOT get to it… how do I get the center console panels off, do I have to take ALL of them off to get to it? 80481681120__F97CE005-C5E5-4FBF-9589-1388214E3586.MOV
    • I will be one of those "blinded". One, I like new shiny things. Two, I've never kept any of them beyond the 3/36. Three, I don't finance anything. Four, yep, it's a waste of money....so,what? I'm doing my part of keeping automotive industry going and keeping my neighbors, most of whom are in it, employed. 😉      By the way this is the "signature... ¬
    • Although there is a "recommended" weight by those who sell trailers, my experience has been that they are way too aggressive in their information, for me at least. My '22 with 6.6 Gas, has a payload of about 3400 lbs and depending on your specs (I don't have 4WD so it has a bit higher Payload than others) yours will likely be different. Payload is one of the most important numbers for towing. Although you "could" tow the max trailer weight for your truck, I, personally, would not go close to that number. Having said that, a lot depends on how/where you will be towing. I live in the LMD of BC and often tow to Denver, Co, along interstates (flat and mountains) and I find I need to keep it in 5th (6spd) for the trip and travel at around 65mph. This is for a trailer dry weight of just under 3500lbs. If you are only doing local, short trips, it would not be that big an issue if you had a heavier unit. You will be surprised how much stuff you load the trailer with, so I would only recognize the trailers "full" GVWR weight rating, then decide on the appropriate trailer from that number. If you are worrying about how much stuff you should be putting in a trailer, you might have too large a rig from the get-go. Once again, depending on what terrain/distance in which you will be pulling. Marv
    • davester, Thanks for the response, how ever, I think I am now a bit more confused than I was before I posted - - After I posted, I actually found a YT video of a guy who replaced his Module (above tire) and he only disconnected the ground cable of the battery, but you describe rubbing the two cables together after disconnecting. I presume that is to do as you describe and eliminate any residual energy? - When I picked up the Module (between my posting and reading your response) from the dealer, I specifically asked about any re-programming and he stated it was not necessary as it was simply plug and play. Don't know how knowledgeable he is, though. - The video I watched also showed the Module plug to be difficult to "unlock" and remove, but there was no mention of silicone, although the video did show a bunch of dust/dirt in and around the plug (old truck) during removal. Are you talking about silicone that was applied by the factory, or silicone that you applied prior to plugging in? Thanks again, Marv
    • Looking for a clean, factory-style lighting upgrade for your 2022+ GMC Hummer EV? M&R Automotive's 40" Bumper Light Bar PRO features a vehicle-specific, bolt-on design with no drilling or cutting required. Choose a bright white or yellow main beam, both paired with an amber DRL backlight for a sleek OEM-inspired look. The kit includes a curved LED light bar, powder-coated brackets, and all necessary mounting hardware.    Learn more or order yours See how it installs and looks on the vehicle:
