Well after finalizing the order on my new Silverado on August 30, Built on October 3, then missing an October 11 arrival date to the dealership and GM pointing fingers because my truck is still MIA 9 days later with no one claiming to know anything. After days of going back and fourth with GM, I called my dealership and they asked me to come in to see if a truck they just got in appealed to me.... Well after looking it over and seeing it was nicer, I pulled the trigger on it AND only paid $1,000 more than my build (Dealership felt bad)
My order was LTZ 4X4 Z71 Texas Edition with 18’s (because I was going to lift it and put different wheels on it anyways)
Truck I got today- LTZ 4X4 Z71 Premier Package with 20’s
Didn’t get my exact truck I ordered but feel like I came out on top in the end
Excellent choice on the Chrome Son!  I am done with Black myself...But I will never be done with the Chrome front end!
Thank you all for your kind words!
I am very very happy with the decision to get a 2019.
I waited on the new Silverado release since 2017. The ride quality is A+, Very good comfort, I have been driving like a grandpa but I do feel like it has more zip than the older models but I suppose that's because of the weight reduction.
In my honest opinion, this is a big step up from the last 10 years of trucks (2008-2018) as my last Silverado was a 2008 and My current Tahoe is a 2016 (same chassis as silverados)
That has to be the first 2019 Chevy that doesn't make me barf when I look at it.. good pick!
Love the chrome too. I can see ugly cheap flat black rattle can looking wheels are a fad fixing to fade out. I see more buyers going with chrome and aluminum wheels.
Sent from my LG-V495 using Tapatalk
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
