Does your key fob look like this?
If so it does.
Hit the lock button twice then hold the circle arrow for 4 seconds and it will start
If so it does.
FYI you don't have to hit the lock button 2 times. I just found that out myself last month.
You're right. Only once
I had to try it myself.
I don't know why I thought you had to hit it twice.
Thanks
BTV is the code you are looking for.
BTV    Remote vehicle starter system
On 2017's:
Included on LTZ and HC
On LT trucks - Included and only available with (PCM) LT Convenience Package, (PDU) All Star Edition or (PDA) Texas Edition. Includes (UTJ) Theft-deterrent system.
Not available on Silverado Custom, LS or Work Truck
Not sure if there is a 'accessory' retrofit available from dealer.
You can buy the hood latch kit and run the wire to the bcm and thebdealer can RedLaser your truck for it.  LTs and up if you don’t have it.  The kit is around 80 plus whatever the dealer charges you.  I suggest calling the dealer last around you and getting quotes.  Some act stupid and will tel you they can’t do it.
Thanks
Prior models you did have to hit it twice, 14 on is only once. Just were just subliminally using your memory.
4 hours ago, Fernando said:
Can anyone tell me if my silverado is equipped with remote start?
What model and trim is it, guessing a crew since your VIN starts with a 3.
The 2009 Silverado 2500HD I had, you only had to hit the lock 1 time, just like my 2015
Father in laws 2011 Silverado 1500 same thing, only have to hit the lock 1 time.
Could have swore my 08 needed it done twice, but I am probably wrong, nothing new there....
Edited by JimCost2014
I'm wondering if Fernando's truck had it? I didn't see the BVT on the option code sticker so I'm thinking it don't have it. Must be LS or WT?
Easy answer is the key fob .
It’s an LT. should I buy a fob with the remote start and get it programmed and see if it works?
If your truck did not come with it, you will need everything that comes in this kit, 22997089 Complete Remote Start Kit for 2014 - 2018 Silverado or Sierra 1500 OEM
Send your vin to [email protected] ask for a list of your RPO codes and a copy of the service records. Should have it back within a couple of days sometimes within a couple hours.
 List will email to you like this
                              Vehicle Build
Model: CK1xxx-2xxx SILVERADO 1500 4WD CREW CAB Order Number: SBKQ3C Gross Vehicle Weight: 3,269 Build Date: 10/07/20xx Build Plant: G
           Option Codes
*IVH is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
    1LT - SILVERADO LT EQUIPMENT GROUP:
4AA - INTERIOR TRIM
7GG - COMPONENT FRT RH
COMPUTER
9X2 - COMPONENT RR RH NON-COMPUTER
A60 - LOCKING TAILGATE AG1 - PWR SEAT ADJUSTER,
DRIVER
AL0 - AIRBAG SENSING SYSTEM, PASSENGER
AU3 - POWER DOOR LOCK SYSTEM
AY0-AIRBAGSDRIVERAND FRONT PASS
B1J - WHEELHOUSE LINERS, REAR
B32 - FLOOR MATS, FRONT B86 - BODYSIDE MOLDINGS,
BODY
BWN - CORNERSTEP, REAR BUMPER
C5Z - 7,200 LB GVW RATING D75 - DOOR HANDLES,
BODY COLOR
DL8 - POWER HEATED OUTSIDE MIRRORS
E63 - PICK UP BOX
FE9 - 50-STATE EMISSIONS
G80 - AUTO LOCKING REAR DIFFERENTIAL
GU6 - REAR AXLE 3.42 RATIO
I15 - ENGINEERING YEAR 2015
JD9 - ANTILOCK BRAKES, 4 WHEEL DISC
K34 - CRUISE CONTROL
KG4 - ALTERNATOR, 150 AMPS
1SZ - OPTION PACKAGE DISCOUNT 6GG - COMPONENT FRT LH COMPUTER
8X2 - COMPONENT RR LH NON-COMPUTER A31 - POWER WINDOWS, DRIVER EXPRESS
A68 - SEAT 60/40 REAR FOLDING BENCH AKO - GLASS, DEEP-TINTED
AQQ - REMOTE KEYLESS ENTRY AXK - VEHICLE TYPE TRUCK AZ3-SEATS,FRONT40/20/40BENCH B30 - COLOR KEYED CARPET
B33 - FLOOR MATS, REAR
BTV - REMOTE VEHICLE START
C49 - ELECTRIC REAR WINDOW DEFOGGER
CJ2 - AIR CONDITIONING, DUAL ZONE CLIMATE CONTROL
DH6 - VISORS, DRIVER AND FRONT PASSENGER, LIGHTED DP6 - MIRROR CAPS, BODY COLOR
EF7 - COUNTRY CODE, U.S.A.
FHS - VEHICLE FUEL GASOLINE E85 GAZ - SUMMIT WHITE
H0U - JET BLACK
IO5 - CHEVROLET MYLINK AUDIO SYSTEM W/ 8" DIAGONAL COLOR
TOUCH
JL1 - TRAILER BRAKE CONTROLLER
KC4 - ENGINE OIL COOLING SYSTEM KI4 - POWER OUTLET, 110-VOLT AC
                           KNP - TRANSMISSION OIL COOLER
MAH - MARKETING AREA NORTH AMERICA
MYC - TRANSMISSION, 6 SPD AUTOMATIC
NP5 - LEATHER WRAP STEERING WHEEL
NT7 - EMISSION SYSTEM
PPA - EZ LIFT AND LOWER TAILGATE
R9N - FORCE ON ALL VEHICLES FOR PRICING OF INTERIOR TRIM
RC4 - TIRE, SPARE 17" ALL SEASON BLACKWALL
SAF - SPARE TIRE LOCK T3U - FRONT FOG LAMPS
U2K - SIRIUSXM + SERVICE SUBSCRIPTION SOLD SEPARATELY BY SIRIUSXM AFTER 3 MONTHS
UDD - DRIVER INFO - COLOR DISPLAY
UF2 - LED LIGHTING, CARGO BOX
UK3 - STEERING WHEEL AUDIO CONTROLS
UQ3 - ENHANCED AUDIO SPEAKERS
UVC - REAR VISION CAMERA
V76 - RECOVERY HOOKS, FRONT
VJH - BUMPER, REAR CHROME
VPZ - CHROME GRILLE VT7 - OWNERS MANUAL
ENGLISH
WMF - VIN MODEL YEAR 2015
XL7 - FREQUENCY RATING 315 MH
Z82 - TRAILERING EQUIPMENT PKG INCL: AUTO LOCKING REAR DIFFERENTIAL
ZY1 - SOLID PAINT
L83 - ENGINE, 5.3L V8 ECOTEC3
MSL - SILAO, MEXICO PLANT
N37 - STEERING COLUMN, TILT & TELESCOPING NQH - TRANSFER CASE 2-SPEED
PDU - ALL STAR EDITION * TRAILERING EQUIPMENT PKG INCL AUTO LOCKING REAR DIFFERENTIAL * PWR SEAT ADJUSTER, DRIVER * FRONT FOG LAMPS * AIR CONDITIONING, DUAL ZONE CLIMATE CONTROL * STEERING COLUMN, TILT & TELESCOPING * REMOTE VEHICLE START * CHEVROLET MYLINK AUDIO SYSTEM W/ 8" DIAGONAL COLOR TOUCH * REAR VISION CAMERA * REAR WINDOW DEFROSTER * POWER OUTLET, 110-VOLT AC
PZX - WHEELS, 18" BRIGHT-MACHINED ALUMINUM RBW - 18" TIRES, ALL TERRAIN W.O.L.
S2B - SPARE WHEEL, 17" ALUMINUM
SLM - STOCK ORDERS
TG5 - SINGLE-SLOT CD/MP3 PLAYER U73 - ANTENNA - FIXED MAST
UE1 - ONSTAR
UJM - TIRE PRESSURE MONITOR SYSTEM (EXCL SPARE TIRE)
UMN - SPEEDOMETER, MILES & KILO, MILES FOR ODOMETER
UTJ - THEFT DETERRENT SYSTEM
V46 - FRONT BUMPER, CHROME
V8D - VEHICLE STATEMENT
VK3 - FRONT LICENSE PLATE BRACKET
VRK - VAA/COMPONENT REL ROOF TRIM
VV4 - ONSTAR(R) 4G LTE WI-FI(R) HOTSPOT W/ 3GB/3MO DATA TRIAL
X88 - CHEVROLET CONVERSION YE9 - TRIM PACKAGE
Z85 - SUSPENSION PACKAGE
        Added Option Codes
#50 - Wheels/Wheel Covers/Locks/TPM Sensors #77 - Exterior - Front Grille/Grille Guards #16 - Graphics/Decals/Emblems - Kit
$230 shipped on Amazon for that kit seems pretty reasonable to do that upgrade if not equipped.
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • can you tell if the reader is actually trying to get codes, and the pcm is reporting none, or is your reader just silently failing because it's not communicating with the pcm?
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
    • Take an automotive stethoscope to the vacuum pump. Iirc those tick as well.
