54 minutes ago, GSC52 said:
But from the posts, looks like the dealer may not be any help.
Yeah, about the only 'help' they can actually provide is dropping your 8-speed out and putting a 10-speed back in its place.
I have over 15000 miles and mine still cant figure out what gear to be in, still lunges and and lurches on downshifting when coming to a stop. Its been to the dealer 5 times, with no resolution. Just the good ole cant duplicate the problem. F'ing fed up with GM. You can buy a $7K TV and if it has one minor issue you can return it. Buy a vehicle and it can have a million major issues, and your screwed... The government needs to be stricter on these companies, considering they took my tax dollars to bail these scumbags out.
drove me crazy in my 2019 gmc 5,3 8 speed, left at dealer overnight several times, same answer cant duplicate issue, i even paid for the trans fluid change to the new stuff but didnt help. got sick of it traded it in for 6.2 10 speed
I have a 2019 Z71 and has had a hard shifting issue within a month of purchase. Sometimes it does it to 4th gear. every time i bring it up to the service  department they say GM know about it and it is normal. This is the first GM truck I have had since 1998 and never had this many issues with any Ford. I am tempted to get in on the lemon law  suit that is going on with GM.
James
A google search brought me to this site, like some of you I'd guess.  I've had my truck since Sep 19 and have had the same slipping/lunging problem after backing and shifting to drive, since I've owned it.  Doesn't matter if warm or cold, it's a repeatable pattern...unless you take it to the dealer.  My truck is in for the second time and I'm hearing the same answer all of you have heard..."normal operation for this transmission". BS
On another news type site it mentioned a class action case for this problem. Is anyone aware of that, or is that fake news?
Just purchased a Chevy Hd 2021 crew cab standard bed it’s 30 degrees out. Just went outside to start let it warm up took off down the road and when it started to shift it kicked hard from 1st to second. I thought it was just still cold, drove another 3 miles to store it kept doing it on the way there. Brought home and parked it, will have to call dealership Tom Gill Chevrolet Florence Kentucky in morning to take down and have looked at. I’m sure once I drive almost 2 hrs. there it won’t be doing it. But I really don’t want to pay $53.000 for a lemon truck. Do anyone have any answers for me. Thanks
Edited by Mark Bushhogging
Glad I found this site! Just purchased a 2019 Z71 5.3 8sp trans this past December. It's my first pickup, out of all the american companies for some reason I was set that I wanted a Silverado. First american car since 2000, had foreign cars since this past December. I liked the new body style on these pickups. But now I wish maybe I saw this website in hindsight before making the purchase.
I too am experiencing this hesitation when my engine is cold. It seems to hesitate no sooner I back out of my driveway put it in drive it seems to do this hesitation before it shifts in second gear. I also of course have the hard shifting in 2nd gear once it does shift. But then again, I have the hard shifting sometimes under normal operation in 2nd and 3rd gears. And downshifting is harsh as well from 3rd to 2nd gears. So it seems that there was no fix for the hesitation problem. Or has anyone come across a fix yet? I mean other than trading in your vehicle with 8spds to a vehicle with an 10spd.
On 4/10/2019 at 7:03 PM, ShamrockShooter said:
Look up bulletin #16-NA-361 harsh 1-2 shift upon first startup shift under light throttle. GM says it normal on the 8 speed. It has something to do with the initial clutch fill time of the C4 clutch. No fix for it. Gm says it's normal. I have driven more than one 2019 8 speed and they all do it.
Just got a 2021 GMC Canyon and notice the rough shift every morning. Is this something I’m just gonna have to live with, does it smooth out over time? Just wondering if there was any resolution you’ve come to. Thanks
Well whatever the issue is with a harsh shift or hesitation you shouldn’t have to live with it. If they its a normal operating characteristic and even if they have a technical bulletin saying its normal its all bullshit. GM has been getting away with problems with some of their vehicles for too many years, they can’t even be bothered to actually solve a problem like yours, been there done that!
But go ahead and see if they come up with a fix...good luck!
i have a 2015 silverado 1500 6.2l that does this its not isolated to the 5.3 it happens first start and some Randoms here and there. last one i thought my transmission gave out
I have a 2019 rst/z71 with 30k miles on it with this very same issue and I've had it at the dealership twice with no real  resolution.   I've always had the weird hesitation when going from 1st to 2nd after starting, but around 15k miles the truck started slipping in just about every gear.  I could be going 50mph and all the sudden i would experience it to just start jerking trying to shift gears.  Dealership said it was due to not having the correct transmission fluid and they flushed and replaced with a mobile 1 synthetic.  There is actually a TSB on this for the 2018-2020 models.  That seemed to help with the over all slipping but did not with the low gears.
Around 28K I started feeling this weird subtle hesitation when i would ride around 35-40mph.  So i took it back to the dealership 2 weeks ago to address the low gear hesitation and this new issue.  I just got it back today and after having it two weeks i basically got the same story everyone else is getting except they blamed my 35" tires for the 40mph issue saying that it was gear hunting due to weight of the tires and the gear ratio is not setup for that.  Even though they have been on the truck since the day it left the dealership.  Then he said the 1st to 2nd slam when i first drive it is something called "Dry Clutching".  Says that the top half of the clutch has been sitting out of the fluid for an extended time and after a few shifts it gets coated again and that's why it seems to go away after driving a few miles.
I tried to reproduce it for the shop manager, but of course it didn't happen when he was in the truck with me.  SMH..  So i guess im just going to have to swallow this BS pill considering it seems almost every single owner of these year model trucks has this issue.  By the way i did purchase the pulsar LT tuner and turned off DFM, auto start and updated my tire size and the slipping still happens.  The tuner has a throttle response feature which is useless for this truck because it just amplifies the hesitation.
I have had mine in for service serveral times. Dealership states GM has informed them not to touch the transmission, that it is operating as normal.. I have owned Chevy all my life, this is very frustrating.
  • 9 months later...
Mine does the same thing. One time I backed up out of my buddies driveway onto a main road, shifted into drive then had to gun it and it completely lagged then slammed into gear. It felt like I hit something and scared the crap out of my kids. Is this something covered under warranty? This situation also made it unsafe for me because I needed to accelerate pretty quickly but instead bogged and slammed into gear. This should be a recall.
Edited by Arnie8715
    • when it's greyed out that is it's way of telling you that it's downloading the patch in the background. Eventually it will be fully downloaded and then it will prompt you at ignition shut down to run the update. I highly recommend doing the update once you get home and can run it a few times. I've had several issues with updates not going the first time around and I had to retry the update multiple times in my driveway before it was successful.   Some updates are huge and take awhile to download. You can help it by connecting to your home WiFi and keep the truck on service mode for the ignition and keep it alive for awhile on a battery charger too. There are specs it needs to be in for updating such as a full enough battery charge, no running ignition, etc.
    • I am not techy at all but wondered if you have the truck running but sitting still in park as some functions gray out as soon as the truck is moving. I believe in the settings for updates you can choose for it NOT to update and I wonder by chance if maybe that was chosen before and now it won't allow you to chose to press update, I think that is back in the settings menu where it has all the items one wants on or off etc. Also I assume you have a wifi connection and checked that it has some signal strength, not that it would have anything to do with the grayed out updates choice in that case. What I am thinking out loud of here may be be of no value but thought I would suggest it, sometimes it can be the simplest thing that resolves an issue.
    • The so called rare failure that some certainly liked to tout ( die hard Ford fan boys ) as per the lifter failing and wiping out the cam. Back when it started happening the blame was being pointed to the lifters and honestly I never did hear anything myself conclusively one way or the other on that. Ford themselves in I believe 2024 had a technical bulletin I will call it that came out and for some engine platforms they were reprograming the engines idle speed but also they had a software update for the oil pump which then some time later was said what that software update did as to be increasing the oil pressure at idle. It is a good question if that issue was completely solved as one Ford specialist mechanic youtuber said he saw failures after that time period. Like anything there would be the variables, what oil is being used and the OCI and how much idle time gets put on an engine. I've seen some comments to claim that the L8T isn't so happy with high idle time either but I also know that companies that require their vehicle to idle a lot on the job don't tend to get the oil changed often enough for all those hours of idle time and go off of the odometer.
    • My 2026 Silv. 1500 WT (reg cab/short bed/4wd) has the 40/20/40 with storage in lower middle seat as well as the fold-down center bolster/armrest.   With the dual glove boxes this is about as much storage as possible in a std cab IMHO. Bill
    • I have a 2026 base 1500 "WT" regular cab with basic Chevy "Infotainment 3" 7-inch screen/radio. How many speakers do I have If I want to upgrade? Is the audio amp separate from the radio/display unit]? [I listen to classical and it gets a bit raspy at slightly higher volumes. Don't need a sub etc.] Do I have two or 1 speakers in the doors? etc. Thanks Bill  San Jose
