PGamboa,
Please assist.  I own a 2015 Silverado 1500 LTZ Z71 with the 6.2L engine.  I recently installed some tow mirrors and the clearance lights do not function at all.  The lights do not turn on with the cargo lamp on or even in reverse.  I was told I may need some additional wiring to ensure this works.  I heard you are the man with the plan.  Anything would help.
  • 8 months later...
I’ve been trying to get the wiring diagram for a 2011 Sierra with Factory tow mirrors. Neither side move with switch and I wanted to get a wiring diagram before I decided to pull everything apart to check
Check with Phil Gamboa at https://harnessdr.com/.
Though the 2011 might be a bit old for his specialty, I don't know.
Edited by MikeBMW
I ran a check on the wiring. I took the door handle off and back probed the wire it’s getting 12v it’s the mirror switch. I just have to order one or find a junk yard with one.
If anyone is still not sure how to do this heres is what i found on my 2015 Silverado High Country.
Somewhere along line someone put older tow mirrors without functions.
Turn signal on the tow mirror harness is pin 13(positive 12v signal hot)
pin 5 is ground
pin 1 is the running lights behind mirror (12 volt signal)
pin 2 is the puddle lamp white led 12 volts
when connected only the mirror turn signal would work nothing eles
I open fuse box and ran hot from 15am ign fuse(used a 12v test light to make sure it only turned on with key on)
and connected to the bcm . i used a meter to check for continuity from mirror harness pin 1 and found the cable in the bcm on the grey plug.
For the puddle light all i did was jump pin 2 & 8 on the mirror harness. (by doing this when you turn on the rear defrost you also get the white led.
Theres diffrent ways to do this but this was quickest way without disassembling door panels.
if need to add the powerfold just trace the door harness pins to the bcm using continuity check using dmm not the test light.
  • 6 months later...
On 4/5/2019 at 11:30 PM, pgamboa said:
Tow mirrors have:
Turn Signals
Cargo Lights (Reverse Light)
Park Lamps (Running Lamp)
You want to make sure you add the ground on the mirror plug.  You should have the turn signal in the door jamb plug.  So if you ran it in the cab, splice on the back side of the jamb connector.  The cargo light and running light may not be present on your door jamb connector (it is missing on early model 2015 trucks).
Good luck!
In the BCM, the left/right turn signal are separate.
I know it's an older post, but I have 15 2500HD that came with JUST power mirrors but not lighting. I added the tow mirrors with it and the power side works, just not the lights. I've seen alot of the mirrors have two plugs, the main and a 4 pin after for the light section, mine doesn't have the 4 pin one. I'm guessing they are all on the main plug. Is there a way for me to wire them to make them work?
This video helped me out a lot. It is a pain but it is worth it at the end. Took me about 3 hours total for both sides. PS: take your time while splicing.
I just had GM replace my door harness and now I've lost function of my Aftermarket mirror. When I purchased the mirror i got the add a wire harness kit. But I'm not paying $79 USD for 3 wires. Does anyone know what type terminals GM uses in the door? Figured it would be an easy google search but I'm not having much luck.
  • 4 months later...
On 2/17/2020 at 7:29 PM, LSyOuCaNtCaTcH said:
Bringing this post back from the dead. Anyone know anything about installing these on a 2018 LTZ? Should it have most everything to make the mirrors work? I'm guessing so since I have the puddle lights and the turn signals. How would I go about getting the running light to work? Thanks any help is appreciated.
Just curious if you figured it out, I’m about to install them on my 18 ltz also
  • 4 months later...
I had my factory tow mirrors installed by the dealer.
They replaced the door harness at that time.
Afterward, I wanted the turn signal lights with the tow mirror lights and ordered a plug and play harness from @pgamboa and it worked great!
I, then, installed aftermarket Boost Auto Parts power folding tow mirrors and it, as well, was plug and play with the GM harness and the one from @pgamboa for the turn signal lights.
No splicing or connecting after the dealer tow mirror install.
  • 10 months later...
On 4/6/2019 at 11:48 AM, pgamboa said:
Yes all correct. Ground is any chassis ground.
Do i need to add a ground so my marker lights work ? With I lock and remote start they come on but go off when the key is on .. please help
  • 4 months later...
Do your folding mirrors from Boost Auto still fold easily? After the year warranty ran out, they stopped folding without a helping hand to coach them along. They said the motors were normal wear and tear items, and I needed to buy a new set since I was out of the 1yr warranty.
Mine are still working great. I use them, usually, 6 or 10 times a day depending on how much I drive.
I use them every time I park at work (in and out), every time I go to grocery store (in and out) and every time I come home (in and out).
By "in and out", I mean when I park, I fold them in and when I leave, I fold them out.
Also, I use them when I go through the automated car wash, fold in prior and unfold after.
Sorry you've had issues but, again, mine still work great! :)
  • 4 months later...
    • Indeed a proper drain tap or drain valve with adapter that has a hose on it that opens up the valve as the adapter goes on is a slick setup and have that for certain highway tractors etc and other equipment that came from the factory with a tap but this L8T is pretty darned good other than me doing it on the floor and easy to touch hot exhaust and am not as agile as I used to be !. If I really want to pull a hot filter on an engine I will use an insulated set of thick neoprene gauntlet gloves but I am not in the hurry I used to need to be so things are done more relaxed and in theory somewhat safer ... I think LOL.    And as I mentioned the unique shape of the Amsoil 1 quart containers, while they might not work as well as an offset pour spout container for some awkward engine location applications, they are working a lot better with my Lisle funnel kit because of how they prop up on all four corners when upside down resting on the rim of the funnel where the typical quart container would never stay put without holding onto it.
    • Well, I just hit 100K a few weeks back, and I can honestly say I have not had any major issues with my '21 5.3 Crew cab.  I have done most routine maintenance, oil changes, air filter, tire rotations, and a transmission drain and filter change (not even a full flush).  A couple of months ago, I started experiencing the dreaded CLUNK when coming to a stop, sometimes hard enough to literally push the truck forward! After researching here and in other forums/youtube videos, etc, I was thinking it's the slip yoke. I finally had a chance to take it to my local mechanic today, and he was not able to recreate the issue.  Amazing, since it does it nearly every time I drive.  He also said he can't simply grease my slip yoke/driveshaft splines, because I have a 1 piece driveshaft.  I am not sure what else I can do.  Has anyone else had this issue or have any idea what else it could be?
    • This is where the Fumoto drain valve comes in handy.  No mess and able to change oil hot, like right off the interstate hot.  Flows nice and you can direct it into a container. As for the oil filter, I use an old dixie cup or plastic one from McDonalds. It contains the oil as you pull the filter down and not all over your hand.
    • Well, if it did change from lifters to rocker arms, at least it would be easier to fix as they fail.
    • Doesn't hurt to try.  It's my understanding that you have to run it at least 4 or 5 oil changes for things to get clean.  Think about it, your engine didn't get dirty in just an oil change so over time it will slowly clean. It's the safest way to do it and not have seal issues.      I remember  a product that came out a long time ago, AutoRX, it was an additive you put in the oil and then drove for 3k miles. Some saw improvements and some didn't. It was suggested to use a non synthetic with it at the time. Same observation, use a couple oil changes and give it time to work. It also stated it worked best if you could drive on trips to keep the oil hot.  I'm sure if you ask AI it could tell you all about it.
