2 hours ago, PureZ71 said:
Not exactly sure because I had removed my mud flaps and the bracket behind them  before due to my previous setup (Stock wheels + 2" spacers). They will for sure clear the calipers. But -12 is just the perfect amount IMO.
Thanks!!
On 7/16/2021 at 8:28 AM, Chad Nelson said:
Ahhh I see the fragility of the snowflakes have made there way to this site too.
Ok boomer, I can assure you I am no snowflake. Just letting you know I think that your comment was being an ass for no reason hating on someone's pride and joy. But yes you can voice your opinion as you see fit just as I can. Take care.
On 7/17/2021 at 7:29 PM, Paul 2020RST said:
Yes, that’s his opinion, and he has every right to state his opinion no matter how much you may disagree or not like it.
I agree...but won't stop me from stating mine either. Take care.
Traded my red 2019 Denali with the suspensionmaxx level kit and fuel wheels for a grey 2021 AT4 that the dealer had lifted after it was delivered from the factory. The total lift is 4 inches over the factory AT4 2 inch for a total of 6 inches along with 18 inch fuel wheels running 35x12.5x18 Toyo open country 3s. The kit is a fabtech with 2.5 dirt logic coil overs up front and 2.25 rear shocks. After some research it looks like more like a 5 inch lift plus the 35s which give it the full 6 inch over a stock truck. Rides fantastic, better than my Denali did with the level kit. 2 weekends ago I also took it out on the Burns Canyon Trail (So Cal) which runs from Yucca Valley (Pioneertown) up to Big Bear. It did awesome so looking forward to spending more time off road with this one.
See, right there is the problem. If I liked it I would get a "hey thanks buddy" etc.... But if I say don't like something than I am a hating piece of ******.  It's just wonderful how fragile the internet has made people. Blows my fricking mind.
5 hours ago, The Gibson said:
Tire size?  Stock height?  Looks perfect!
Toyo open county r/t 35X12.5R18. Ready Lift 2" sst lift kit but only installed on the front. Thanks!
35X12.5 BFG KO2s on Fuel Block 18X9 -12 offset. Billstein 5100s set at stock height, front mud flap bracket and mud flap removed. no rub, slightly kissing the felt liner in reverse at full lock.
On 4/6/2021 at 4:00 PM, lapoolboy said:
OEM 22's with 285/55R22 Ridge Grapplers.
What suspension setup are you running?  These are the tires I want to run on my factory 22's I love the look of your truck.
Still need to get windows tinted. Tire is Nitto RG 275/60. Wheel is Hostile Typhoon. Also did 2” level
Edited by JSB81
On 7/1/2021 at 9:08 AM, Trev Towers said:
I do. It should be somewhere around 1” of poke over factory. Also added a picture of the clearance at full lock. I wasn’t interested in going any bigger than the stock tire sizing because I didn’t want to impact fuel economy too much with weight, overall I believe the new setup is just a touch lighter.
On 7/1/2021 at 12:06 PM, Trevor Towers said:
Here are some more pictures for you as well. I included an image of my city MPG in just normal driving to show I can still maintain essentially the same MPG I was getting before. All city driving.
Finally got mine on. Fit great and no rubbing. 2021 Denali w/ 275/60r20 toyo open country at3 CC3D9A48-B5CD-4A2C-8BCF-020A2ABD9AEE.thumb.jpeg.f6f6969a49a5d5259d86095cb4e937b1.jpeg
On 6/30/2021 at 10:29 AM, Trevor Towers said:
Used this forum to pick out my specific wheel and tire set up so I’m returning the favor!
20” Vossen HF6-4s 20x9.5- +15 offset.
275/60R20 Falken Wildpeak AT3W.
it has a 3” Superlift lift kit. The tire size is same as stock on the stock 20” OEM wheels. There is zero rubbing at full turn. This setup gives a similar look to a leveled AT4.
I just got my 19 Silverado back today and ended kinda disappointed. I did not gain 3 inches in the front and have a pretty noticeable rake still. Do you happen to have what your stock measurements were compared to the new measurements are?
On 4/15/2021 at 6:19 AM, GK Hill said:
Daylight photos to follow😜
Are these gloss titanium?  I wish they had 18" with 0 offset.  Looks great with the Satin Steel Metallic.
Yes they are. I thought the color blended well too. Thank you.
    250.3k
    BDS my HD
    BDS my HD
  • Who's Online   3 Members, 0 Anonymous, 607 Guests (See full list)
    • Hello hello looking forward to expanding my knowledge of the 2026 2500 HD that I just bought.   Truck has 3500 miles on it four-wheel-drive crew cab and I’m about to put a 6 1/2 inch BDS lift on it 18 x 10 -25 offset with 37’s   Already have the wheels and tires just waiting on the lift install in about three weeks   Question what surprises am I not gonna be happy with?  I’m not new to lifted trucks so I know that acceleration towing gas mileage all that is affected..   Question is those of you that have this truck this powertrain with a 10 speed Allison and have done the mods that I’m doing,,, how bad is it? Is that Allison constantly gonna be hunting for the right gear to go into? And what about towing, acceleration, fuel consumption as mentioned?    Lastly how come I can’t find any ring pinion gear set up for these axles and when could I expect to see them?   I apologize if there’s any typos I’m doing speech to text on my iPhone.
    • I've got a 2013 2500 6.0L Flexfuel. Drove the truck earlier today with no issues. Went to run an errand tonight and noticed key fob wouldn't work. Figured battery was dead, so replaced fob batter. Still wasn't working. Grabbed my other set of keys with the other fob and that one wasn't working either. So I manually unlock truck and insert key. Interior lights come on, dashboard lights up, turn key and truck starts. Turn truck off, like a moron, and try starting again. This time no crank, no click, no nothing. Lights still come on and dash lights up, but now I'm getting a service 4wheel drive, service tire monitor, etc. Check voltage on battery and Im showing 12.2v. Throw my battery charger on it and give it 15 mins and try starting again. But still no crank no start. Decide maybe its a bad battery, run to autozone grab a new one and put it in. Same issue. Disconnect battery and let it sit for 15 mins. Try again and still nothing. I had managed to roll the windows down earlier as its a humid night, but now I can't get them to roll up. Power locks are also not working now. Then randomly I try the key again, and it fires right up. Immediately I roll up the windows as we have nothing but rain forecast this week. I shut it back off wait 30 seconds and start up again. Worked a 2nd time. So turn it off, start putting things back together. Try one more time, and back to no crank no start. And now the car alarm starts going off. Had to disconnect battery and leave it that way for the night as I don't think my neighbors would appreciate my alarm going off again tonight. Any thoughts or help would be appreciated.
    • No one will care for you like you care for you. Do what you can for as long as you can. IMHO of course.
    • How about them NICKS!!!
    • Hi there.  Long time lurker, first post.    i have read the previous posts regarding the water ingress problem with this emblem.  I bought my 1500 SLT the  summer of 2025 new and after reading the MANY problems with these emblems failing I decided to install one anyways.  As per a YouTube video, I sealed ( or tried to) this sign with silicone sealant around the outer perimeter joint and the holes that were already somewhat sealed on the rear plate of the emblem.  And installed the connector assembly using dielectric grease on the connectors. The installation looked great and worked well for about 4 months……then FAILURE.  Grrrrrr…… I live in the great white north and wash my truck weekly in an automatic car wash  to keep the salt off.  Let me tell you that removing the old, failed emblem is a whole different animal than removing the OEM individual letters without removing the grill assembly. Mainly because the illuminated logo is built differently than the original letters which  you can remove the red surface lettering with a knife or some kind of blade which gives access to the tabs which hold the logo onto the grill. So I had to essentially destroyed the old emblem to remove it. Doing so killed my chance of doing somekind of autopsy on the failed , old logo.  But there was plenty of water inside when I ripped it apart.  Prior to installing the new assembly I tried it with the old harness and it works fine.   Does anyone have any insight as to where the water is getting into this emblem? I intend to seal the new logo with slow curing epoxy this time around using a syringe.  I think this newer emblem may be an updated unit which I hope GM got the vendor to fix. It has an October 2025 date on it.    If this one  fails,  I am just going to revert back to the non-illuminated letters….AFTER PULLING THE GRILL.    Any thoughts on sealing with epoxy would be appreciated. Thx!   Doug
