Transmission Service Questions
thatryan
I wouldn't run Amsoil in my lawnmower.
I have an 18 year old snapper lawnmower. Self propelled high wheel. I changed the oil and filter 3 times with Amsoil. Not smart I know. Still going no smoke. Now I’m curious about how long she’ll go.
  • Replies 48
Me too? :)
11 hours ago, thatryan said:
What am I missing, is amsoil bad for mowers or something?
There are certain individuals that just seem to have a hatred for AMSOIL and will do and say anything to discredit the products and the company.  AMSOIL has been the victim of this for many years now.
Me too? [emoji4]
It’s a mower I use for trimming and mowing in a fenced in area for the wife’s dogs. It even has the original plug and fuel filter. I recently gave it to my daughter. I usually end up mowing that lawn. 19 year old computer wiz grandson has trouble starting it. The mower deck is starting to get pin holes in the deck. It’s looking like the engine will outlast the mower.
  • 3 weeks later...
I stopped into an oil change shop yesterday, asked if they do a pan drop & change filter. He said it depends if the exhaust is in the way as they can't move it or jack up anything.
He gave me the number if a local mechanic, I asked about how you change more fluid than just what will come our with the drain, his response...
Start it & idle in park & you'll get most of the rest of the rest of the fluid pumped out to the pan.
What does anyone think of that, seems a bit iffy to me. Any problems with air locks in torque converter etc?
Sent using Tapatalk - 2014 5.3 WT
That’s what I’ve heard too. What fluid you going to use?
Sent from Above
That is TERRIBLE advice (to run the transmission until all the fluid comes out).  It's only slightly less bad than doing that with your engine to get all the oil out during an oil change.  Besides various bearings & bushings, there are also clutch packs and seals that depend on the fluid to keep them lubricated to work right.  Sure, it probably won't kill your transmission immediately, but it will shorten it's life...
Any shop that would suggest doing something like this, is a shop you never want to use or take further advice from.
If you absolutely have to swap all the fluid (even though the transmission lasts a nice long time with normal fluid changes from just doing a pan drop), find a place that will do a "flush", where they add new fluid as old fluid comes out (typically by inserting their machine inline with one of the transmission oil cooler lines).
Yeah, I didn't like the sound of it either. I want to change the filter so maybe I will look for a new pan with drain plug so I can do another couple of drain & fills in short succession.
I had one full change (flush through as you described) at a different oil change place at about 50,000 kms, I'm now at 110,000 kms.
if you cant handle doing a home brew trans flush, you might want to drill and tap the torque converter for 1/4" pipe plugs, this will drain 80% of the fluid
Is the updated Mobil 1 fluid brought out for the 8 speeds considered an upgrade over regular Dexron 6 for the six speeds?
No mention anywhere of that.  6-sp call for Dexron VI.  Mobil 1 Synthetic LV ATF HP is recommended for use in requiring DEXRON® HP ATF DEXRON®
No mention anywhere of that.  6-sp call for Dexron VI.  Mobil 1 Synthetic LV ATF HP is recommended for use in requiring DEXRON[emoji2400] HP ATF DEXRON[emoji2400]
Ok thanks. I have recently been getting some badly delayed shifts when getting on the gas & just wanting to put in there the best oil I can.
Thats probably "Torque Management" coming in.   If you want the best then use this.  Its in my Denali ..
Aisin-Warner AW-1; BMW 83 22 0 142 516, 83 22 2 152 426, 83 22 2 289 720 (ATF3+); Chrysler MOPAR* 68157995A, SP-IV; DSIH 6p805; Ford MERCON* LV, SP; GM DEXRON* HP, DEXRON* VI; Honda/Acura DW-1*, Type 3.0; Hyundai/Kia SP-IV, SPH-IV, SP-IV-RR, NWS-9638, SP4-M; JASO 1A-LV; JWS 3324; Mercedes Benz 236.12, 236.14, 236.15, 236.41; Mitsubishi SP-IV, ATF J3, ATF-PA; Nissan Matic-S, Matic-W; Saab 93 165 147; Shell M-1375.4, M-1375.5, M-1375.6, M-L 12108; Toyota WS; Volvo 31256774; VW/Audi G 055 005, G 055 162, G 060 162; ZF S671 090 255.
    • I have A 2020 1500 5.3 8 speed. LTZ. Transmission problems since 60,000 miles. Started when I go to store in morning to get my morning coffee before work leave truck running get back in put it in drive/ rev no movement step on gas a little slams into gear. Put in neutral step on gas little shake then put in gear and gose.  Shut truck off start .. ok now at stop light stop truck after a few seconds feel a little kick if that doesn’t happen stuck in 3/4 gear shut truck off wait few seconds and start usually ok again. If you down shift manually ok as long as you get into 1st before stop. If not it kicks . I WANT A NEW TRANSMISSION. Now I want a new truck it just hit 80,000 IDK IF ILL BUY CHEVY CAUSE THEY STILL HAVE THE PROBLEM AND REFUSE TO RECALL . Oh I’ve changed the fluid and filter 3 times now. And yes used mobile 1 not ac/delco cause it’s not meeting the requirements that mobile is did use ac/delco filter
    • Of course refrain from political debate but I myself have very dismal hope for what is all going on up here every where we turn so I nodded my head when I saw this joke.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
    • Got this yesterday out of nowhere. Truck is a 25',6.6 gasser with 8k miles.  Only semi anomaly is that the truck had been sitting, uncranked for 6 days. Elec Stability Control showed immediately upon cranking, not while driving. No drivability issues, just the message. Battery didn't seem to be weak when cranking over.  I drove it, killed it, let it sit a few hrs with no avail.  Truck is 100% stock. No damage.
