On ‎8‎/‎24‎/‎2018 at 5:23 PM, Slatemetal15 said:
On the 14-15 trucks, the hid’s will be on during the day because they are set as the drl’s. You can buy a drl harness that can eliminate it or switch the drl function to your fog lamps. I have the morimoto kit and have just left them as is. We’ll see what kind of life I get out of them. The lifespan will definitely be shortened though due to being switched on/off a lot more than neccessary.
What harness? Where can I get it? I would like to switch the DRL to Fog lights.
New to the thread. have been browsing through the comments and have found some good information.
I do have a few questions though.
1. I have a 2014 Silverado 1500 High Country, it has the factory projector lens for low beam, Is this an HID Projector lens? Can I just put in a HID kit and be fine?
2. If it is not HID Projector lens, has anyone had any luck with after market complete replacements? So I would not have to cut my OEM myself. I have specifically been looking for after market ones that look like the OEM. Specifically https://www.protuninglab.com/20chsi15253512.html  .
3. If I do end up having to buy just a HID Lens and mod my OEM what is the most recent census on the HID KITS out there? Since it has been a few years now are there any good reliable ones? If so where can I get it, and what parts are needed if not all parts are in the kit?
please and thank you everyone.
The best setup you can do on that truck is a new FXR projector with Hylux HID ballasts.Easy to do. Only small modification to the dust cap. Here is a link
https://www.fastheadlights.com/ProductDetails.asp?ProductCode=fxr%5Fchevy%5Fretrofit%2Dkit%5Fhylux
I would like to do a retrofit, but I don't feel comfortable cutting into my headlight housing.
No cutting into your headlight at all. The projector goes into the back and lines up using the retrofit brackets in the kit.
So no cutting any of the housing at all? I thought I had to?
On my Sierra with the Morimoto HID kit I turned off all light notifications for the door lock/unlock for unnecessary start/stop of the HID bulbs.
On 8/23/2018 at 10:16 PM, MegaCode360 said:
Yeah, the 14-15 LTZ/HC low beams are projectors.  They are not really HID projectors but the HID kits work fine in them.  Some swear by doing a retrofit with real HID projectors but I'm running HIDs in the stock projectors and it works great.  Would it be brighter with real HID projectors?  Maybe, probably.  But it's fine with the stock projectors and 100x brighter than with the halogen bulbs.
Glad to hear this. I want to get the kit for my halogen projectors but there were quite a few reviews out there saying that the brightness difference wasn’t worth it.
Yes you have to cut the back of the housing off.
It took me 7 hours and I bought everything from fast headlights.
It was a long day, but at just over $300, it’s been completely problem free and it’s one of the best things I’ve done to the truck.
i bought a d2s mini 4.0, hylux ballast 35w, and 5500k morimoto bulbs.
do it. One of those great long term mods you won’t regret
I would alot about 3 to 4 hours to do it. Of course this will vary based on how quickly you get the headlights removed and the tools used to cur open the plastic cap on the back. All in all it is pretty straight forward and simple to do.
Here is a 12 part video series showing the process of installing a Morimoto D2S 4.0 projector retrofit kit in the GMC Sierra.
Part 1: Opening the kit
[/url]
Part 2: Parts and materials needed
Part 3: Setting up the projector
Part 4: Modify dust cap
Part 5: Cut lines on the back
Part 6: Cutting thr back
Part 7: Removing the OEM projector
Part 8: Install Morimoto D2S 4.0
Part 9: Wiring the bixenon shutter
Part 10: Hooking up the ballast input
Part 11: Connecting your Hylux ballast
Part 12: Sealing the back
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
