I'll join this club...
My '14 GMC Sierra SLT AT CCRB 4x4 5.3 with nearly 24k miles vibrates. I bought it at 17k miles, certified pre-owned and never noticed any bad vibrations until my trip to Pittsburgh with my family.
With 3 adults in the truck the vibration at 75mph was horrible! Adding a 4th person made the vibration smooth out a touch. Needless to say I did not cruise at 75mph out there and back.
In the last 2 weeks it's developed a vibration/binding/moaning noise from the transmission to rear-end area under med-hard acceleration, while rolling or a stand still. The same day I noticed this, it sounded like something in rear-end was grinding while backing up out of a driveway.
Dealer can't get me in till the 13th of October... I guess I'll get the run around then.
EDIT: The MPG have fallen about 1-2MPG on average since that trip. I usually average around 17.5-18MPG to work and back all week, now I fight to get 16-16.5MPG. Maybe it's related to the issue? Idk.
Edited by MThompsonjr115
General reference information from http://www.discounttire.com/dtcs/infoTireBalancing.dos
{Snip from above}
Other Sources of Vibration
Very often the wheel/tire assemblies on a vehicle may be in balance but you can still feel a vibration. Here are some of the other causes of vibration:
  • Bent wheel
  • Tire out of round (radial or lateral runout)
  • Wheel-to-axle mounting error
  • Inconsistent tire sidewall stiffness (force variation)
  • Brake component wear or failure
  • Drive train or engine component wear or failure
  • Suspension wear or failure
  • Wheel bearing wear or failure
  • Wheel alignment is out
Your tire dealer can isolate many of these problems for you, and there is no question that determining whether the tire/wheel assemblies are good and in balance is the first place to start. However, ultimately this may not be the source of your vibration problem.
Hello all,
I am here to relate to all of the vibration issues that we are having with our trucks. Two weeks ago I bought a 2014 RCSB 5.3L Silverado. I bought the truck brand new with 8 miles on it. When I was driving home on the freeway I noticed the cab vibration when I approached 60 mph and we'll onto 75mph. Being that I was coming from a 2004 sierra with 100k miles that drove way smoother I knew this wasn't right.
I now have 650 miles on the truck and have been driving it to see if it would get better...it's not and it's getting worse. the cab shake is so bad and there is a faint drone noise that gives me a headache and oddly hurts my teeth when I travel at freeway speeds. I have a 5 mile freeway commute to work and am totally beat up when I get there.
Last week I went to the dealer and explained my issue. Service manager clearly was lying when he said "wow I have never heard of that problem" . This is a very high volume dealer also. I have an appt for next week to have the truck checked out. It very clear after reading all the complaints there is no fix for this as of yet and not really sure I want my truck torn into just to have the problem still be there or get worse by what some of you have wrote.
On a side note I have done a little troubleshooting by swapping wheels with a buddy who has a 2011 silverado that drives perfect. He has aftermarket 22" wheels so that's what I put on. We'll yep problem with my truck still exist even with his 22's so a out of balance tire or wheel is ruled out.
I have been a dedicated chevy owner for the last 20 years of my driving experiance. I even own a 1963 chevy c10 that my grandfather bought new...it also drives smoother at freeway speeds than my new 2014. I'm very disappointed in chevy about not figuring this out yet. I can almost not drive my truck anymore due to pain it causes me. If they can't fix it this will for sure be my last chevrolet. I'm total floored a 2014 chevy truck can be so shaken and vibrate that it causes pain in my teeth.
I also have spoken to two other 2014 silverado owners who one says his as been at the dealer many times for this issue and still not fixed and another that is ready to off his ASAP.
Just wanted to share my experiance on this bad deal with all of you as we all are suffering with our expensive trucks that drive like a worn out roller coaster.
TRUCK of the year!!!! What a joke...
Cheers
Hello all,
Cheers
Here is a link to another thread. Disregard the first page after the original persons (posters) comment.
http://www.gm-trucks.com/forums/topic/156181-2014-sierra-vibration-at-highway-speeds/
Edited by 15LTZZ71
You know the sad part of this whole thing is I got my 2014 in January and they had the problem then but rather than stop production and fix the problem they just kept on producing bad trucks! I mean come on, someone should step-up and say enough is enough and make them pay for all the junk they are producing! Know wounder the recall list is over 3 million and still growing.
You know the sad part of this whole thing is I got my 2014 in January and they had the problem then but rather than stop production and fix the problem they just kept on producing bad trucks! I mean come on, someone should step-up and say enough is enough and make them pay for all the junk they are producing! No wonder the recall list is over 3 million and still growing.
No, not 3 million, 30 million.
Not 3 million, but 30 million.
Could you image if ford, ram, nissan, or toyota started exploiting this in a commercial. Unlike the ________ our trucks don't vibrate or shake and in the event that they do, we don't call it normal!!
Edited by 15LTZZ71
For what it's worth both ford and ram have had the same problem in the past. Not nearly as widespread as this GM problem but google _____ vibration and you'll see others from competitors with the same problem.
I feel terrible for y'all with the issue. I've test driven three Silverados. One had a real bad 70+ vibration, one a mild 40-50 vibe and the other didn't vibrate. I honestly think this issue is more widespread than the 20-25% reported on the forums. I hope they get this figured out in the future and get y'all fixed or bought back. It's really shocking how many people have this problem. The worst part is GM not standing by their product and taking a piss at loyal customers.
Can somebody start a Poll thread on who's truck vibrates and who's don't. I would but I'm not sure how to.
Yeah, they would probably like to mock GM a little over this but are probably afraid of the possiblity of repercussions some time down the road.
Just go to the forum you want.
Click start a new topic.
Then manage topic poll on the right.
I'm trying to post the poll as a new topic in this section ( not in this thread ) but I'm having trouble posting it.
If you do a poll remember that some people have a vibration but don't have a shake. My truck has a horrible vibration in my floorboards and accelerator pedal almost all the time but I only have the shake for about the first 1/2 to 1 mile after sitting for awhile and then it goes away. Just a thought, it's your poll do it the way you want though.
Edit: if you are unsuccessful PM me and I will attempt to setup a poll thread tomorrow.
Edited by 15LTZZ71
I was interested in picking up a 2014 Silverado 1LT Z71/LT Plus Pkg with the 5.3L until I came across this forum and now I don't think that would be a wise choice; due to the incentives & rebates I can pick up a 2014 in the mid 30's. Is this vibration/skaking/moaning something I would notice right off the bat if I did choose to test drive?
Are some models/rims/gear setups more apt to having this problem?
From what the window sticker shows the final assembly of this Silverado was in Mexico, not sure if this has anything to do with it?
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
    • My initial introduction was here.  It's hard to believe that I last posted in February 2013, having just deployed to Kyrgyzstan.  Since then, I've retired from the military and the 2006 Sierra SLT Z71 that first brought me to these pages was lost.  I went forward to Afghanistan in March 2013 and did a lot of sitting behind a computer on brigade staff.  Within 18 months of getting back to the States, I was selected for Drill Sergeant duty, after which I moved back to Virginia (my home state and where I served from 2004-2008).  That '06 Sierra did a lot of driving between Louisiana, Georgia, and Virginia, and ended up with nearly 320k miles by 2022.  By then, the registration had been expired for a couple of years, but the pandemic had all but eliminated tickets for such transgressions.  Admittedly too, I usually drove my wife's SUV or son's car the 2-3 times a week I had to report to work.  Teleworking sure was fun while it lasted.   I started my retirement leave four years ago and stored the Sierra at my sister's house.  A big mess was made when her fiancé passed while she was taking care of business out-of-state in late-2024, and his son pretty much mismanaged everything to do with the estate.  Even so, I was assured that my truck was safe... until it wasn't.  I found out that my truck had been scrapped about four months after the son took over everything.  There's nothing I could do; I'm 1000 miles away and it was technically abandoned property since he'd even trespassed my sister from her own house (she had no claim to it as she wasn't married, and the fiancé was the sole owner).     Anyway, today I got my second Sierra.  This is a 2010 SLE 2WB CCSB with a little over 200k miles on it.  It's got the 5.3L I'm familiar with and should handle what I need it for.  Hauling stuff that won't fit in the Transit Connect (yep, I sold out, but that's the wife's vehicle) and towing a few times a year tops.  The price seemed decent, considering how much people sell their trucks for in the Deep South: $4500.  I've seen similar trucks listed for more than double that.  I got it from a coworker who left his tag on until we transfer the title next week (Louisiana requires a notary for transfers), so I've been driving it all day.  The rear speakers don't work, which is one of the things that brought me back to these forums earlier.  I can't say how active I'll be as a poster, but I'll be scouring the archives while I find out every little thing I can about the 2010s and particular nuances/problems with my truck.   It's definitely not a GMC, but I got another Willys Jeep a few months back as well, so I'm almost at the same place I was when I first joined gm-trucks.com.  My old 1960 DJ3A was sold back around 2010 or 2011; my current Jeep is a 1946 CJ2A.  So, I've got a slightly newer GMC and a much older Jeep.  I kind of wish I still had that F-250 I had way back when too.  The Dakota is long gone and was technically my brother's truck, though I had it registered and insured.  The F-250 had to go when my grandmother's house was foreclosed on due to mismanagement around 2012 or so.     Hopefully anyone that made it this far isn't too annoyed.  I tend to be long-winded, but I'll be doing more reading than posting in the coming months.
