Sarasota
2015 Denali 3500 DRW, Michelin ltx, 4x4
Thanks,
I was wondering which dealer was it you were dealing with.
Edited by pm26
Thanks,
Ah, sorry. Palm GMC in Punta Gorta.
Saddly I have now developed the dreaded vibration that starts at exactly 20 mph and stops exactly at 30 mph . Doesn't vibrate at any other speed very strange . You can feel it in the steering wheel and gas peddle also a little on the floor Board . It feels like your on a pebbled street or rumble strip . Anyway I will be taking it in for service in the near future . Love this truck but the vibration is very annoying . Didnt really notice it for a while but now that I have I don't enjoy my truck as much . Freeway speeds are smooth but city driving is when I'm in and out of the vibrating mph . Accelerating you don't feel it but steady speed anywhere between 20 and 30 mph or stopping for a light it does it . Hope they have a fix : (
Ok, so this coming Monday will mark the 4th consecutive week that my brand new truck will have been in the service department. If they do not call this week, does that mean that I am eligible for the lemon law in the state of Tennessee? I heard somewhere that 30 days is the mark.
Are they gold plating it?
The dealership rebalanced my Goodyear SR-A tires 29 days since the last time they did it, at which time they replaced one that would not force balance below 15lbs. Well, they said they matched balanced one that was off, and the other three were only generating 4-6lbs of force. Now the truck vibrates more.
Time to go find a good tire shop...
Maybe it is time to trade for a vibrating 2016 model? Are they out yet?
As I said several times before, road force variation, even if zero, does not guarantee good wheel balance. Proper wheel balancing does. So once again, measuring road force variation and correcting wheel imbalance are two different parameters. Hunter 9700 wheel balancer, first measures the road force variation (if that option is selected by the operator), then wheel imbalance. If the road force variation is excessive, the machine will flag it. Low force variation means the tire is very little out of round. It does not mean the wheel is properly balanced. If the machine is improperly calibrated or the wheel is incorrectly mounted, chances are they balanced the wheels wrong. Way wrong. Possibly they all are out by as much as 1 ounce. This will cause very unpleasant vibration at high speeds. I have seen this before. More than once.
Perhaps the main reason for a bad balancing job is selection of an improper size cone to center the wheel on the machine. If you use a cone that is too large and catches on the outer lip of the center hole, the wheel will not be properly centered. A combination of a proper fitting spring loaded cone on the inside of the wheel and a good quality wheel lug adapter on the outside of the wheel is the best way to mount a wheel on the machine.
Edited by pm26
Or maybe it's not a tire issue....
It vibrated after I first got it. They replaced a tire and forced balanced all 4. It no longer vibrated. Then a slight vibration came back around 55mph. They checked all four and messed with one. Now its worse than when it went in the day before.
So either we have a heck of a coincidence on something else coming into play, or they didn't do it right. My money is on the later based on the experience so far. Worst case scenario is I dump these crap Goodyears for Michelins and then rule out tires.
As you said, time to find a competent tire shop.
Hi reporting to what I believe is the correct thread for my issue:
From what I'm reading there is not much of a solution for the vibration problem. I have 2014 6.2l with the max trailering package as I tow a 8000lb toy hauler. Truck tows great but the vibration when towing is getting worse. I'm not sure if this is the same problem as mentioned in this thread but as you can imagine when towing you put a big load on the truck - this is making the vibration bad.
I've already brought the truck in three times to fix problems and with only 6000 miles on it I'm disappointed to have to bring it in another time.
Has anyone looked at the transfer case? Driving along @60-65mph on a newly paved concrete tollway, going straight, I put the truck into 4 wheel drive "Auto" mode. The rumble strip vibration I have been struggling with suddenly gets much worse. When I disengage the 4 wheel "Auto" back to 2 wheel "Hi", after several miles it seems to dissipate back to a slight rumble strip vibration (felt in the steering wheel and pedal and slightly in the seat) especially at 40-50 mph.
Perhaps something in the front drive line is the source... Putting in 4 wheel "Hi" also has the same affect.. and I am going completely straight forward.
As soon as i took those shitty azz tires off my truck its been smooth as can be. Ive got 12k on it and still ridin smooth. The other day i was coming home from BPS and i decided to take the highway to see if my vibration had came back... Nope, smooth all the way to 85. I'm not saying tires will fix everyones trucks, but im sure glad i didnt screw with the dealer on my 2nd go round
    • I agree. That`s a LOT of sludge for 12,000 miles. I tossed that out here since this is an OCI thread. There`s tons of people here that do not post.   I used to work on a city fleet. That includes police cars and fire trucks. Lesson is, not to only use the odo for oci. A police car has a ton of hours on the engine for the miles it shows. And, not just idling, directing traffic. They beat on these things.   Course, since it is a Kia, they were gonna use the "100,000 mile warranty" for their OCI.😉
    • CLASS ACTION SUITS?  Does anyone know if there is already a class action suit for the paint - which was to have been fixed, changed in after the 2020 GM vehicles?  Does it look like this?    Just started 3 weeks ago - No help from GM as of yet - Dealer will not assist in speaking with GM on my behalf. Confirmed it is the paint they use along with the way the put it on that causes it to fail.  Clearly a Manufacturer's Defect.
    • That dog don't hunt. 😏   First, a 2025 with 12K on the clock AND idled for a year nonstop is false on it's face; this is 2026. You can do one or the other but not both.    Second, ENGINE HOURS are absolutely available. The rest is third grade math. Micky Mouse scanner he got out of a box of Cracker Jacks OR an ID10T error.    Third, if they ran it out of oil "Several times" that motor is boned on the first hit.    Does this guy think piling higher makes it stink less?
    • That's interesting, I assume that would add to the cost of the oil but also I was forgetting to bring up the issue of the low tension rings allowing more oil past which in turn forces the cats to have more oil additives pass through them that wouldn't otherwise so they are creating that problem and of course its all in the name of fuel economy. Mind you the other issue would be the lack of additives that fight the formation of carbon within the piston ring grooves which turn the engine into an oil burner and with in this GM forums case is your average off the shelf Dexos licensed oil, meanwhile the other off the shelf oil being Valvoline's R&P isn't licensed and the only one that is which is that certain Mobil oil that came out recently ( its not even being marketed in Canada ) and only a fraction of vehicle owners are going to be using it out of all the other oils on the shelf or the quickie lube bay that meet the Dexos spec by way of actual licensing.    Also I suspect that its an easy excuse to pool the non turbo DI engines in with the turbo DI engines and design the oil to not have LSPI issues in the most demanding engines and short change the naturally aspirated DI by not offering a higher concentration of additive package they could handle and still not be at risk of LSPI.    I wonder if Amsoil flipped the switch just lately and did whatever packaging designation at the same time as I wonder what oil formulation I would have bought in May, of course I don't know when it was packaged at the factory vs how long it was in storage at the Edmonton warehouse. I know its been said at least in the past that the big players switch over to a reformulated oil but the packaging has not changed until they make that move as well so there is that cross over time where its a new formulation in a predated formula marked package.
    • Hmm. A real reason to not just use the odometer to determine OCI?
