Are you saying your 22s are 100lbs each with or without tires mounted....???? If without, I'm curious what my wheel weighs thus what my total wheel/tire weight is for myself....
I dropped my truck off on Monday with a different dealer about an hour from me. They went through all the tires/wheels and checked alignment and found nothing out of whack. They called me and said everything seemed normal and with in spec to them. They didn't drive the vehicle so I asked them to do test drives before I come pick it up.
They called me Tuesday afternoon and said they wasn't able to drive it but they did go ahead and remove the drive shaft and verified it was balanced properly. It tested "well within spec". I asked why they didn't test drive and was told they didn't need to as they could test it better in the shop than on the poor roads around them.
I decided not to push any more. I picked the truck up Wed. morning and drove it 2 blocks down the road and traded it for a 2016 F-150 Platinum. I can't remember ever being so happy with a purchase decision. After owning about a dozen GM vehicles I/nor my kids will ever own another one, never.
  • Like 7
Welcome to the Club my friend. Instead of a Platinum I went for a Fully Loaded Lariat with virtually every package available, you'll enjoy it! post a pic of her
After having the steering bushings replaced with "newly engineered" ones and a u joint replaced I'm happy to report that I don't feel vibration from 70-80mph any more. Only problem now is my steering wheel cocked to the right a few degrees... I guess I can live with that for now, beats shaking down the road all day
Could you please post what was on the work order? Part numbers replaced? Was a service bulletin referenced? Thanks!!! Any information helps us work towards getting our trucks fixed.
I'm not sure about the new GM trucks, but my S10 had a self aligning steering column. As long as the alignment was straight, it would center itself over time.
No service bulletin but here is the part number for the bushings 84097717
After two days of driving I'm still pleased with the result. I still think these stock tires a junk and now that there has been some resolution to my problem I can now focus on upgrading. Looking at Cooper AT3 at the moment.
Thanks!!! Can anyone dig up what this looks like and how hard it is to replace? All I can find is it's $32 online.
Schmidt152, for others and myself, what were the vibrations that you were feeling?
I've had my 2015 CCSB, 4x4, 5.3 LTZ for three weeks and it turned into a vibrator yesterday. Only had 5200 miles on it when I bought it.
It went from the smoothest vehicle I have ever owned to a vibrating mess. About a week ago I started feeling vibrations in the gas pedal. Nothing major just a minor annoyance. I get back from Nashville last night and drive it home from the airport and I started noticing a side to side vibration in the steering wheel at speeds between 65 and 75. It got worse at higher speeds.
I drove it on a 40 mile round trip today and it was worse. I've driven that same route numerous times and never had an issues. So I know it isn't the road.
I have an appointment Thursday at the dealership to have it looked at. Fingers crossed.
Vibration in the steering wheel plus vibration in the seats and console as well. Steering wheel was the worse BUT hold your horse because GUESS WHAT? ITSSSSS BACKKKKK! Truck was smooth as glass when I got it back and now it's the same as it was. Well maybe slightly better... but still that damn thing still shakes. And I get it, it's a truck and it's not suppose to ride like a Cadillac but vibration is far different from a stiff truck suspension. RT I know what you're going to say, and I agree. My beef is that I want this done on GM's dime and I want answers from GM. But this is BEYOND ridiculous! My dealer has been great to work with. They've gone as far as picking up my truck from home and leaving me a loaner (That's service!). What is killing me is GM and their mechanics and engineers attention to detail. My steering wheel is now crooked to the right and when I dropped it off it wasnt. That's a simple fix so just @$&!ing do it. I gave them a list of all the items people complained about and none of them checked to my knowledge. Just a "bad U joint and newly engineered bushings" B$!!s&$&.. This rant is far from over GM but that's all the time I have for now
    • These show the problem and symptoms, and I explain things too. to clarify again, I did not change over any computers or wiring (with the exception of the map sensor). All of the computers and wiring are original to the 2010 vehicle   video 1 - background info/explanation and part of the problem   video 2, idle misfire   I think the reason that the MAP sensor is reading High is because the engine is misfiring so there is less vacuum...   Additionally there's a p0102 for the MAF low frequency, and a p0108 for the map high voltage.        Again, apologies for the somewhat long-winded explanation, it's a rather difficult problem to explain without going into the details.
    • You'd want the Pulsar to be safe.  That was the first product that worked for 10 speed trucks that they came out with.   Range Technology 22451 Pulsar LT for 2019-2022 GM Gas Trucks     That said, in the features description of the RA003B, it does list it working with 10 speeds.  However there are reports that the RA003B can cause some drivability issues on early 10 speeds.  So the Pulsar is the safest move IMO.      Range Technology RA003B AFM/DFM Disabler   Features: Range AFM/DFM Disabler keeps you in full power 100% of the time Simply plug into your onboard OBD-II port and it instantly begins working to eliminate the AFM system Disables Auto Start/Stop Blue LEDs The Range AFM/DFM Disabler does not reprogram factory ECU Works in hundreds of applications, 2007-2022, including 10-speed models. Leaves no trace, unplug it to return to factory settings Virtually no battery draw Fits all V6 and V8 General Motors (GM) active or dynamic fuel management vehicles, includes cars, trucks, and SUVs This device does not support the 2022.5+ Refresh model trucks or 2021+ SUVs To confirm your 2022 model truck is compatible with this unit, check your VIN. The 12th digit in an early model must be a '4' or lower Made in USA
    • I have a 2019 new body style high country with a 6.2l L87 and a 10 speed transmission code MQB. Looking for a disabler that is compatible. Most show it’s not. I watched a video on utube from Dons Life that says Ranges RA003B is compatible but when you go to Ranges website and check compatibility it only has a 8L90 trans listed which is an 8 speed.  I don’t want to buy the wrong one. Anyone have any experience with this situation?
    • This actually happened. Be careful where you get your information re: gas price trends.
    • I understand the principle...you don't want to spend $150 for a $0.02 piece of plastic or a little screw and perch thingy.   But this is a problem that looks like it can be reliably solved with a zip tie.   That might hold you over until you can score one at a pick-a-parts yard.
