RHStansbury Posted June 7, 2016 Posted June 7, 2016 Total typo on my side...meant to say 325/50/r22 - not 55. The point I was trying to make was that they are definitely 35's. Maybe the buyers just drive them in straight lines???
jrob56 Posted June 7, 2016 Posted June 7, 2016 (edited) It's 325/50r22 it says it and also the picture of the tire shows it. Also anyone can fit these under their truck but enjoy all the rubbing it will cause. Sent from my SAMSUNG-SM-G930A using Tapatalk Whoa now 325/50/22 is a 34.8 inch tire which is bigger than I think most of us though would fit with a level without rubbing? Edited June 7, 2016 by jrob56
kylercochran361 Posted June 7, 2016 Posted June 7, 2016 Total typo on my side...meant to say 325/50/r22 - not 55. The point I was trying to make was that they are definitely 35's. Maybe the buyers just drive them in straight lines??? Lmfao exactly! Just like people that ask to put levels on their trucks but think it won't alter their trucks life or performance. Of course it will but it's something you are taking a hit on for the drive Sent from my SAMSUNG-SM-G930A using Tapatalk
techsan15 Posted June 7, 2016 Posted June 7, 2016 (edited) Good looking truck. What size tires? I have a 2.5" level on the front and stock block in the back. Measuring from the ground to the center of the fender, I'm 1" high in the front. So my thought is by adding the 1-3/4" block in the rear, it will put me close to dead level. How does your truck measure out with the rear block? Thanks, and its just the stock 275/55/20s. I will try and get some measurements for you. It is the bottom and top spacer on the front with the 2" block in the back. Edited June 7, 2016 by techsan15
16silvdriver Posted June 8, 2016 Posted June 8, 2016 (edited) If i have an ltz can i put rear blocks in with my level or no because of the air ride shocks? Edited June 9, 2016 by 16silvdriver 1
16silvdriver Posted June 9, 2016 Posted June 9, 2016 Also anybody have any input on the street rays ebay leveling kit? Super cheap and seems the same as any lower strut kit
amxguy1970 Posted June 9, 2016 Posted June 9, 2016 If i have an ltz can i put rear blocks in with my level or no because of the air ride shocks? There air no air shocks, those are for the SUV's. If you bought it used and it has air bags out back then I am not sure, would have to check with the manufacturer of those bags. If it is stock, you can take out the stock rear block that is 1.25" and add a 2" block if you want. Tyler
BoomBoom19 Posted June 9, 2016 Posted June 9, 2016 Not sure where you saw that listed. Under "Aftermarket Options" they have them listed as 325/50/r22 which would be 34.8 " x 12.8". In other listings they've also mentioned that if the buyer prefers 20 inch rims, they'll come equipped with 35x12.50s. Regardless, I am in love with these trucks. When I did the conversion I did it as a 20" tire so typo on my part. But yeah, I highly doubt those fit.
mmwest Posted June 19, 2016 Posted June 19, 2016 (edited) Does anyone have any suggestions on why I'm having a lot of bounce when towing my boat. I'm guessing it has something to do with my newly installed rear 2" block. Thanks Edited June 19, 2016 by mmwest
Smoothyrogers Posted June 19, 2016 Posted June 19, 2016 3.5" kit with UCA's. Left rear untouched. Looks taller up front cause it's on uneven ground. 20x10 -18 offset Fuel turbo wheels 285/50 cooper zeon ltz. Rides real smooth. I had 305/55 on it but it rubbed too much on back of fender.
tanner709 Posted June 19, 2016 Posted June 19, 2016 3.5" kit with UCA's. Left rear untouched. Looks taller up front cause it's on uneven ground. 20x10 -18 offset Fuel turbo wheels 285/50 cooper zeon ltz. Rides real smooth. I had 305/55 on it but it rubbed too much on back of fender. looks good, which 3.5" kit, Rough country? how does it ride
Smoothyrogers Posted June 19, 2016 Posted June 19, 2016 looks good, which 3.5" kit, Rough country? how does it ride Thanks. Just ebay spacers and I locally sourced some Rough Country UCA's. It rides like it just left the dealer.
Jeff5347 Posted June 20, 2016 Posted June 20, 2016 Thanks. Just ebay spacers and I locally sourced some Rough Country UCA's. It rides like it just left the dealer. Do you have an on the uca's. I looked on their site but only had up to 2013 can't find for 2014+. I have a 3 inch and curious on the arms. With your 3.5 level/lift did you drop the transfer case? Sent from my Nexus 6P using Tapatalk
Smoothyrogers Posted June 20, 2016 Posted June 20, 2016 Do you have an on the uca's. I looked on their site but only had up to 2013 can't find for 2014+. I have a 3 inch and curious on the arms. With your 3.5 level/lift did you drop the transfer case? Sent from my Nexus 6P using Tapatalk Mine are 13's. My buddy owns a shop and he made them fit on my truck. The balljoint angle came out perfect.
Jeff5347 Posted June 20, 2016 Posted June 20, 2016 Mine are 13's. My buddy owns a shop and he made them fit on my truck. The balljoint angle came out perfect.Was it a pita to fit. I have a shop I can use. Any grinding or drilling? Sent from my Nexus 6P using Tapatalk
