How would I add a couple inches to my 2005 silverado Z71 with a 6 inch
  • Replies 103
Would a 3 inch body look good on my 6 inch lift eith 35s? I gotta keep my tires and wheels there brand new and ill check to see when I get home exactly how tall the subframe is
Yes, it looks fine. Think about it. The difference in the amount of wheel well that is filled between a 35 and a 37 is only an inch. Just check out Blackout's rig. Plus with the 35s, you wont have to trim. 37s may require some trimming.
Iv got 12.5 wide on mine. I have an 05 with the older body style. I don't want to add the running boards do you think itll still look fine without them and more of the body showing? My body looks really good I just repainted it and the wheel wells flat black primer
It will look fine. When combined with a suspension lift the extra frame hanging doesnt really look out of place to me. Its when a body lift is used by itself that it looks odd and needs to be covered.
That being said, i would suggest some sort of step to help get in with that much lift.
Just my opinion though.
This
How is it only an inch? I know at 40 psi, my 35x12.5r17 measure a little over 34" with the weight of the truck on them. You would figure a 37" would be at least 36" with similar pressure and weight? Tell me if I'm wrong, because then that means I could go 38's haha
Thanks ill put a vody lift on at some point but I just dont have the time right now. I appreciate the offer. Rdnckhntr because half the wheel height goes into the finder because the axle splits it.
Yes but since its split into two sides that gives you an inch on each side unless that's what he was talking about which Im assuming it is. Just didn't think it through very well haha
Appreciate the cheaper link. I'll do that soon. I jacked up one side of my truck 3 inches more and man that will be awful high. Are you sure this is something a rookie could do? Iv got a jack its kinda old but still works fine. Iv got some basic tools and my brother would help out. What all will I have to do? I mean how do you get a block Iinbetween the body and frame?
I was in the same boat as you. I already had my lift and 35's installed and then wanted to go higher. Your gonna need a couple blocks of 6x6's and then I stuck a bottle jack on my rear tire, one side at a time, to lift the bed. I did it by myself in about 8 hours, maybe a helping hand here or there, but all in all I almost got it done alone. Not as bad as you think. Then again, I am no rookie at working on this truck. Ive had it sitting on jackstands with everything basically torn out of it at once, from the entire suspension, to the tranny and engine. It all got back together, you just gotta take your time so you don't mess anything up.
They give you very good instructions with the kit, barely any thought has to go into it. Just need to know how turn some wrenches and be willing to get a little dirty, that's all
    • Are you playing Slide Down endlessly but your score is still low? Are you constantly crashing into obstacles as the game speed increases? Don't worry, this article will share 5 invaluable tips to help you master the race and impress your friends. Golden Rules 1. Look one step further. The mistake of 90% of new players is only staring at their character. The secret of experts is to look towards the top of the screen (where the slide is about to appear). This gives your brain an extra 0.5 - 1 second to process the situation and determine the direction of movement before the obstacle approaches. 2. Use gentle movements; don't swipe too hard. Slide Down is very sensitive. Moving your finger too forcefully or with excessive amplitude will cause your character to be thrown off course or crash into a wall. Practise moving your finger with small, decisive, and precise movements. 3. Don't be greedy for gold in dangerous locations. Gold coins are tempting for buying skins, but life is more important. If you see a gold coin right on the edge of a cliff or next to a spike trap, ignore it. Our goal is a High Score, and your score only increases if you survive. 4. Make the most of Power-ups. During the slide, you'll encounter items like Magnets (attract gold) or Shields (temporary invincibility). Never miss them! Especially the Shield, it's your "get out of jail free card" to help you get through those deadly fast sections. 5. Stay calm when speed peaks. When your score exceeds 500 or 1000, the game speed will be very fast. At this point, don't try to think logically; let your natural reflexes work. Take deep breaths and don't panic. Apply these 5 tips to your next game, and your leaderboard will surely improve dramatically. Good luck climbing the Slide Down leaderboard!
    • If you use compressed air regularly, one problem you cannot ignore is moisture. Water in the air line can cause rust, unstable air pressure, poor tool performance, and even damage to sensitive equipment. That is why I highly recommend using a desiccant air dryer. A desiccant air dryer is designed to remove moisture from compressed air by using drying materials such as activated alumina or molecular sieve. Compared with basic water separators, it can achieve much lower dew points, making it especially useful for applications that require dry and stable air. For workshops, painting systems, pneumatic tools, CNC machines, laser cutting equipment, and industrial production lines, a desiccant air dryer can make a big difference. It helps protect equipment, improve air quality, reduce maintenance costs, and extend the service life of the whole compressed air system. Another advantage is reliability. Many desiccant air dryers are built for continuous operation and can maintain stable drying performance even in demanding environments. For users who care about long-term efficiency and equipment protection, this is a smart investment. When choosing a desiccant air dryer, I suggest paying attention to air flow capacity, working pressure, dew point performance, regeneration method, and maintenance requirements. A good model should match your compressor system and actual air consumption. Overall, if moisture is causing problems in your compressed air system, a desiccant air dryer is definitely worth considering. It is practical, efficient, and highly useful for anyone who needs clean, dry, and reliable compressed air.
    • My brand new 2007 Silverado's wax frame was rust from end to end partway through it's SECOND winter here in MA. That stuff is completely useless.
    • I went another direction after losing a trailer tire, thanks to not being able to access air at ANY of the 5 gas stations and garages I stopped at prior, with a Toyota Tacoma onboard, 50 miles from the Canadian border. They were either out of order, access was blocked, or the hose a few feet too short and I couldn't get any closer without risking damage to someone's property.   https://postimg.cc/gallery/X5QJ55w
    • I took a 12 second video on my iphone but the file is too big to upload. I will have to figure out how to extract the audio or just do another start with an audio recording.
