Installed 2.5 front king coilovers, dirt king Uniball upper control arms, dirt king locking cams and heavy duty bolts, king 2.5 rear reservoir shocks with compression adjusters and extended travel. Wheels are venomrex VR602 17x9 -12 wrapped in 285/70/17 ko2's
A24A383A-8F38-437A-8DE1-C65C460C16E5.tiff 3C10F237-88EF-43ED-AE6D-80496858CC22.tiff E5378A01-8DE8-4853-BCD2-B5CEAF4DF177.tiff
Realized when I posted this the pics were attachments instead of embedded. Oops. 8d56e1c16a2cc5c98144767ccbbc6a0a.tif26a200bd33444f3550a2eee738219633.tif3d6d2a960b8ec584ef9a5e508d5a82eb.tif
  • Like 4
Florida just went to a higher level of stay home, so I figured it was time to put the Bilstein 5100s in my truck that I bought a year ago.
Getting them into my 2014 was tricky, but I used 1 compressor to shorten it just enough to let the lower mount clear the LCA.
Fast forward to now, with my '17 and stamped UCAs. Damn, my old cheat doesn't work!
Fought and struggled with it all day then decided to pack it in and start again tomorrow.
Then it hits me.
All that damn time I was trying to get my old trick to work to reinstall.
All I need to do is disconnect the steering linkage and drop the nut from the upper ball joint. Connect the strut assembly, and then push the whole thing up with the jack and reinstall the linkage and the ball joint nut.
Sent from my SM-J810F using Tapatalk
Just finished up the intellectual property patent on these so I can post now. Took me a little time and my homies help with CAD but here is a one of set off face plates for the McGaughys lift traction bars and compression struts. Beveled with 45s to match the drop member face plate. Pretty juiced to see these cut in bulk next week!
  • Like 5
Added the keypad today. It’s def a feature I missed from my f150. I’ll use it a lot
locks - unlocks and rolls down the windows
also lights up at night when pressed
Edited by Sean006
  • Like 8
This week I installed a new set of steps and color matched a used go rhino bumper I picked up on the cheap.   I’m happy with the results.
  • Like 4
What else you got up your sleeve? Those are show/sema worthy.
#yougotskills, #killerparts
Appreciate it brother but it ain’t that big of a thing. Haha But hopefully a cool little accent to bring cemetery between the polish & copper in the wheels and these polished to the copper traction bars on the lift kit.
Had to get out of the house today. Stopped and snapped a few shots.
ba597be328e8e55612c59b8ae37c4e90.plist
e820db300c7944bce39ff718c970ab0c.plist
1392b8ebdfed5900c77b510e12ff6184.plist
The wife’s ride
  • Like 9
  • Thanks 2
Did some light offroading and got a feel for the new suspension set up. Now just have to wait for our governor to reopen the sand dunes!
251732f1f38c5c5de8e0710487c0e4c0.jpg475ed569554ed2d63f4f30e0bff1761a.jpge83eef2c1783208b7be415a2bf8f64a8.jpg
Nice truck man. Love all your mods so far. Is it a 6.2?
Thanks. It is. Wishing I would have went a little bigger on tire size for these wheels. But for 600 dollars new with the stickers still on them I couldn’t pass the deal.
I love these things, I wish more of the automakers would get on board with this idea. My work trucks are fords and it’s literally the only thing I like about them. [emoji1787][emoji1787]
So that’s just automotive taped on there tho right? And it’s wireless and basically acts like another fob? How hard was it to program?
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • It has happened to me a few times. I carry a jumpstart-tire inflator with me.
