Finally got some winter tires on steel rims.
also added some amber strobe lights to the front of the truck. ( being an army medic I am somewhat of a magnet for accidents.  People at work call me a black cloud )
ooh lala should I go for it guys?
lol
Mine was from Molly69. Don’t be too jelly. [emoji1787][emoji1787]
On 12/9/2020 at 11:31 AM, slj2008 said:
Did you add lights to the steps ??  Look's good
Yes, 11mm/3watt/flush mount/stainless bolt lights
Thank You for the info.
13 hours ago, slide187 said:
You got one too I deleted mine ?
mine was already deleted i only had a notification email, never click on those links anyway you might catch a ISTD. lol
  • Haha 1
Went to a body shop a couple weeks ago to see if they would paint my chrome bumpers. They would not for obvious reasons. Started doing a ton of research and ignored all of the advice on not painting them... Obviously. Finished the rear bumper today. Think it came out pretty clean. There are a couple imperfections in the clear coat, but if it bugs me enough I’ll polish them out. Hopefully my 4 hours of sanding hold up [emoji23][emoji1317] Not bad for 70ish bucks per bumper.
  • Like 7
Hey guys!
Just got my truck back after a week of repairs. Radiator, lines, water pump, belt, thermostat all replaced. Also got a tune up with new OEM spark plugs and wires and a fuel system flush. It was more expensive than I thought and took a lot of time, but I am very, very happy with the end results. Truck rides like it did when I first got it and is super smooth; just in time to become my daily driver again for a new job. ?
Mine said she was “looking for a good guy for romantical s3x.” all I had to do was “click here to register.” I mean... if that’s not legit, idk what is. [emoji1787][emoji23][emoji1787][emoji3059]
You’re alive!! Lol
Been a while. I think I've added tow mirrors, Detroit Truetrac rear differential, and 4.10 gears since the last time I was posting much. Oh and the B&M diff cover.
Sent from my Pixel 5 using Tapatalk: http://www.gm-trucks.com/forums/index.php?/topic/192614-Tenscourts'-2016-LTZ/Z71-CCSB-4WD-Silverado
4 hours ago, Mercracing said:
I ordered a front and side view cameras. Details coming...
start a thread on the install and set up
    • I have a 2015 Silverado and sometimes I can not get in to the truck. I use the key to unlock the driver door. Something is locking the truck when I unlock it, last night I left the truck open and this morning it was locked with the mirrors folded in. This happens while driving so it is now a safety issue. I reach down for the folding button and they open, then they close again.  Any advice, thank you,   Ed
    • Did you ever find a resolution to this? my 2019 Silverado 1500 is showing the exact same headlights issues with the exact same symptoms.  would help a ton if anyone has any advice on this or better yet a known solution..
    • tl; dr I've now reached the 6th floor of hell. I'm chronicling my journey for my morning readers.   Pulling the top of the intake apart was moderately easy but it involved a lot of parts, connections, and minutae. I was preparing for the new fuel lines to arrive ("nut and bolt kit" it's called). The fuel line connections are notched and held in place by the manifold and a metal plate with a T27 screw.   It's on the back of the intake, under the firewall, with little clearance, and two hard metal fuel lines in the way. I was using Franken-tools (weird combinations of 1/4 inch ratchet with/without an extension, with a bit holder for my T27) to get in there. One of my sockets and bits fell off and has yet to emerge on the floor. I lost a second setup and that's when I almost started throwing tools. But that was the point at which I had gotten traction on the Torx head, and it promptly stripped. No more traction.   I started humming "1-877-kars-4-kids" because I was about at that point. You know what? I'm $1500 into this thing and I can make it disappear just as quickly. This isn't fun anymore. I had spent a lot of time already "tidying" around the engine bay: Fixing all the "someone's been here before!" BS. The truck has been exclusively dealer- and shop- serviced and I'm reminded of why I never let other people work on my cars unless absolutely necessary.   Speaking of dealer service. This truck has a 1" stack of records going back to 1995. I put them all in an excel spreadsheet, date/mileage/description.   The CPI spider has been replaced 4 times in 85k miles. The EGR? Another 4. Multiple, multiple O2 sensors. One Cat. 4? Sets of plugs and wires, and I swear half the stack is diagnosis paperwork for "misfire, runs rough, extended crank, dies at stoplights".   GM was producing some proper crap back then. And it was still well within the era of brittle/crappy plastic. (Windows 95 was released the same month this truck was sold new, we HAD the technology!!)   There (was) a plastic shroud around the evaporator core and HVAC fan in the engine bay. I noticed a chunk of it missing so I poked at it some more and it literally shattered. Touched it some more and pieces were crumbling off. Had a good laugh. Clearly whatever plastic garbage they were using had broken down over 30 years and was literally turning to dust. That was a good half hour of using a shop vac to remove the rest of it.   Back to it.   I was going to give up for the evening but then decided I'm already level 10 pissed off at the stripped screw: G* D* it, give me my tools back -- and my JOY. We'll do this the hard way: The whole intake is coming off.   Blazer won Round II. After finally finding and accessing the 12 intake bolts and using a pry bar to unseat it from the heads, it popped loose in an explosion of gunk and grime raining down into open ports. Awesome.   6 times I reminded myself: Be careful of the temperature sender on the front of the intake.   YEAH, I forgot again and snapped it clean off in the removal. Add another $20 to the ever-growing list of new parts this thing is consuming.   The shame is, long before removing the intake, I had changed the oil in prep for Tuesday's momentous fuel line replacement that was going to be the magic fix and I'd have a running Blazer to tool around in this next weekend. The intake removal, including raining gunk, also gushed dirty coolant all over the valley. Of course it did. Welp, there goes another $35.   I now need an intake gasket set, bolt set, coolant temp sensor, another 5 quarts of oil, some RTV. Don't worry, I've already got 3 new jugs of Dexcool and a thermostat waiting. I'll fill it with clean water first to get it running, dump it, and then add the Dex later on in case... well, let's not go there. I'm only tearing this down once, next time the truck is going on Marketplace for FREE.   Oh, and I'm going to need vacuum hose for all the stupid connections placed at the rear of the engine which have since disintegrated. Come on, GM....tell me you don't do that anymore?   Oh, and the ears on the distributor where the cap screws down are both cracked. I mean, why not put a new distributor in it too. You get a distributor, YOU get a distributor, Everyone gets a new distributor!   This truck isn't out of the woods yet...I'm already questioning how much more time I'm willing to sink in.
