Had a similar problem on my 16 LTZ. Problem occurs when I have multiple items plugged in (e.g., phone, ipod, ipad, and thumbdrive) at the same time. Often times the power to one or more of the outlets (USB and/or cig lighter) flashes on and off rapidly. Seems like they are not pushing enough juice to power all the outlets they have built into the truck. My screen will go blank and it won't recognize any media I have plugged in. Really frustrating.
My 16 just starting doing this after two weeks! so the only fix as of now is just pulling the fuse and putting it back in?
Thanks
Thanks
No not a fix, a work around to get it going if it doesn't come back after waiting or a restart.
My guess is that there won't be a permanent software fix anytime in the near future. Probably tens of thousands of lines of code with pieces being written under subcontract by many programmers and the whole doesn't work exactly right when a combinations of dozens of inputs are simultaneously being read by the radio/Nav head/phone/time delays/light sensors/bluetooth/4G Internet/USB ports/video drivers/Iphone/autoandroid and a whole lotta other crap that screws up the logic circuitry and causes a video freeze or some other unexpected occurrence.
So I pull a fuse now and then....I can live with it as long as the engine doesn't stall....my complaint is that the idiots didn't put a reboot button on the unit......or maybe the designers did a need for it given the complex nature of the computerized electronics, just like the need for reboot capability of a home PC, and the marketing people nixed it.
Driving on the roads here in Texas with 105+ heat.
I had my screen go black while I was listening to XM. The XM continued to play, the reverse camera worked when I put it into reverse, but the screen wouldn't change from black.
Turned the radio off by pressing the power button once (not holding it down), and turned it back on 5 seconds later...screen came back on just after I turned the radio back on.
I think it's more of a temperature thing than anything for us here.
You might be on to something.....mine crapped out after getting into the vehicle parked in the hot Sun. Forgot the sunshade and the internal temp was over 120F.
Well I too am in Central Texas, so the heat might be a cause, but not the whole issue. It will be interesting to see what GM does to fix this. I have a new HMI Module on order for mine, but they are on national back order, so who knows when they will become available?
  • 8 months later...
You can buy all the extended warranties you want. GM will just say that's the way it is supposed to be, and refuse to fix it. Then one of these GM monitors here will get involved and pretend to do something beside ask for your vin and dealer
Mine went out for the fourth time. Dealer in Wenatchee wa charged me 135.00 to reprogram it. I asked them if it fixed the problem they said I don't know. If ti happens again disconnect the battery. What a bunch of a##munchers. I won't be going back ever again. What a rip off
Has anyone just had the bottom of the screen black out when they adjust the HVAC controls? Mine's done that and also the instrument panel has blacked out on the radio controls (didn't display the music station or song).
I hear there is a problem with bad grounding near the dash speaker on the drivers side. This bad ground causes a lot of issues with dash power apparently. You can pop the dash panel closest to the windshield and take a look to make sure you have a good connection. You'll be able to see it once the panel is off. There may be a loose connection or a problem with the crimp on the spade.
  • 2 years later...
I’ve got a 2016 2500 my screen went out and and I’ve tried everything, pulled the fuse, disconnected the cables. The radio will work trough the steering wheel for about 20 minutes then cuts off. If there’s anything else I can do let me know.
I have a 2015 Silverado work truck, my radio screen has gone bank on many occasions and the constant fix is pulling a fuse on the right side of the dash. A technician showed me how to fix it. I feel I shouldn't have to deal with this in such a way. I was told it reboots the radio. Often I have to reset all the radio channels, time, etc. The other day I was listening to some music via USB and my wife put some music on via the SD card input located in the console. I liked the music and left it in. Later I noticed the radio would randomly cycle on and off and the controls were non-operational. Out of curiosity I removed the SD card and the random cycling stopped. I am so disappointed in the stock radio head I have decided to replace it with an aftermarket radio even though I will loose the warning / monitoring screen. I have searched the internet and found many people have similar problems but nobody has posted a resolve. My only concern is that if I replace the radio head is if the factory power wires are the culprit resulting in the same situation. Perhaps the stereo installer can wire into other circuits to solve the problem? I don't have the answer....
So I pulled fuses 41 and 56 for info 1&2 and I don’t think it worked. I called on Star to set up my free trial as I heard they may have an Update and what do ya know, it worked. Not saying onstar services fixed it but I believe that it’s a software bug and by it being connected to 4G service and getting signal it may keep it from wigging out. I will post an update but this bug has to be software and not hardware if it was hardware it wouldn’t sometimes work and sometimes not for this issue it needs to be updated by a new software from GM which it hasn’t since 2018 so old software in a new system imagine how often our phones get updates and if we don’t they break so same thing I’m thinking.
So my infotainment screen just stopped working.  Sometimes the backup camera works and sometimes it does not.  Sometimes when you crank up the truck the screen will turn grey and then black.  I have fully dismantled the dash and pulled every connection and reseated them.  I have pulled the fuses and reset them.  I have disconnected the battery and then reconnected after a half hour.  None of the “easy” fixes have worked.  I scheduled an appointment for service but this seems like a ridiculous problem.   If anyone has any ideas or can help it would be much appreciated. Thank you in advance.
I had the same issue and they replaced the software and still didnt correct the problem
Sent from my SM-T817V using Tapatalk
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
