Thanks GM for fixing it, 3 days at the dealer for the frame issue and Radio sound problem, the radio still not working after update and xm radio antenna replaced.
It doesn't look like they did much for the frame rust... am I missing something?
They didn't do much, but they call me saying was fixed.
I'm guessing his post is laced with heavy doses of sarcasm. It looks like they painted the pumpkin and that's about it. Great job GM.
Edited by badfnz
You are right.
I'm assuming you've had a follow up discussion with the dealer on the "fix".... What was the outcome?
To the OP:
Do yourself a favor, get some sanding discs, a few cans of black primer paint, and several cans of good quality professional rubberized undercoating and fix it yourself. I would not even bother taking the vehicle to them. You can fix it nicely yourself in several hours and be happy with the results.
If I worked at that dealership, I would be embarrassed to call that fixed. Someone got over promoted at that shop. He is probably related to someone, there's no other way he could otherwise keep his job.
When contacting the dealer, they said TSB #14002A did not apply but #PI0564D did apply.
Does that one say it is NORMAL?
Por makes a rust coating the neutralizes the rust and puts a black coating on it. If mine does it that will be the step I take.
That's not acceptable! Looks like it was done by a blind man. I'd be back there demanding to know why they had the truck for 3 days and that's all they accomplished. I sincerely doubt it's GM's fault, but that of a lousy dealer.
You actually left the dealer with it looking just as bad? I would have no accepted that.
I had to leave on Saturday after 15 minutes of waiting for the general manager. I did had a meeting with him this morning and GM by email. Dealer said he just followed GM directions.
    • Hey thanks yall for the info. It apparently was the key fob - the "reserve" key fob works just fine. Yall were all over it. Great input! JRD
    • I just bought one of these.   https://www.topdon.us/collections/diagnostic-tools/products/artidiag-pro   Yeah, it`s got a cable. $250/year after 2 years. Do I want more? Yep. But, I`m not working any more and can`t afford a whirlpool in my tool box.
    • Why don't I have a good scanner? I've always wanted one when I've needed one.   My latest reading says I don't need to do a relearn on the ckp sensor on a 1995 with OBD 1.5. The relearn is prescribed for the later-model 1995's which shipped with actual OBD II when GM completed the transition in prep for the 1996 MY. I need to confirm that. Did you know forums are disappearing? Knuckleheads on Facebook... it's not the same. It's just not.   So, scanners. Again, shooting myself in the foot for having eBayed my Snap On MT2500 "brick" with all the adapters. Not that I couldn't buy another but those are getting quite old, and mine wasn't new enough to work on 2000's vehicles.   Damn it (as I'm scanning my email between paragraphs here). Did you know there's a 2000 Jimmy 2-door on BaT that's ending this morning? It's local. I want it. 14k miles. Absolutely beautiful.   Back to scanners. MT2500's are old. Solus, now that could be a contender. There's a ~2008 Verus with a system error that's basically new in box for cheap. Hmm...I'm not sure about a scanner that runs an archaic version of windows (95 or CE, I can't tell).   I want the ability to reset and rotate TPMS, test individual modules, bleed ABS, electronic parking brake controls for servicing brakes, relearn procedures and other bidirectional controls.   Snap On does an MT2600. It's a new model as of last year, marketed as their "entry" scanner. Entry? Only where $1900 gets you through the doorway plus, I'm guessing, $1000/year if you wish to keep it current. So goes scan tools actually designed for production environments. Want decent products with excellent support, you pay for it.   Everyone is raving about Autels and TopDons and Foxconns and all these newer brands that are selling the $500 "prosumer" scanners for backyard hacks like me. They're tempting...honestly. Updates are cheaper, base prices are remarkably cheaper... And you get to deal with bugs and translation whoopsies and, well, just don't use it on anything expensive, OK? Having a dealer replace an ECU because it needs to be re-imaged after an adventure in scanning is no joke. But I think most people are getting by OK with these units.   eBay on a scratch-and-sniff pro-model oldie, a shiny new TopDon, or???   God dang it, I can't stop looking at this Jimmy. I'm ready! I'll Bring The TRailer! It's beautiful.
    • I removed the OE running boards.  It looked so much better.  I wish I took them off a long time ago.     I had to put something back on for my wife.  I wanted Westin Sure Grip Running Boards but they are very pricey, like $600 plus.  I was going to go with the Ionic 41's like I had on the 2019 Silverado but went with Westin Outlaw Drop Steps instead, about $200 cheaper.  They are sturdy and functional but not super crazy about the look, but it works.
    • It's all a crock of 💩
