I've read so many posts about the 5100s my head is spinning.  80% love them, 20% say they ride terribly.  Seems like there would be some in between.  Perhaps some Install error?  Maybe bolts need to be torqued when the truck is on its own weight?
Everytime I'm ready to buy them I find someone new who says they're terrible.
When have you ever been in a room and had 100 % of the people in the room agree on the same thing?
It’s $450 not a $4,000 purchase - and 80% (by your estimation) agree on the value of the 5100.  I’m unsure what else you need? A consensus?
Imagine if you applied that same selection criteria to the question:
should i I buy a Dodge?
should I buy a Ford?
should I buy a Toyota?
You’d never make a decision in life - if you’re looking for consensus from “peers.”
Edited by Oregon_GMC1500
Thanks to everyone who answered my questions with valuable information. I picked up the Bilsteins off amazon for 365 shipped if anyone is in the market.
For those that have changed the strut settings after installation, how difficult is it to adjust? I know its just a snap ring but I can't imagine its super easy to adjust.
You’re welcome and Good Luck!!
Photos are always welcome after install.
If other folks hadn’t posted images & advice on their setup - I would have been lost.
My point is there is a wide spectrum in results.  I assume something may be going wrong on the install or some defective part.
I decided to order them from 4wp.  $297 shipped for all 4.  I go back and forth on which setting I'm going to do, either the 2nd or 3rd (.75 or 1.25 claimed lift). Since I don't really want to mess with rear blocks and my truck has under 2.5" rake, I'll probably go with the 2nd setting and maintain 1.5" rake.
I'll be sure to post pics and a review!
I've used this style strut on a different vehicle, different brand.  You have to remove and disassemble the strut to change it.
If you got the set of 4 for $297, I don't think you got the height adjustables for the front. You might double check what you ordered.
Sent from my SM-G930P using Tapatalk
 Correct part numbers for the Bilstein 5100 for our K2's :
Front: 24-238304 (Adjustable)
Rear: 33-238319
 I have not seen these sold as a set of 4 so yes double check your order......
Rear: 33-238319
4wheelparts has a promotion on the package.  My understanding is the non height adjustable ones are 4600. I did call them to verify but they have to get back to me tomorrow.
I asked them if that promotional price covered the 5100s that fit my vehicle and they haven't gotten back to me in a week.
It doesn't, I tried to order them for my old truck last year and it only included "shocks" whereas the fronts are struts, so the deal did not apply. Cheapest I found them was amazon and summit at the time...Now I'm driving a 2017 and after one year of ownership I've had it with the Ranchos and I'm on this thread.
That's annoying.  I called them a few hours after I ordered and they said they couldn't find my order yet but they'll call me in the morning.  He agreed that the 5100's are height adjustable so it should be correct. Sounds like if it ends up costing around $375, I should still order them.
Back in page number 113 (i think) there is a phone number and a salesperson who's name is Alan mentioned in the body of the receipt. The price and his number are there, so perhaps make it easy on yourself. Parts arrived next day - and everything was perfect.
You guys were right.  Error on the website, it's for a truck with shocks only.  Straightened it out, paid the extra and I should have them soon.
4600s are the same internal shock, with yellow paint on the outside and blue boots/protectors.
Other than the silver look to 5100's, 4600's will do the same job if you are not wanting to level the front end.
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
