Can’t remember from when I installed the 5100 but I want to lower the front shock to the bottom ring for stock ride height so I need to take the spring off for that? Wanting to do that tomorow but need to know if I gotta get a spring compressor first
Yes you need spring compressor.
I have a :
2017 GMC Sierra 1500 Crew Cab RWD
I’d really like to run a 35 but I am not a big fan of 4+ inch lifts. Unless there is some sort of coilover UCA combo I am missing. So I guess I’ll have to settle for something in the 33 range, ideally 305/70/17...Have people gotten away with that tire set up with the 6112 shocks?
On 4/25/2019 at 3:30 PM, Sierra Dan said:
4600 and 5100 are built identically on the internal side other than a longer shaft for the 2" of lift.
Not looking to start something here but as of today (maybe different in the past) this is false information. I've called Bilstein twice now and spoken with two different dudes who have confirmed that the valving is indeed different.
They keep their valving specs on lock down but they confirmed it's different and that the 4600s have softer valving, by how much? No clue!
...SOOO for someone who isn't looking to increase height on the front (which is clearly the minority) 4600 is probably the way to go!
Ok starting to go cross-eyed, I have a '14 GMC 1500 Z71, having Bilstein 5100's put on Thursday, planning to go with the highest setting, what's the biggest tire size I can go without rubbing, or with minor trimming on the factory 18's? Kind of eyeing 285/65/18's or 275/70/18's in BFG AT2 or Goodyear Duratracs
I have LT275/70/18s, no lift Ko2s and no rub. 2014 silverado CC 4wd. So you should be able to do at least that.
I think I want to go somewhere between stock rake and level. Anyone got pics using the 2nd notch? Thanks.
Thanks, went with the 5100's at the highest notch, and the 275/70/18 BFG KO's, only rubbing is one right turn at full lock, I just need to tie back the inner fender liner and it looks to be no rub after that, very happy with the ride and looks, a little stiffer than stock but I always felt the stock ride was too soft anyway, should have done this from the get go, with a tape measure it's 1" higher in the rear after the install
Edited by Ryan A
I went with the 2nd notch.  I think looks good and I wanted some rake.  The truck ride better than the rancho factory shocks E1850EC0-6284-404B-89A8-2385D19E3CA2.jpeg.d12faf0cd2bd6ec6127f9111cf74922b.jpegks
Thanks! Looks great!
Hey everyone, I need some help figuring out what to do with my truck:
2017 Z71 CC 90,000km
Installed Airlift 5000 at rear last year
Front end now looks stupid low, and front suspension feels dead. Rear suspension feels just fine now with the air bags.
It seems like the 5100 will be the best bang for my buck. Should I install a full kit on all 4 corners, with new coils up front? Can I just get away with installing the 5100 up front?
Anyone know of a good deal for a set of 5100’s right now? Looking to buy in the next week. Thanks.
It won’t be quite within the week but probably in about a month. I’ll be taking mine off and putting 6112s on. They have about 20k miles on them so I’ll do $120 for the pair
Added Bilstein 6112s on the highest notch today. Rear has 5100s and 2.25” blocks (1” of lift). It turned out exactly like I wanted it to be.
affb9d5190a9c38ff9cfc01ece3c909a.plist
    • I'm tangentially aware of what Harley used to be, back in my riding days, although I was into Italian sport bikes. Ducati seems to have gone the other way; still very expensive, but they've made a large subset of their bikes a lot more reliable and accessible, and they've diversified their lineup to include other riding sports too. IMO, a good example of where greed and growth might have also been beneficial to the consumer.   Although GM is charging a relative premium for its most popular pickups, I find that there are some excellent value propositions in its lineup as well.   The Colorado still strikes me as the most attractive midsize on the market, and also the most reasonably priced given capability and features. There's a part of me that wishes I would have bought one instead of my Silverado.   The Equinox ...I must be getting old. The ICE equinox is a great design IMO. Probably because it reminds me visually of an actual SUV aka an S Blazer. Underneath it's nothing even remotely close, but it LOOKS good. It's got all the modern features plus some at a very reasonable price. If I had to run out and buy myself a daily commuter to do everything except tow, an Equinox would be on my list.   It does bug me that mid-tier 1500's reach into the 50-60k range, and Tahoes and Burbs are even more expensive. Less than 10 years ago, dealers were sitting on rows of Tahoe LS and LT's for low 40's. You could even still find Tahoes with a front bench, still!
    • Big oil is raking in billions from the Iran war. Can it avoid Trump’s fury?   Remember I said Big Oil is 'Vertically Integrated"?   Even as they no longer own the majority of the "Pump" they still own the "Well". Crude price upward pressure does not translate into that same pressure on production. Pumping cost remain unaffected and the gap is pure profit. Even after subtraction of a minor, comparatively, lower amount from supposed, but not always, realized refining volume. Consumers hate war, Big Oil, not so much.
    • We live in a world where the average person expects more. People say wages and our needs are farther apart. My first new home had 3 bedrooms and one bedroom. My first car and truck had what would be considered a stripped or work vehicle. In my neighborhood back then there were more homes like that and cars too. Middle managers and second home buyers worked their way up to the fancy houses and cars. Car loans were 3 years. GM had different models of cars for different income levels. The cars were pretty much the same size if you wanted a big vehicle. The nameplate designated the opulence. Chevy, Pontiac, Buick, Oldsmobile and Cadillac.  To be fair some of the cost is government mandated. We can’t blame them for giving us what people will pay for. Careful advertising steering people towards more profitable SUVs and trucks. As I learned recently a minivan is a cheaper more efficient form of transportation. Certainly easier to live with. Somebody realized the profit margin wasn’t as big and gave it a soccer mom label. So it lost its coolness. They’re making it the masses are buying it. You hit your hand with a hammer you can’t blame the hammer.
    • Hi All, I’m In need of advice regarding a scan result on my 2023 Silverado HD.  The Sensor Supply voltage relay states ON But…. the following 3 tests show Malfunction. Sensor supply voltage relay control circuit HIGH voltage Test status- Malfunction Sensor supply voltage relay control circuit LOW voltage Test status- Malfunction Sensor supply voltage relay control circuit OPEN test status - Malfunction. No DTC codes are stored. No DIC Lights. Remote Key Fob has been giving a few issues, namely Vehicle will not respond to an Open/Lock command from the key fob. New batteries installed to FOB made no difference, plus on one occasion recently the vehicle unlocked using the Fob, the vehicle started normally via the push button, then a random warning came up on the DIC stating the Remote Key was not found, all this while the key was located next to the central cup holders. Does anyone have any input or advice regarding this scenario? TIA
