6.2L Max Tow, Anybody have one?
  • Replies 122
Just got the call that mine arrived at the dealer. I'll wait until tomorrow to go look at it. I thought I would be bonered up about it getting here so soon, but I'm not.
I was the same way as you. When the sales lady called she asked if I was even interested because I sounded so calm. When I went to go see it though I turned into a 16yr old again.
Some of us would just like the opportunity to "get all bonered up"..........still waiting in Missouri. Order for this truck was placed in October and I am still waiting. It does appear it finally made it off the train after about 3 weeks. Now we will see how long it takes to be picked up by a truck and delivered to my dealer. Now I know how the ugly girls feel:)
Update: I got a call from my dealer later this evening and the truck has finally arrived. Excuse the poor picture since this was the only picture sent by my salesman. I guess I know what I will be doing tomorrow!
I picked mine up today. It rides very very nice. No clunking from the tranny either. The truck feels kind of sluggish, probably due to the TM and V4 mode. But when you smash the pedal on the right, it's a rocketship. The inside door levers feel like garbage though.
Picked it up today! Seemed to run fine. I drove a few miles in town with stop and go along with a short hope on the highway at 80 miles per hour. I didn't notice any issues with the transmission or any vibrations with my limited time at the wheel. As stated by some of the other posters, the truck has a very nice ride.post-137813-0-96022400-1429420832_thumb.jpg
She's a beauty!
My concern with the camper mirrors, I was hoping the truck didn't look like dumbo. With the longer bed, it balances out very well. Mind sharing different angled pics? Front and rear view?
post-137813-0-71918000-1429457502_thumb.jpgpost-137813-0-71918000-1429457502_thumb.jpg
I was also concerned about the trailer mirrors looking out of place on the 1500. However, I am happy and relieved to say this new truck wears them very well in my opinion. After seeing my truck yesterday I would not change them to the smaller mirrors.
I second that, I don't think I could livr with the smaller ones.
They're actually more convex than the old style tow mirrors had. You might try adjusting them a bit more. I have mine adjusted so I can see the back tire which eliminates any blind spot.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
