Awesome thread everyone. I've noticed it is a little difficult to see backing up at night now with windows tinted. This will help alot!
You won’t be disappointed!! Dremel / Solder / and Patience and it can all be down in a couple of hours!
Any questions or concerns don’t be hesitant to ask!
I've been disappointed with the lack of illumination of my reverse lights for awhile and I'm glad I stumbled on this thread.  I just ordered a pair of the Rigid Ignites today.
If anyone is looking to buy a set of these, northridge4x4.com has them listed for $98.79.  The price seemed too good to be true since most places are selling them for $123, so I called customer support and they confirmed the price.  I also signed up for a first time buyers coupon code online which saved me an additional $5, bringing my total to $93.79 with free shipping.
Edited by cev103
  • Like 4
After being on back order for awhile, I finally got my Rigid Ignites and installed them last week...... best upgrade to my truck so far!
I found the 1.75” hole saw worked best to cut out the step and I managed to use the supplied stop nuts (although the top one is a PIA) to mount the lights with the help of a friend.  I used a 14-16ga blue Posi-Tap into the white wire w/ the green stripe from the trailer harness for power.  I did tie both positive wires from the lights together and then used a butt connector to extend the length with an 18ga wire because the wires coming from the right light didn’t have much slack.  I then inserted the 18ga wire into the Posi-Tap and tightened the connector.
I did the same with the ground wires, tied them together and extended the length with a butt connector and some 18ga wire with a ring terminal connected to the other end.  Without doing this, I wouldn’t be able to reach the factory ground connection with wire from the right light.  I then loosened he factory bolt attached to the ground on the frame (this was located just forward of the trailer harness) and attached the ring connector.
On 10/25/2017 at 6:35 PM, huntr1117 said:
I just did the same mod 2 days ago. I ended up putting it on a 3 way switch. On with reverse, off, On whenever I want.10340fcb15e325223cb03d114e68be20.jpg
Sent from my SM-G950U using Tapatalk
Can you better explain/share the 3 way switch: type, placement, wire taps......I want to the same choices (Reverse/On/Off) for backing up the boat and whatnot. I was thinking of pulling power from battery into cab for on/off position and using trailer connection for reverse selection. Curious how you made it all happen
Hello, what setup is this? Do you have a model number or web link? Looks good. Thanks
New to this forum. I just bought a 2017 silverado 1500 and was thinking about doing this to rear bumper. Any place out there with a decent price on these lights? Does it have to be installed by a rigid dealer for it to be covered under warranty?
Sent from my LG-M430 using Tapatalk
Amazon is priced reasonably.
124$ now on northridge4x4 now
Hopefully they lower price again
Yeah, I saw that..... I think I may have ruined that when I called to confirm that price..... sorry
Last week they were still $93
Pissed I didn’t buy last week
Thanks guys. I see that amazon has them for 105$. For the rigid lifetime warranty does amazon work under that as a dealer? Do the lights come with a template for mounting? What size hole saw is needed?
On 4/18/2017 at 4:05 PM, sk said:
While the Rigids are great if money is tight why not go with some of these?:
https://www.oznium.com/led-bolt
I put them in my bumper steps facing down just to light up the step (not as reverse lights) but they are plenty bright and work great!
I ordered 4 of these with lenses, and two of the lenses fell off before I even got a chance to install them. YMMV.
Got mine on Amazon, doing install this weekend hopefully
Sent from my SM-G892A using Tapatalk
did you contact oznium's customer service?  from what i've read they will likely just send you replacement bolt LEDs
i've bought a bunch of stuff from them and been very happy with everything.
125$ on Amazon
    • Did have to make 1 modification because of the WeatherTech rear mud flaps and that was needing 3 longer screws than what came with the install package. 😄
    • Picked up the liners yesterday. Installed passenger side WITHOUT any modifications. All mounting holes lined up perfectly. Rain is interfering today with drivers side. Very Happy! Will add pics when finished
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
