has anyone tried to get the charging pad a bit bigger to fit a iphone max in it. if so id like to see some pics im trying to figure out how i could go about doing it with it still looking like it came like that
  • 4 weeks later...
Hey man, I just saw your YouTube video and am very interested. Are you still selling these or have a link to a site that is?
Yes. Reach out to me at HarnessDR.com
Use the contact us button and provide as much detail as you can.
I gotta Center Console for sell 480$
Black with dark wood and charging pad
you’ll have to pay for shipping and packing tho for anybody looking to upgrade
pickup in Dallas Texas
Edited by Frankielozano214
I read about 35 pages of this thread...searched for a few hours (literally) for a part number for the harness in the jump seat. It's a 23 PIN so I need to send it in to Phil for my harness. I hate to take out the harness so the next guy can't use the power in it. Does anyone know a part number? If there is no part number, does someone make a video of how to get the seat apart? Thank for the help fellas. I already have my console in place so when the PnP harness arrives it should be just a few plugins to make it all work.
Tomorrow starts my swap! I’ll let you guys know how it goes. ?
I was able to source my parts through a Local Body shop.
Only concern I have is the wiring harness; it’s coming with a harness but I am unsure if I still need pgamboa’s harness to make it work. Any insite?
Thanks!
Thanks!
To make it fully functional yes, you’ll need Phil’s harness.
Even with the harness GM is sending me? I had a feeling I’d have to get Phil’s but it’s just an extra cost i was hoping to avoid. Thanks for the feedback!
Do you have the part number of what GM is sending you? If it is just the console harness, then yes, you will need Phil's harness.
Unless your truck came with the full center console and your swapping for a newer one then it might be plug and play, but if your going from jumpseat to center console you’ll definitely need Phil’s harness, you’ll also need them two wires usb type B to usb type B to run from the hmi to the front of the console
This is what the Body Shop gave to me for a parts list (image attached). We were also skeptical on if the entire assembly would show up or if were going to be missing anything. We’ll find that out tomorrow.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
