Got it all situated. It’s in for now! Just waiting on the USB and harness. Thanks for everyone’s help!
Got my harness while I was out of town last week. Thanks Phil!!! Didn't take long at all. I won't have it put in for a bit, but I am sure it will be perfect.
Nice buddy!
Hope mine comes soon as well. ?
I’ll be getting a large batch of these started today. Was waiting for a shipment of connectors to come in. Appreciate everyone’s patience.
Hey Guys I’m planning to do the console swap can you tell me if this is the 16 pin connector before I order from Phil the man ?
Pgamboa
Got my harness today and it’s all in! Everything works!
Unfortunately the USB’s inside the Console flip up don’t connect to Apple Play! ?
10/10 thanks for your help Phil!
Unfortunately the USB’s inside the Console flip up don’t connect to Apple Play! [emoji24]
Glad to hear! If your console USB hub is the later 2016+ version without the SD card slot, that could be a reason CP/AA doesn’t work. Also, make sure you’re using the black/brown cable for this and that the black end is plugged directly to the HMI. If you loop out of the front USB hub (like in my video), they is reportedly not passing the CP/AA signal.
Lastly, check to make sure those usb cables are fully seated.
Hey Phil,
Console USB under the lid is just 2 USB and a Aux.
Green runs from HMI to the USB Hub. Black (USB Hub) to Brown (Brown Connector)
AP works just fine with the front USB’s. If that’s what you’re asking/Saying!
41 minutes ago, Adepuy said:
Hey Phil,
So you are using the "output" of the front USB (black port) to the Brown Port.  This is the reported issue of CP/AA not passing out of that "output".  Instead, unplug the black port and route it to the black port of the HMI.  The existing black port cable that is plugged into the HMI is what is under the passenger seat.  So that gets abandoned.  Try that and report back.
That worked!
All USB plug-ins pop Apple Play up.
Green HMI to USB
Black HMI directly to Brown Plug.
Thanks!
16 minutes ago, Adepuy said:
That worked!
Green HMI to USB
Thanks!
Great!  If you get a chance, I would LOVE to get your feedback on the site.
https://harnessdr.com/product/16-pin-center-console-conversion-harness/
You can be a detailed or as brief as you like.
Also, HarnessDR is solely operated by me, from my home.  So all advertising is by word of mouth, FB Tagging, and feedback.  I most certainly appreciate your business and support, especially during these uncertain times.  Thanks again!n  #ModON!
    • I have the same running boards on my truck and I do agree they are bulky. I also find myself stepping over them when getting in and out of the truck. Besides providing protection to the rocker panels, they aren't very useful.  I will be replacing them soon with the Amp Powersteps.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
