Just purchased today.  Tech Package, AT4 Premium, Driver alert II, performance package, sunrooof, 20" wheels. Love the cat back sound.  Love this truck!
Edited by paulny
  • Like 5
4 hours ago, mbr2ooo said:
Thanks... I like these wheels better than the High Country 22s, plus it's nice to have something none of the other Silverados out there have.
I don’t mind any of the polished wheels GM has for the T1. Beats the hell out of those chrome plastic clad wheels IMO. Won’t break my heart if those kind never come back.
Congrats I'm trying to get one as well but there not dealing near me
19 AT4 5.3 with tech package and 20s, so far only mods are the windshield decal. Love the truck drives surprisingly smooth for an offroad oriented trim. I have taken it offroad and it impressed me. #RideOnT1s!
Edited by Amaze Productions
Thanks!  I had to drive 8 hours round trip to find not only the exact one I wanted, but also to get the best deal within a 300 mile radius.  Be patient and persistent...it will happen.  Good luck!
9 hours ago, Wheelguy said:
Nice, simple mod. Have those on my Denali. Pretty nice for factory wheels & polished wheels seem so much easier to maintain.
 Are the wheels polished with a clear coat ?
All GM wheels in North America are clear coated except for the areas of installation contact (mounting surface, hub hole & lug nut chamfers). The only exception might be a plated wheel. I cannot recall if clear is necessary for a plated wheel or not. Painted and polished are most definitely clear coated for protection against mainly corrosion due to substances used for clearing ice & snow as well as effects from heat & humidity.
Edited by Wheelguy
0dabcd3af21acf080dbd05b648da8586.jpgb562c55a8fe63585edeb57aa45581675.jpg99ab19a169c85a0e68a3c2d8aa3c6dc2.jpg
The wife took her Denali in to the dealer and came back wanting this, well more of a demand. Brought it home Friday.
It's got the 6.2, technology package, premium package, painted wheel moldings, sunroof,...I don't know of any options it's missing beyond the performance package.
Planning on window tint, ordered powered tablet holders, bought a potable Bluray player that's like a laptop, researching some type of bed cover.
Sent via Morse code
Sent via Morse code
Beautiful truck !!  Congrats.  This was my second choice, but I went with a new left over 2018 Sierra Denali Ultimate with 6.2.   The deals were just to good to pass up, especially compared to a new 2019.   You love the motor that's for sure.   Suggestion for bed cover :  I was going to go with the Bak Flip MX4, but dealer showed me the GM version.  It's made by Rev Industries.  Looks the same to me at least.  Any ways, I managed to get it about $150 cheaper than the Bakflip.  Enjoy your new truck.
Sent via Morse code
I had the dealer install the Undercover Lux..  it’s awesome..  thinking about adding the Bed Rugs to make it just like the trunk of a car..
Just picked this one up yesterday didn't plan on it just did it on a whim LT Z71. Accessories on order.
Thanks
Barry In MO.
  • Like 5
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • It has happened to me a few times. I carry a jumpstart-tire inflator with me.
