If you have the HUD with built in Navigation you can obviously display the directions through the HUD.  Unfortunately, if you prefer WAZE for directions you cannot display the WAZE directions through the HUD.  However, if you set up your destination with the built in Nav first you can then go through Android Auto and also set up the destination in WAZE to display on the center digital display.  Basically , you have 2 Navigation's running at the same time.  You have the advantage of the directions showing on the HUD and also getting the traffic, hazards, police updates from WAZE.  On long trips, WAZE has saved me a number of times in avoiding major backups.
Thought I would share a picture of the GMC Tailgate Handle I added to my RST.
  • Like 4
Nice idea. Makes those stake pocket holes obsolete.
Nice!  Where did you get it?  Do you have a part number?
I ordered the handle, bracket and bolts from the GMC Dealer and installed it in 5 minutes. I don’t have the part # but I am sure they can hook you up.54FFA4B5-CA65-4982-AD56-0437AF76FA21.thumb.jpeg.ffc9338caad580fc906fcb4b6193d941.jpeg
Picked up my Trail Boss Thursday and did a road trip to the states Friday. Cool that when you switch the units the speedometer dial and DIC convert to MPH.
Coming from a 2017 F150 and it didn’t do that. Only thing I miss about the F150 is the big gas tank.
Ohhh and I miss the console shift as well.
  • Confused 1
The truck will detect if your trailer's light is malfunctioning and tell you which to check accordingly. Another big this is the truck will automatically engage parking brake if you're loading up the trailer and rock the truck a bit.  I found this out as I was rocking my boat trailer back and forth just a little to get the wheel chock out, as I was doing this I heard the brake on the truck engaging.
Discovered this today.... if you press on the skinny pedal on the right, you can find Ford F-150's in the rear view mirror...
They just appear there... its like magic!
  • Like 13
  • Haha 9
Lol COTD!
On 10/19/2018 at 1:07 PM, sams819 said:
Another small but nice change I noticed. On my 2016 the oil fill was a screw on cap on the valve cover. My 2019 has a filler tube that is high over valve cover and it is level so a funnel sits on it level. Much easier and less messy.  ???
Do you have a picture? I would love to see this.
It actually took me a few seconds...i'm slow today. LMAO.
This also made me sad b/c it reminds me i'm about to drop some money to get the cam phasers replaced on my F-150 so I can get rid of it.
Edited by ChinkySuperman
  • Haha 1
Your parking brake will disengage when you press the gas pedal.
On 7/17/2019 at 10:15 AM, BringTheRain403 said:
Sorry IMO they're all trash. They're annoying AF in stop and go traffic or when you stop at a stop sign for two seconds and it shuts off and turns right back on again and for the 4% fuel mileage savings they say you'll get I'll pass. It's the dumbest feature they've come out with on new vehicles in a long long time...
Sent from my Pixel 2 XL using Tapatalk
agree, mandatory tpms sensors suck too.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
