7 hours ago, peterH said:
My dealer just told me there are going to fix the leak by sealing from inside the truck.... ?
That would be a first That I’ve heard of a dealership doing it that way. Can’t hurt either way, the actual fix doesn’t work anyway when done from the outside. Unless you get a new window it seems like
On 5/15/2020 at 9:08 AM, Leevon said:
Stay tuned ya'll...I just ordered a solid rear glass to convert my slider.  This might seem crazy to some but my options are 1) let the dealer "fix" the leak and we all know how that is turning out or 2) trade the truck or 3) fix it myself permanently.  I like the truck, don't want to trade it and I never wanted the slider anyway and I definitely don't want silicone goobered all over a $55k truck so solid window it is.  The GM glass is coming out of Canada apparently there isn't much inventory.  I am going to do some dis-assembly and prep this weekend I'll let ya'll know how it goes!
I got the conv 2 pkg and to be honest I really don't even use any of it.....stereo sounds a lil better, the rear window opening doesn't matter to me either.....my 2019 didn't have it and this one does have it.....I will probably never use it
and the conv 2 pkg was must on this truck, I just had to have it, lol now I got it, meh.....not really a big deal having tons of extra stuff on a truck.....
we don't get a ton of rain but my build date was 11/19 ....idk if that's early or late for HD trucks
Are these the redesigned nuts? Just got them today from my local body shop. Wish i had the original ones i took off the truck, there somewhere in my shop/garage. They were a little bit wider and smooth.
@abraham Lincoln I wish I could tell you. My truck is still at the dealership waiting on them since there on backorder. I can send those pictures to my service advisor and see if they can give a clear answer on that.
On 4/29/2020 at 5:58 PM, ShamrockShooter said:
Interesting. Just realized the work truck trim doesn't have the spoiler on the back...5455623b0ce25af48a851eaf5b00fd41.jpg
Sent from my Pixel 4 using Tapatalk
I really wished this was a “spoiler delete” option on these new trucks.
Well 2 weeks with the TSB done and it held up during some storms. Last night it rained. When I check it there was water again. It was not nearly as bad but none the less it is back at the dealer for the weekend.
it is definitely coming from the spoiler. Because I dried the window and then tapped the spoiler and out can a drop of water.
You can see the water following the contour of the window frame.
oh 2020 LT Trail Boss with 1200 miles on the clock. First repair was done at 700 miles. Only had the truck 6 weeks. Build 11/19
Edited by Andrew David
I'm not so sure. If you live in really cold climates, water gets in and freezes, it expands, and boom, you have another problem.
Interesting. The 2019 I am looking at does not have that little grey trim piece in the corner of the rear window
Grey paint on the window? It probably does. Black slider track plastic? Only if you have a sliding rear window
It may have been the lighting
It’s not a trim piece. It’s the silk screening on the glass the flash is making it look grey.
I don't own a T1 but my wife's Malibu had a similar problem that I recently did the TSB on myself by ordering the parts instead of going to the dealer.  The problem was they used the wrong nuts that with were not locking and with time and vibrations were getting loose. Also the gaskets were so thin as seen on some of the pictures here that the new ones are about 4 times as thick.  Here is the TSB for reference. Hope it helps if anyone suspects the leak coming from the rear spoiler.
https://static.nhtsa.gov/odi/tsbs/2019/MC-10165439-9999.pdf
Today I finished up my slider to solid window conversion.  Would I do it again?  Yes.  But cutting the urethane seal to remove the glass is a pain and I'd leave that step to a pro next time to save the aggravation.  I can say confidently that these leaks COULD be fixed by removing the spoiler and sealing the top of the sliding window IF performed with the right products and extra cleaning and care.  Replacing the glass is overkill.  But with a slider you'll always have a cracked window frame, unless the design is eventually fixed and the glass is replaced.
The TSB is incomplete in my opinion, the products recommended are inadequate and the likelihood that it will be done properly at the dealership is a huge gamble obviously.   If you want to seal the window frame then use a self-leveling urethane or seam sealer type product.  Sealing the spoiler bolt holes is also critical, although I'd argue the majority of leaks are probably the frames not the holes.  No matter who does the work, your headliner will have be molested, paint may be scratched removing the glass and something will probably break (a trim clip etc).
The solid glass cost me $257 and took a week to get through my dealer parts account.  I spent about $120 on 3M products and specialty tools.  I used 3M urethane primer, 3M window weld and 3M strip caulk.  One tube of window weld (sealer) did the job.  I rolled the strip caulk like play-dough and put it around all of the bolts. Once tightened, it squeezed through all holes and made a nice permanent seal.  After the glass had been in for a couple of hours and the spoiler was replaced and everything buttoned up I put the truck outside just in time for a huge rain storm and it passed the test.
Edited by Leevon
  • Like 5
    • Can someone tell me where the video processing module is in a 2023 Silverado? I'm getting conflicting results that it's in the front passenger area or the rear passenger area behind the seat.
    • Yes I agree, its what amounts to free advertising to let people know about his UOA testing company, and not that there is anything wrong with that but certainly that is a motivator for putting out videos about the science of oil as well as other topics such as oil and air filtration etc. The interesting part I found with his last video is not only the physics behind the reason for the varying wear due to a diesels working torque range causing more bearing load and that higher viscosity oil is of benefit, it was also that the chemistry behind the GM Dexos 0W-20 and the Mobil Dexos licensed 0W-20 are far enough apart that its showing up with a difference in wear even though the two oils are matched in viscosity and in that comparison viscosity was not having the finger pointed at it.    There are a few youtubers out there or one anyway that I have watched a bit of who has gone through the pains of accessing various countries manuals for a certain engine platform and while in the US/Canada it may say use 0W-20 or what have you for some Toyota product, in some other countries it sings a very different tune for the very same engine with the typical traditional oil viscosity/ambient temperature charts to help choose which oil viscosity is correct for the conditions the vehicle will be used in and in some cases its taken an engine in a US manual that states only use 0W-20 as per warranty coverage and yet that same engine in certain other countries may have up to a 15W-40 etc oil option that meets the spec. Another words the guy who is driving through Death Valley or Phoenix and south weather at 120f is often being fed a line of bs by the US system that has forced vehicle companies to restrict the warranty to a specific low viscosity oil for anterior reasons as well as the long drain interval suggestions.    Thankfully youtube is free ( yet anyway ) for viewers to sift through information and of course comes with the good and the bad ( truth and lies ) and we can choose to turn off/not watch what a person finds is bs or just not interested in the topic.
    • No doubt... But, as someone who doesn't pay for his services, but who has provided a few views/clicks on his Youtube platform, the data around the Mobil oil testing I think does have some value including to "freeloaders" like me.   A lot of what he's doing is likely showing the OE's work in their oil selection, something that many of us had kind of assumed was true all along, a good balance of both excellent protection and efficiency.
    • Lake Speed is drumming up business for his company just by being in the spot-light so he has a vested interest in stoking the 0W-20 fire.  IMO
    • I knew when I bought my truck that it had off road hill decent or craw control or whatever they call it and rolled my eyes at that but it gets throw on with other options my truck has, I just never had a heads up if the highway speed regular cruise setting had anything to do with the brakes and that took me by surprise. If you've ever been to the top of Pikes Peak and watched those ahead of you on the way down with their brake lights on constantly, one can guess they are probably not gearing down or not enough anyway if their vehicle will allow and a good reason their is a brake check spot part way down where they use an infra red heat gun to check how hot ones brakes are front and rear.    Your right that once one gets out of the front range by Denver and I've not been on that stretch of 285 between Denver and Fairplay myself but I know its high and Fairplay at 10000 feet, Buena Vista at 8000, it drops a bit from there but then your going back up and over the 11000 pass and Durango is at 6500 . So yes your definitely right that 6500 and a lot higher is the theme of going anywhere out in that direction from Denver but hey, the down hill sections give fantastic fuel mileage !.    I don't even look at the fuel pumps for what premium costs here, since I live on a farm and up to this point get fuel delivered I am rarely in front of a fuel pump and when I am, I am often using card lock bulk fuel stations so it tells me what the price is AFTER I buy the fuel. Looking up on gas buddy and converting to US gallons but in Canadian dollars, regular on average of the prices listed was around 5.95 and premium is around 7.00 . That was one reason I did not go for the 6.2 half ton aside from its lack of carrying/towing if one was going by the rule of using premium fuel and until recently one could only buy regular farm gas if playing the few cents off game for farm dyed fuel for a "farm licensed pickup". But yes I hear you on the fuel price difference and like the diesel theme with it often being more expensive then gas it doesn't have quite the charm to it either as it once did although right now here for some reason the price of diesel has come down more so its now inline with the price of regular gas.
