Wow this thread it super depressing. If I was y’all I’d just go for the solid widow replacement option. I had the opening window in my 2016 but, don’t miss it a bit on my 2020.
That’s exactly what I’ll do when mine leaks.
The thought that we should eve have to change the sliding rear window for a solid one is  ridiculous. I have not used the slider in mine but I still would easily give it up. What about resale value? I personally have just had my first (and hopefully last) repair. I waited a month for a replacement glass. If it continues to leak I will look at trading it in.
I'm going to let them replace the window first and if it leaks again I'm going to try that tube caulk that someone posted on here. I've already contacted the company for a sample box and if I like it I will just slide that into the gap of the spoiler so no water even gets to the glass.
As one who has had a leaky rear window for about a year now, I really do enjoy the benefits of opening the rear slider during these beautiful fall days we're having here in Texas. I'm glad to have the slider, even if it still drips sometimes when it rains. ?
I just took my 2019 in for a rear window leak.  They told me it was the high mount stop light.  They resealed and will check it tomorrow.  (I know i have seen this mentioned before, but didn't want to go through 19 pages of posts as my computer is very slow loading).  Anybody think there is a chance that this is the cause.  Dealer said there was a TSB on it.  Just curious what you guys think.
Very unlikely it’s just the spoiler or brake light leaking, IMO.
If those were common areas of leaks, how come nobody in 169 pages has had those leaks with a solid rear window truck? They all have the spoiler, but somehow only trucks with the slider make it into this thread. Says it all, right?
Not aware of any TSB aside from the one telling them to caulk your window frame.
1000000000000x correct !!!
Every time someone new comes to this thread it seems like the same story. "window leaking, dealer said it's the brake light, nothing to worry about, we'll reseal it, move along"
Does it not seam odd that GM is telling dealers to tell customers it is just the "spoiler" or "3rd brake light" or "window seal" to de-escalate fears or attempt to calm customers AND not admit that the window frames are actually cracking. Even if you look at all the service orders when they do the repair, it says "found window leaking, sealed or replaced window per TSB". They won't put the words "cracked window frame" in the receipt they give you. Why? We have seen these cracks in this thread. They have either found no way to stop it or refuse to look into it. It doesn't take over two years to solve why a plastic item is cracking if you wanted to solve it. If someone can prove this wrong or if GM was willing to be transparent about it, I will happily eat crow. But it has been two years. Everything @OnTheReel said is accurate.
Don't take my words above as me hating on GM. I love my truck sans the leaking issue. Just be honest and transparent, it is not hard. It is what we teach our children.
  • Like 5
Yeah, he's blowing smoke up your tailpipe to be honest. Like the previous people have said a lot better than I can.. it's the window frame and GMC for some reason or another just isn't owning up to it. I'm right now emailing the person I've emailed and talked to on the phone what my service was just like and what is happening and I am sure going to mention this to them as well.
Edited by Dali555
Thanks, Dali555. That's what I thought. I appreciate your opinion. I will see what happens today when they do another water test on it. Frustrating!
When you go back to the truck, be the biggest pain in the ass you can muster up and check every little inch to make sure they didn't mess anything up like scratches in the plastic trim on the inside pillars, happened to me, or scratches in the paint.
Be very diligent!
Edited by Dali555
Thanks, econometrics and onthereel. I hadn't recalled that resealing the spoiler or stoplamp had actually fixed it for anyone.
Be very diligent!
Will do. Thanks for the advice!
169 pages is a lot of reading...I see a lot of theories and guesses about the source of the leak.  If you're confused by your dealership your service department isn't communicating well or they don't know or don't care.  It's simply a poor design of the window frame, you did nothing wrong by driving normally and you can't prevent it by avoiding hot or cold weather or opening your window.  There is a long, thin, flat and hard piece of plastic which is the "setting channel" for the window to body adhesive.  It's too long and is not designed properly for thermal  expansion and it cracks in the weakest spots on the top corners.   It hasn't been fixed.  Case closed.   Can we sticky my photos or my detailed posts about removing the sliding window and installing solid rear glass?
Edited by Leevon
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
