2 minutes ago, Leevon said:
169 pages is a lot of reading...I see a lot of theories and guesses about the source of the leak.  If you're confused by your dealership your service department isn't communicating well or they don't know or don't care.  It's simply a poor design of the window frame.  There is a long, thin, flat and hard piece of plastic which is the "setting channel" for the window to body adhesive.  It's too long and is not designed properly for thermal  expansion and it cracks in the weakest spots on the top corners.   It hasn't been fixed.  Case closed.
Good eyes! Would you mind sharing what salon you go to? Your toes look great btw. ?
I go to your Mom's salon, the one with the free happy endings.  I'm glad you like my toes, you should see the other one without a big toenail!   That is one ugly foot though, I'll give you that.
Edited by Leevon
  • Haha 3
  • Confused 1
8 minutes ago, Leevon said:
169 pages is a lot of reading...I see a lot of theories and guesses about the source of the leak.  If you're confused by your dealership your service department isn't communicating well or they don't know or don't care.  It's simply a poor design of the window frame, you did nothing wrong by driving normally and you can't prevent it by avoiding hot or cold weather or opening your window.  There is a long, thin, flat and hard piece of plastic which is the "setting channel" for the window to body adhesive.  It's too long and is not designed properly for thermal  expansion and it cracks in the weakest spots on the top corners.   It hasn't been fixed.  Case closed.   Can we sticky my photos or my detailed posts about removing the sliding window and installing solid rear glass?
Great info, thanks for the pics!
Too funny.
This is why I didn't rush to get my rear window replaced.  Unless they start using a different plastic for the frame, one that won't crack, a new rear window with a slider will leak again.
I think a good sealant job can fix the problem.  When I removed the spoiler, I saw spots on the top of the frame missing sealant. I added Kent sealant to those areas.
Regardless, the responsible thing is for GM to get the supplier to use a better plastic and do a recall.
The leaks in my 2019 rear slider were definitely from a cracked window frame.  I removed the spoiler and could see 3 cracks across the top immediately.  Then I carefully flowed a small amount of water over each window frame crack and bingo...water was leaking into the interior exactly where it had been during the rain. Kent P10200 sealer was applied per TSB 18-NA-383.  Lasted 6 months and now is leaking all over again on drivers side.
Inquired with Chevrolet dealer parts today about new glass and was told that GM part number 84569182 had recently been superseded to part number 84944319.  It was so new they couldn't find it in the dealer parts database, they had to look it up in the GM database.  Anybody know if the new rear slider glass part number includes any design or material changes to eliminate the frame cracking???  Dealer had no idea...
So the sealant didn't hold up past 6 months for you?  Was there any obvious signs that the sealant itself cracked or shrank?  Did it leak at the same cracks or new ones formed?
  • Sad 1
Yep, sealant only lasted 6 months. And it was cleaned, dried, primed and sealed. I haven’t had the spoiler back off to check for new cracks or sealant shrink yet. Was hoping that GM would get to the bottom of the frame problem and that the new rear slider window part number actually included improvements so a window replacement would fix the leaks once and for all.
Bummer.  I just sealed mine in a few areas the tech missed the first time around.  Let's us know what you find when you get your spoiler off again.
Glad we were able to roll in over to 170 pages.  The cracks in the window frame pictures were quite an eye opener, but do cause me concern.  I picked up the truck tonight.  They sealed the window as well with strip caulk.  We will see if it makes it passed 6 months.  The tech promised me it wasn't leaking.  I talked to the tech and service manager, as there were some minor scratches and scrapes on the interior moldings (thanks for warning me about this).  I did not see any paint damage, but need to clean it up a little better.  They offered to order the trim pieces and replace them.  I had also asked them about turning the afterblower feature on when I dropped it off.  OF course, this never made it to the service ticket.  The service manager had the tech go get the computer and turn it on for me while I waited.  I guess the next time I wash it, I will find out.  Thank you all for the help and the humor!
18 hours ago, Leevon said:
I am wearing those exact flip flops right now. I have four boxes in my closet since I wear size 15 and once I find a shoe I like, I buy a lot of them. Nike Benassi Supersoft FTW!
The cracks make sense. However it is still a major design flaw that there is no weather stripping or anything along the top gap of the spoiler. That gap basically funnels water directly to those cracks. I’m still thinking if the top gap is sealed the leaks would basically be non existent even with the cracks. Of course they would still leak when you blast water in there during a wash but being parked out in the rain or elements wouldn’t be an issue. Just my theory and I could be completely wrong. I have weather stripped that gap and am waiting for the next rain to test my theory.
  • Thanks 1
Which gap did you weather strip? I was thinking of doing the one between the window and the stupid “wing”....
There is some sort of spongy strip along that gap.  It is adhere underneath the spoiler itself and sits in front of the body seam when the spoiler is on.
When I water tested my leak, I notice water would flow over the top of the spoiler and then drip along the slant that slants back towards the rear window.  They end up on top of the rear window itself.  Weather stripping the gap would definitely stop a lot of the water, but it won't stop those drips sliding along the slant especially in a long rain.  Just my observation.
Hard to tell from the picture but that strip doesn’t look waterproof. I could see water getting in from the slant as well. My next move was to try and get some stripping in on top of the window.
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • I agree, there is no one answer fits all as every rig is different, one may be pulling some little aluminum fishing boat while another is towing a monstrosity that weighs a lot and hopefully the owner if the rig has some prior experience to know what drive mode they should choose.    It also struck me and this is from watching a few of those boat ramp escapades videos in the past, Ford being one of the vehicles that has the auto front axle hubs and sure enough its found out that one hub has crapped out and won't engage and may not have manual hubs to even select on both sides so they are on the boat ramp stuck with no four wheel drive and spinning .... they flat out need a tow to get up the ramp and deal with the vehicles new found issues. That can happen to all brands of pickup, finding out either four wheel drive or 4 low isn't working right at the time its needed it to work as some electronic crap has failed.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
