On 9/24/2020 at 3:44 PM, SoCalPlag said:
Anybody not using the dash speakers did you just disconnect them and run components in the door ?
I am pretty certain that anyone that purchased a set of components removed the dash speakers, built an adapter, and replaced it with the tweeter that comes with the components.
Yep. No need to add holes to the door when you can mount the tweeters in the dash and get a good sound. The PAC Audio (a.k.a. Best Kits) speaker mount adapters actually come with the adapter mount to put a tweeter in the dash location. https://catalog.pac-audio.com/catalog/installation-accessories/2014-2020-general-motors
I have the same 6x9 to 6.5" adapters.  I like those tweeter adapters.  I do a lot of sheetmetal work so I built mine out of 0.063" aluminum.
On 2/20/2020 at 10:25 AM, Goobax said:
I would recommend sticking with John (the email address is correct as you typed it), over LLJ Customs. Way better communication. He made a harness for me with the non-Bose but I am actually going to go a different direction then adding a sub only which is what I had him make for me. If you want, I can sell you my harness that I bought that is ready to go for adding an amp to a non-bose system (teal and almond connectors) with 13 ft of leads. I can e-mail you pictures if needed, just DM me
Do you still have your harness
I kept the Bose, personally like the Bose! I did however add a stealthbox under rear seat with 2 12in JL’$ and 750hd amp! Luv the sound! [emoji91]
On 10/25/2020 at 2:41 PM, WACKEM_G said:
I kept the Bose, personally like the Bose! I did however add a stealthbox under rear seat with 2 12in JL’$ and 750hd amp! Luv the sound! emoji91.png
I used to say the same, until I heard Morel speakers and I'll never go back.
Yes, send me a message if you're interested.
As far as I have seen, most component sets recommend against doing this don't they? I opted to install my tweeters in the dooes then I went with 3.5in JL Audios after having the small memphis direct replacements. Sounds way better now.
Edited by Goobax
There are a lot of articles and forum topics on this subject, so I am not getting into that here.  Just check out a professional audio shop.  Look at their installs on youtube, instagram, etc.... 95% install tweeters in the dash and/or a-pillars for perfect balance.
Anything installed will sound better than the stock Bose speakers by far.
Has anyone tried to install the PAC APH-GM02 harness on the New Body style Bose Amp?
I want to try to install amps on my truck and i think that this kit would make a loop harness so that we dont have to cut any cables or harnesses.
It just doesn’t say its for the New Body Style trucks. But they might still be using the same connector for the Bose amp.
Hello,
I would like to upgrade my amplifier so I can sum up my channels and adjust speaker levels.  I have a 2019 GMC Sierra with the Bose system I recently upgraded my speakers to Focal Access series, here's what I have Focal Performance 165AS3 and Focal Performance 690AC. This made an enormous difference in sound quality, I placed the mids and tweeters up in the dash I couldn't hide them but that's ok I took the woofers and put them in the rear doors and the 6x9s in the front doors and when I sum up, I'll add tweeters to the rear doors, and I'm not concerned with adding a sub right now I just want six channel control. I have read must of this thread and it's obvious there's diverse opinion on which is the best way to go. I keep going back to LLJ Customs Car Audio Fabrication loop harness with an AudioControl D-6.1200 this harness connects to the tuner before the Bose amp.  So, I would like to get people's opinion on that setup and more importantly the cons of going with it. Thank you.
Hello,
Email john [email protected] he will build you whatever you need and he is worth supporting.
Ok so I finally got my system mostly done in my '20 Sierra. I went with the Nav-TV unit, a Kenwood 5 ch amp, & the JL Audio stealth box. One problem I have though is that I no longer have door or warning chimes (like for Front Park Assist or Rear Cross Traffic Alert). I still obviously get the visual signals on the driver display and mirrors, but there's no sound like there was prior to installing the Nav-TV unit. I was under the impression that one of the benefits is that it kept the factory chimes as well as balance, fader, & EQ intact. Is there something that was missed in setup? I had a somewhat local shop do the install, but this was their first time using anything from Nav-TV, so I'm wondering if they missed something. Anyone else have this issue?
Strange. So you have no chimes?
All my factory settings and chimes are mirror image to what they were previously.
Check your chime volume in vehicle settings. Mine was turned down to an inaudible volume when I got it back. Not sure if the shop turned it down or it defaulted to that level.
    • Still $3.01 with even more places at this price
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
