Hey all,
I installed the OEM black GMC letters on my AT4 this weekend and thought I would pass this shortcut along.  If you don't mind being a bit destructive and want to take the easy route - just pry the red insert off of the factory emblems and it exposes the retaining clips.  Insert a screw driver and they pop right off.  No grill removal required.  I had one or two tangs that didn't immediately snap back in on the new emblems.  apply a bit of pressure to the grill tab with either your finger or a flat blade screw driver from behind until it clicks.  You are good to go.
  • Like 6
Did you do the tailgate emblem too? Would love to see pics. I just ordered my emblem set for my Denali last week.
I did mine the hard way, which the front grill removal is a B$%#.  Looks sweet though.  The rears are easy with a heat gun and masking tape.  A little harder since all the letters are the same.  Since I have the Dark Sky Metallic and swapped for Black wheels its a good combo.
  • Like 6
TY, I originally wanted the Pacific Blue, then Satin Steele...hard to find around here and when I did they were gone before I could get em.  This one was special ordered with the performance pack and the painted wheel arch to match...the guy that ordered it backed out.  Really glad I got it and so glad I got the performance pack.  The wheels & emblems and overall tones work well together so really happy with what I ended up with.  Just need to level the front a bit and will be all set.
Just put on a ceramic coating before this pick..took 1.5 bottles to do, still need to do the rims.  Really makes it pop.
Edited by quicksilverc5
Gorgeous truck.  I'm getting my rims done the same way.
Love the wheel arches too.  I couldn't do it because I knew mine would get destroyed but I def love the way they look.
Could you be specific and how you remove the front grill
Well there was an earlier post that said all you had to undo was the top bolts to remove it.  I removed the entire font valance, which I would not recommend for most to do.
1.  You have to remove the wheel arch moldings at least half way to reach a bolt towards the top of the front Valance.
2.  There are push clips and body clips everywhere.  The hard ones are where the valance meets the front fender as its really hard to get the trim tool in there
3.  There are to clips that hold the fog lamp air intake to the Frame, 2 clips and 3 U-Body clips for the trim by the headlights, 3 push clips across the front and 4 body clips as well.
4.  You need two people to support the valance until you have the clips off so 1 side wont twist and fall
5  there are 3 bots on the bottom of the grill (that I though or think hold it on as well)
6.  Replace the valance by starting on 1 side, do not do the middle section till the end as the trim that goes up to the headlights takes some fiddling to get right and with the bottom clipped you wont have the clearance to get them all aligned.
The grill lifts up with a bit of a tug.
I plan to never ever take it off again.
Fortunately you can get replacement clips for the Wheel arch moldings from Oreilly or autozone.  (I broke 3 right away)
Thank you for the very specific instructions it is a little more complicated than I was thinking
The grill on my 13 was so easy I removed it all the time to tinker with stuff
Those black wheels do look awesome, especially with that color.  Which wheels are they?
The wheels are the gloss black wheels that normally come on an elevation.  But I have BFG K02s instead.
RD3 Wheels, 20" x 9" (50.8 cm x 22.9 cm) Black gloss painted aluminum
2019 Wheel RPOs attached
2019 Wheel RPOs.pdf
    • I imagine the cold winters up here with repeated short runs in town every day for those that live and work in town and given what I have come to learn on this forum with DI engines having fuel dilution issues, and if they don't change the oil until it says to but keep driving it for a while, I bet all that is just lovely on those finicky lifters.
    • I just did some reading and Stabilitrak is more than a what I had originally thought. It is more of a vehicle control system to help the driver in precarious situations. I thought it was only the AWD system. Now I know. So I changed the title for this thread to AWD conversion to Z71
    • Sounds like converting will be a bigger endeavor than I was thinking. This truck doesn't have 2Hi like the Suburban did. The Tahoe has 4Hi and 4Lo and a button to turn of traction control.   From what I understand the Stabilitrak uses open diff in the front and rear. When wheel speed is not the same the stabilitrak uses the ABS system to slowdown the spinning wheel(s) to transfer power to the slower non-spinning wheel(s). I thought the transfer case was open too. Being able to transfer power either more to front or rear depending on wheel spin. Maybe I miss understood some information with you saying and power transfer is 50-50. Thanks
    • My brother has a 2007 Avalanche with afm 5.3. It`s got 176,000 miles. Runs like a clock. Never been apart. Co worker has a 2010 Tahoe with afm 5.3. 230,000 miles. Never been apart. Runs like a clock. So, even though cyl deac is a weak spot, they can go the distance.   BUT, these engines had the oil changed regularly, AND had 5w30 as spec. I wonder if they would have lasted this far on 0w20? I`ll bet not.
    • I certainly could be wrong but I hear of pickups far newer than that 2007 cutoff which may not be going to the wrecker but are having engine work done and be that a reman engine or new engine or trying to repair the existing engine. Some of it would be design issues as per the cylinder deactivation system that GM has and one of those lifters wiping out the cam and the question of oil changes moving the needle or not on that whole mess, or in the case of Ford pickup engines that have the long timing chains and wearing them out and the roller followers and phasers and some of that certainly goes back to oil change intervals. But in those various cases the truck has all sorts of life left in it and so the unfortunate owner and may be original owner or used market owner that is pouring money into repairs so the truck is not seeing the salvage yard yet but damage is happening by infrequent oil changes. A friends son had bought a 2018 I think it is half ton GM and it had some sort of extended or used dealer warranty on it and of course the lifter issue bites and its rattling and so the dealer had to swallow the bill and was at least 7000.00 and I think they only replaced what they felt they had to replace so yeah, I can see that being a ticking time bomb in the not too distant future. Would frequent oil changes cure all these engineering "marvels", probably not but some engine designs have shown that they do much better if the oil is changed a lot more often then if the manufacturer service claims are followed. New trucks cost so much that there is an incentive to keep the existing truck on the road by repairing.
