On 6/1/2021 at 2:55 PM, Dogdad said:
Any more issues since the floor mat correction?
Ever since I noticed that, have had ZERO no-start issues
Brandon C any further issues since the bulletin fix reprogramming the ECM?
I’ve had my 2021 Sierra Denali for 3 weeks and have 900 miles so far. The non start issue has now happened to me twice so far. Have an appointment Wednesday at the dealer. Hoping it’s as easy as flashing the ecm.
reading the other thread of the camshaft position sensor exciter wheel doesn’t sound like a fun fix having the truck taken apart.
Edited by PandonSF
My 2021 Silverado is having the same issue. This is the third spell. It will turn over and keep turning over. Won’t fire up. When parked for 20 mins or so it usually restarts fine. I have paid a ton of money for this truck and I expect it to start on time, every time. Can someone please post the solution so I can relay that information to my dealership, since they can’t seem to figure it out. Please and thanks.
If you read this thread you’ll see that No one can post the solution because it isn’t clear. Plenty of speculation and potential causes but no smoking gun at this time.
Silverado’s for the last few years have left the factory with packing grease on the motor instead of shipping with oil due to epa regulations, the dealer is responsible for stripping excess grease upon receiving it at the lot. Sometimes the mechanics tasked with getting this grease off the motor are less than thorough. While the engine runs and heats up it makes the grease thin and runny causing it to basically get blown all over the place by the fans and belts and can get on electrical connections causing power to not get to where it needs to go, ie vehicle turning over but not starting right away. Sometimes the engine light will come on temporarily because the vehicle computer knows something wasn’t quite right but won’t give a code because it doesn’t know what’s going on and eventually goes back off after starting it up successfully a few times
This is just stupid.  Nobody packs grease on either the inside or the outside of the motor for shipping.
JCT89
What info made you believe this is true?
Unbelievable.
The problem IMO.
How on earth would they be loaded onto and off of shipping trucks, boats or trains?
Edited by gemarsh
This happened on my 2021 Silverado 3500 gas. It did it the first time at about 1500 miles and I torqued the fuse box pins at that time and thought it was fixed. Happened again a couple of weeks ago at 6500 miles. First time hot sunny day running errands around town. Second time towing a 10,000# trailer in the rain for 200 miles and stopped for fuel. Both times restarted after 15 or 20 minutes. The second time I kept cycling the retained power by opening and closing the door and then locking it. After the 4th or 5th attempt it started like normal with no codes. Took to the dealer today for a scan and found no codes. They installed the ECM software update in the previously listed service bulletin, and also a recall on the infotainment system. Hope this is the fix. I have looked at the gas pedal thing and that is not the issue here as I have the  Z71 mats that are installed correctly and always use my right foot on the brake pedal as everything I own has that requirement. I have had a couple of times when the dash indicated the remote was not found but it started anyways so that may be a sign of where the issue starts?
Recall on infotainment system??
On 5/14/2021 at 9:06 AM, Jmartin2 said:
Anyone experience a permanent fix with this issue? My truck has the 3.0 duramax and I’m wondering if it’s potentially a different issue. Almost seems like the truck isn’t getting fuel while attempting to start. Always stars on the second attempt and never throws a code (which makes it real fun when dealing with technicians).
I have the 3.0.  It has happened to me 7 times within the first 5k miles.  Been to the dealer 3x.  Last time they claimed to have re-torqued the fuse box bolts.  Other than that they say they can't replicate and usually mention that they "checked all the software".  First new truck i've bought in a long time so its very disappointing performance from a $60k truck.
To recap what my truck is doing
First two times, i was using key fob, and the start would spin but not fire.
3rd time - starter spun but would not fire, then it would not crank after at all for multiple attempts.  I had it towed to dealer but it actually did crank as he was putting it on the tow truck.
Times 4 - 7, push the crank button on dash, starter runs for ~10 seconds but no fire, and I can't get it to stop.  Then it has crunk on 2nd attempt every time.
This is being discussed in detail in the 2020 HD forum on this site. There is currently no fix for this problem, even after having the entire truck torn apart for the camshaft bulletin.
    • Thanks for that, yes just because I could I measured what came out just to give me some guidance although I already knew to expect it to take at least 9.5 to just throwing in the whole 10 quarts off the shot and doing a one and done heat cycle to drop out the excess to get to the proper level. I don't recall exactly now what I measured that came out but was less than I put back in, I knew I spilled some on the garage floor but the main part was that I was thrilled in the discovery I did not have to touch my exhaust to flex it down. The gasket manipulating is a pain of course to create that clearance to take the pan out and put back in but its all very doable if one is careful and not forcing the gasket to flex too much. From the quote I got at a transmission shop of 900.00 here in Canada ( never asked at the dealer what they charge ) I saved 700.00 doing it myself after paying for the supplies so that to me paid very good wages !, and I knew what fluid was put in and that I had changed the filter and that the level is correct without any doubts.
    • I do have one of the AFM diasable box, using it for last 1.5 years.
    • I found a setup that lets me open the cover partway with racks installed, using side-rail-mounted systems for easy access.
    • Typically its said and I agree so far that the engine oil drain plug oring is not required to be changed out unless you see some damage happening to the oring as apparently the oring lasts well. The dealer I have been getting a few parts from never even stocked the oring but instead stocked the whole drain plug that comes with a new oring which for the dealer is easier because they just throw in a new drain plug if there was any question about damage on it as well and charge the customer accordingly but again only if it is needed.    Also a hint about the drain plug oring to help it last vs a risk of causing damage to it, after its been removed and wiped off or washed off ( that is a whole other topic about some solvents damaging orings because some solvent types do ) to make sure to relube the oring with a bit of new oil so that it won't "grip" on the sealing surface of the pan and needlessly stress out the oring. Its no different than putting some oil on the sealing ring of the engine oil filter. So I just grabbed a new drain plug to have on hand although more recently bought just the oring as well but as its special it costs half the price of the drain plug ... !   Since you mentioned the hate to be empty handed theme, I am not sure what you have in the way of filter removal tools as I like using the exact sized for the filter steel 1" wide band with side to side swivel handle filter removal tool, and it can be used to snug up the filter without risk of damaging a filter as well ( its probably a lisle brand I have ). The drain plug hex size is 15mm and I always like using a 6 point socket if I have a choice and with this truck I've been using just a 3/8 ratchet that has a fairly long handle. Do you have a funnel that will work to pour oil in as that is definitely the short coming bastard part about the design with that fill port on the valve cover on such an angle that no normal funnel will even work. There are adapters and things on the market that will set into or screw into that fill port, I didn't want to deal with US shipping as that is all I was seeing at the time so caved and bought a Lisle brand multi vehicle fit adapter funnel kit and it really works well but there are much less expensive adapters out there that work in conjunction with an off the shelf funnel that would do the job also. Now that I have it, I like how it works and works so slick with the shape of the Amsoil 1 quart containers I have now switched over to. Whatever you do, have a funnel system of some sort as you will be swearing if you dropped the oil and then realize you have nothing to properly pour new oil in without spilling it all over the engine !.     Other comments, quite a bit of oil flows out down the filter when its cracked loose due to the housing above the filter so let it dribble down the filter until it slacks off flow and then remove the filter to create less possible mess. It seems these engines can sit for quite a while and drip and if you have time let it sit there and drip out of the engine as much as it wants. Also a good time to grease the 9 zerks on the front end, that's my typical practice anyway to grease the suspension and steering each time I change the oil. And remember to reset the oil change minder ( not something I am used to doing with older vehicles and equipment ).
    • I really did not measure what came out. I carefully followed directions to check level after i did the spill and fill and filter change. I used 10 quarts. 9 was not quite enough. My trans temp was about 175 when I checked it. Truck sitting in my driveway very close to level where I always check oil pretty much every time for consistency. My driveway is just ever so slightly downhill to run water to the street.
