I bought a gallon of Dexron VI from amazon because of price. Was going to do my transfer case and noticed the gallon pump I have is too small for it. The jig has a huge lid! Anyone know a pump that works on these?
$10 -$20 Walmart, depending where you buy it at, it’s called a “fluid transfer pump”, use it with any size container.
Sent from Above
I got this pump for doing diffs & transfer case:
https://www.princessauto.com/en/detail/1-litre-bottle-pump/A-p8629826e
Works ok, just needs a lot of pumps to get the job done when doing a complete fill.
If you do get something like the pump in the previous post, be careful that the hose going into the transfer case is significantly smaller than the fill hole in the TC.  Awhile ago (before I bought the pump at the top of this post), I used another hand pump similar to the on in the previous post, and the hose was just a little smaller than the fill hole (but it went in/out easily enough, didn't seem to be a problem), but it was close enough in size that the fluid couldn't readily come out (a little would come out all the time because the hose was horizontal, so some would run back down the hose as I pumped fluid in).  Pumped in a bunch, more than it should need, with the same small dribble of fluid out all the time, finally pull the hose out and fluid just starts pouring out.  And those hoses tend to be really stiff, so it's easy to either tip the oil bottle over or for the hose to come out of the fill hole...
Thanks guys, maybe I’ll get a couple quart ones to do the transfer case and keep the gallon for trans fill.
hopefully the pumps screw into AC Delco quarts... lol
As stated above the fluid transfer pump  shown works well.
I got my dexron VI in qts so my pump fit my containers but now that AMSOIL came out with the squeeze packs that is the bee's knee's.  No mess for sure.
My experience with the little hand pump(the yellow one posted), works great until you start working with warm or hot fluids. The tube collapse on its self with warm fluid, any other time it works like a champ.
I’ve personally never used it with warm or hot fluids, no need to for the transfer case, instead I first unscrew the drain plug, drain my transfer case, allowing it to fully drain while it’s still warm and then I use it to pump in the new fluids directly from the Amsoil transmission fluid bottles. I wouldn’t use any plastic type pump with pressure clamp on connections on any fluid close to being hot, that’s a disaster in the making.
Sent from Above
IMHO, for the sole purpose of maintenance, the squeeze bottles Amsoil has for the diffs are extremely easy to use which means everyone would maintain their diffs more frequently, that’s proactive.
Sent from Above
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
    • Anyone install a a supercharger on your 6.6L L8T? Talk to me...
