3 hours ago, emfollin said:
I got my truck back tonight after torque converter change. I only have a few miles on it but it feels the same. Tech wrote on RO that prior to TC change there was too mush slippage on TC lockup and that shudder is gone and some hesitation is normal due to DFM and 10 speed tranny normal operation.
Give us an update after you have driven it for a while. It doesn't sound like they fixed your problem.
Truck is back at the shop now. Initial test
drive by technician reports normal operation. There is definitely a hesitation at low throttle. I have a feeling I’m going to be sent home disappointed again.
  • Sad 1
I am having the same issue.  2022 AT4 with 45k miles.  It feels like the transmission disengages at about 40 mph.  I have to take my foot off of the gas and feather the pedal until it re-engages, but then it doesn't shift automatically [50 mph at about 4k rpms].  This happens about once a week.  I love the truck, but a 2 year old vehicle shouldn't have this problem.
We regret to hear of these challenges you are facing with your vehicle and would like to take the time to learn more. To do so, please send us an email to [email protected]. Be sure to include your Username and Forum name in the subject line with additional details. We look forward to hearing from you.
my 22 started doing this the last 1k miles or so, 39k on it now along hard down shifts from 2-1 sitting in traffic...
  • 4 months later...
I have a 2020 AT4 with a 6.2L. I have had all my scheduled services done at Beck and Masten GMC in Houston, TX. My truck has 74k miles on it. And it has been making a strange noise from under the truck. Took it to Mac Haik Chevrolet as Beck and Masten service went down hill. Was told my transmission pump was failing. And also told my transmission has NEVER had the fluid changed which was due on my scheduled service at 45k miles. Even though I have been getting my services done at GMC!!! So I'm being quoted $7,640 to replace the transmission!!!! I can not believe a fairly new truck that has been serviced and taken care of now needs a new transmission because the GMC dealership I trusted it too never did the work that was recommended by the manufacturer!!! This truck will be going to my son next year and I will not be buying another GM vehicle if I can not get this resolved. Nothing makes me more pissed than to be put in a position where I have zero recourse even though I did my part. PATHETIC!!!!
Edited by William L. Sheppard
I am having this issue on my 22 GMC 1500 started around 34,000 miles got into dealership they replaced torque converter said it was good. Drove it home from dealership on a Friday and took it back on Monday with same issues. They sent back after another week and said they reset the computer and it needed about 500 miles to calibrate.  About 1000 miles later issue is back and took to another GMC Dealership to see if I could get a second opinion. They are telling me that it is fine and that I should only drive with it in the 2WD mode only. I previously had a 2017 GMC 1500 and I always drove with it in the AUTO mode and never had an issue. The dealership is telling that I should not drive with it in AUTO mode on the highway?  How did the technology get worse in these trucks from a 2017 to a 2022?  Anyone else have opinion on driving in AUTO mode?
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • I bought belts and pulleys for my '20 L5P at Rock Auto a couple years ago. I have used them for many years, and almost always save significant money, especially when I buy maintenance stuff ahead of time.   They carry many OEM parts, which is all I use unless an aftermarket is shown to be same/superior, or if it is an insignificant part or unavailable OEM part anywhere else. RA is usually lower priced, often by a bunch, but parts are sometimes unavailable or out of stock, and I do shop around and sometimes find better prices at other sites.   Be aware that you pay shipping, and if you buy multiple items and they are coming from different warehouses, the shipping can kill the advantage. Planning ahead is best if possible.   If you have a transmission service in the near future, check out their OEM (AC Delco ULV) fluid, usually MUCH less than anywhere else.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
