Please let me know what you figure out. It’s so weird how it drives perfectly fine but idles like crap. I’m gonna check my  battery wires such as the ground and stuff today for damage.
so far I’ve replaced the injectors, swapped coils, clean throttle body, ran seafoam through it many times, clean MAS, replaced spark plugs and wires. We even smoked it and can’t find any leaks. It makes me more mad that it’s on one cylinder that performs perfect fine and has great compression.
On 10/8/2022 at 3:23 PM, The Pig Dusters said:
Ohh okay gotcha. Yeah as soon as I start driving, the flashing light will stop, and it will
drive smooth as silk. But when I’m parked or idling at a light or drive thru, it misses so bad and shakes.
This symptom set sounds exactly like the state trooper 2018 Tahoe 5.3 we had in last year.  Cam was toast on cyl. 8.  Had good plug, wire, compression and leakdown test.  Idled like crap and when you picked up the RPM everything was great.
I think its time to pull the head and lifters on #8 to check that camshaft...
Edited by newdude
  • Thanks 1
Hmm. Wouldn’t I be having more issues than just one cylinder if the camshaft lobes were bad? I’m not a mechanic I’m just trying to understand lol. I also had a guy tell me to order the AFM delete issue as it could be something going on with that AFM lifters. He said he plugged that in and it fixed his rough idle and misfiring issue. I thought I’d try that first before anything else. I don’t wanna put crazy money in it if I don’t have to.
1, 4, 6 and 7 are the AFM cylinders.  You are missing on 8 so a Range AFM won't help and still wouldn't help if the cam was trash on one of those 4 cylinders.  Could it allow an AFM lifter to somehow magically re-lock properly?  I suppose, but unlikely.
With RPM the cam is spinning faster so the roller on the lifter is able to overcome the bad surface but when its idling its not letting it open the valves all the way.
Edited by newdude
With RPM the cam is spinning faster so the roller on the lifter is able to overcome the bad surface but when its idling it’s not letting it open the valves all the way.
Ohh I see. Okay well tomorrow or Wednesday my buddy and I are gonna check one last thing. We did have the valve cover off to check the springs but we never did check to see if I could be dealing with a collapsed lifter on the cylinder 8. We never really ruled out a bent pushrod or something but if that is the case, I expect the camshaft to of taken some damage as well. I’ll update once we check.
Yes. So my truck was only missing at idle. We tried new plugs, wires, injectors, and we made sure of all the small things. No intake leaks or anything at all. I took it to a dealership and they told me it was a lifter. They wanted 5K FROM ME which I’d be okay with but the guy couldn’t explain how the lifter was only messing up at idle. So I said no and I bought a Range AFM disabler. It fixed my issue. I’m not sure how it fixed it but it did. No more misfire and no more flashing cel or stabiltrak.
The AFM disabler turns off the function of the VLOM that control the AFM cylinders, but kinda doesn't make much sense because it doesn't work on cylinder 8.
Edited by CamGTP
Exactly so I’m as confused as you are.
I'd run and get a lotto ticket LOL.  Talk about luck.
What is crazy is you were showing the miss on 8?  And 8 (passenger rear most cylinder) is a non active cylinder so installing the Range wouldn't fix a miss on 8.  That would mean 1, 4, 6 or 7 were the problem, 7 (driver's rear most cylinder) being the most likely one it seems.
I'd still keep in mind that there's still an "if" scenario where if an AFM lifter has already stuck once and seems to have re-set, that it re-sticking can't 100% be ruled out.
Edited by newdude
    • I agree with Tim.  As tech heavy as engines are these days, no way I’d be an early buyer of the new 6.6.  Of course, I bought my ‘26 Denali w/the 6.2 after dumping my Tundra with it’s defective 3.5 liter imploding engine disaster, so I’m a little gun-shy.  That said, my 6.2 has been rock solid.  I don’t drive it like I do my BMW Z4 M40i, but I don’t baby it either.  I got a V8 for a reason.  But I’m averaging 18 around town and 22 highway.  I have seen 24 highway as well when I wasn’t loaded up heavy.  Considering my Tundra with the twin turbo V6 only got 14.5 in town and 17 on the road, I’ll take the 6.2 all day, every day.  If I were you, I’d grab a ‘26 while you can.  Inventories are probably gonna start dropping and I’ll bet the deals will start looking sweeter as well.
    • I am curious if anyone has figured out a way to add an hard button AUX or 360 Camera switch to the center row of switches. I have a 2021 AT4, and want to split the hill decent button and add a 360 camera button so that you don't have to go into the center display and locate the camera functionality, etc...   My father's 2024 Yukon XL AT4 and it has a hard button, see below. I found this thread on the Yukons, but it seems like there may not be a part number for the 2021 sierras. https://www.gm-trucks.com/forums/topic/255339-adding-hard-button-for-camera-on-2021/ Anyone else figured this out. Seems like it would need to be a custom switch!   I am getting ready to install the auto stop/start eliminator, so would be nice to knock them out at once.     Upvote1Downvote0Go to comments
    • Looks like the entire state is burning. 😬
    • Through the years it hasn't been my typical method as I tried to drop oil on an engine that was hot from having been worked, however that was not always practical and had to fire up a unit and let it warm up reasonably well and drop the oil when I had the time to do it but am referring to not only vehicles but a variety of farm equipment and highway tractors etc. However on a vehicle where one is crawling under it and the exhaust is nearby to ones body and if wanting to pull the plug without danger of being hit with boiling hot oil or attempting to remove a HOT oil filter, its sure safer and easier to not have everything smoking hot and can remove the filter right away when under the vehicle and let it all drain. Of course its not the end of the world if a bit of oil stays in the engine that might have eventually found its way out, I like to get out as much as possible but any oil changes that take place in shops would rarely be sitting around for very long at all before the plug is thrown back in and filter slapped on and oil poured in and sent out the door quick like. There would be very little time spent ( assuming they even did it ) in starting the engine with oil to fill the filter, then waiting to verify the level on the stick. A good reason to check ones oil level shortly after a shop changed the oil on a vehicle just to make sure its correct and to look under for any oil around the drain plug or filter.
    • Cool to see another Vermonter!
