Thats great news! Free factory HID kits for everybody!! haha...only in a perfect world.
But in a perfect world we wouldn't have these problems in the first place [emoji6]
Touche sir...touche
Hey sir did you ever get your HID lights put on?
Blasting up I37 and I35 to Austin for F1 races they made a -ell of a difference.
Well worth the money spent
I installed them last week with no issues. Did not post pics because there are many before/after pics out there already. They are much righter than stock and make a big difference. Very happy with the kit. I did mount the relay harness on the driver's side where there was more room on the firewall and open incase there is ever a need to troubleshoot. Did not want it hiding behind the intake. Just had to extend the power cable to the battery a little.
Bass mechanic,
Did you use the hub centric ring on the fxr projector? I was attempting the retrofit today and the projector was not sitting very well
So being lazy and not going through all 55 pages, has anybody actually done a retrofit on these new headlights or is this really an HID thread?
Did you read the first page? There's retrofits there for the Silverado. Also Bass Mechanic did a retrofit for his Sierra. Not sure which page.
Yeah, guess I should re-phrase...I meant like a custom retrofit, not just un-bolting and bolting in a new projector. More like taking stock non-projector lights and actually retrofitting projectors and custom painting houses etc.
Oh. Nope, most ppl In that boat seem to just get the Anzo headlights and are happy with that.
Gotcha...been floating around the idea of a custom retrofit and was looking for a few ideas...have found a few on google searches but just thought I'd try this thread too.
Thanks for saving me reading 55 pages lol :thumbs:
Bass mechanic,
No I was careful in how I placed my holes and how far I tightened each screw so that the projector was in the center. It may be possible to make some small brackets or mounting tabs that would allow some adjustment if you felt you needed it
So I just finished my projector retrofit on my 14' Sierra. FXR 3.0, 55W 5000K Morimoto setup from TRS. I used the "rear entry" method that was pioneered by Bass Mechanic, I think. It went pretty well. Taking apart the front end of my truck kinda sucked. The first light took about 4 hours and was pretty stressful , the second took about 1.5hrs. Very happy with the results. The harness that they sold me had the stock input inverted( black to red, red to black). I got a loud relay buzz on my test before install. I swapped the stock input plug( red to red, black to black) and that fixed it. Thanks to all the people on here for the info to do this on my own (First DIY retrofit).attachicon.gifIMG_1907-1.JPG
Good work man. So you put these in from the rear eh? How exactly did you go about securing the FXR to the mounting bracket? Did you get it to sit flush with the front of that bracket or is there a gap on the front side of the projectors? Looks nice and level. Bring that driver side up till the top of the cut off lines up with the other side. You don't want to see two steps;)
10-22 diode is if you want the fogs on with the running lights. Like the picture says they can't be turned off.
10-18 diode will give you fogs on when the high beams are activated but will also give you the option to turn them on and off with the OEM fog switch.
What diode did y'all use for this? 12V - 1W?
Just got my DDM 5000K kit in, will post an update after. Also ordered the adapter above for my fog lights as well. Haven't gotten down there yet but I would assume I'm going to have the same issue.
I just blew up one of my error cancelers doing a test run. How do i know if i have it plugged in properly I kinda don't want to mess this up again cause my kit took 15 days to come in
which kit is it? 55W or 35W? The 55W kit draws too much power for the error cancelors and will blow them everytime. Happened to me twice. Then I gave up on the error cancelers and everything has been working fine without them. Have had them in since the beginning of May
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
