I have a 2014 Silverado LTZ with 20" Continental tires that I picked up in the middle of November 2014. After a day or so I noticed the vibration after 65 MPH and thought the tires needed re-balancing, I figured I'd mention it at first oil change. mine wasn't as bad as the one's I've seen on the you tube video's but there was a distinct vibration. I now have about 3,700 miles on the truck, and the vibration is just about gone... It seems the more i drove the truck in 4WD or auto 4W the better it got. (We got a lot of snow here in New England.) I just got back from a 200 mile road trip and my passengers were saying .. wow!! this truck rides so smooth. At first I was real disappointed with this truck and thought I was going to have to fight with the dealer to correct it. Now I don't think I'm even going to mention it... My truck runs perfect and I'm happy with it.. Just throwing this out there..
I am pleased to report that my vibration is fixed, at least for now. Last Wednesday morning I dropped off the truck for it's second evaluation. My dealership had purchased a "Pico" meter (not sure of the correct spelling) that helps them locate the source of a vibration. They pinpointed the driveshaft as the main source so they replaced it. Apparently it was a lot better but they still were not fully satisfied so they also ended up replacing two tires while they had it there. I returned last night from a 1700 mile trip (SC to Miami and back) and it was an absolute pleasure driving this truck. Of course I was expecting it to start vibrating again halfway there but it did not. There was not a hint of vibration at any speed and I even managed to knock down 19.1 mpg with the cruise set at 80 mph all the way there and back. Hopefully it does not reappear in the future but for now at least, I love this truck again. Now I finally feel confident enough to start accessorising it. I have the Bakflip F1 and BedSlide coming tomorrow, and the 3/5 drop, Borla Touring and 22s are next.
For those of you dealing with this I would ask your dealer about this Pico meter. Again, not sure I have the spelling or name correct but it was a device that GM Engineering reccomended the dealer use for analyzing. They said they had another truck that was vibration in the 35 - 40 range and the meter pinpointed driveshaft vibration on that one as well. I guess they now have two happy customers, and I'm glad to be one of them. I sooooo did not want to have to drive a Ford or Dodge!
Add me to the list of "vibrators". 2015 Sierra SLT with 1000 miles. Dealer has had truck for going on 5 weeks ! Just one of many complaints. Garbage 50k+ truck.
Just saw that there is a bulletin "Vibration Analysis Worksheet" 03-00-91-001G for 2015 trucks and earlier. I don't know what this is about because I have not see this 'worksheet', but the title seems to apply to the vibration issue. Dealers will normally show these document to you if you ask. If you read the 'worksheet' and find some useful info - post what you find.
Did they give you a "loaner" to drive?
Edited by pm26
Most likely it was a Pico Scope, like this one:
http://www.testandmeasurementtips.com/oscilloscopes/picoscope-4424-ideal-for-noise-vibration-mechanical-analysis
You may want to post your question over on the SUV threads. Your issue may be the same as the this one:
http://www.gm-trucks.com/forums/topic/162779-2015-yukon-noise-in-cabin/
Just curious - why would they have had to replace the headliner to fix a water leak on the side window? Seems odd.
The water leak was in the back right stationary window. There's an antenna in the window, and it was causing the leak, they tell me. The leak left a water stain in the headliner, so they replaced the whole thing. One of the panels popped off a couple weeks later, and I took it in to get them to pop it back in place.
Glad they got it figured out for you. What was your vibration like? Highway speeds only? Seat of the pants, steering wheel, floorboard. etc...?
The Picometer is the vibration reading device the GM TSB specifically calls out to use in order to give the dealer an idea of what is actually vibrating. The TSB lists where to attach the device in one of two places, and also goes as far as to list the frequencies for vibration and what can cause each of them. If a dealership doesn't have the device, then they are not following the TSB to fix the issue, and likely just wasting time throwing parts at the truck hoping it fixes it.
I know of one dealership in central Texas that has one, yet hasn't trained anyone to use it to follow the TSB. And they have two trucks they can't figure out what's causing the vibrations...
Hi Newm. My vibration only occurred between 73 - 82 mph. It didn't matter how I drove it or what the road surface or road conditions were. It was very noticable in the steering wheel and seat bottom. If you had a drink in the cup holder you could see the rapid vibration in the bottle, to the point it "rattled" and annoyed you. It feels like a whole new truck now - just like it should have when I bought it new a few weeks ago. Go figure...
Did they give you a "loaner" to drive?[/quote
Yes, gave me a watered down Buick that I can barley get out of my 800' country driveway. Absoutely livid. GM owes me some serious compensation. Dealer has had it longer then I have. If there's so much as a scuff or scratch on it if I ever see it again, I don't want it back. Will go straight to BBB and my wife is a attorney, has connections ... I'll esclate the situation to the moon.
"Auction" on their own used car lot, with "certified used" slapped on the window, waiting for the next sucker to come in and pay premium price for it. And the cycle continues.
Exactly what they did with my bought back truck...
I've read over a lot of the posts from this page, and it seems what I have going on is slightly different.
My truck rides fine at high speeds, no shacks or rattles. It's low speed, mostly low or light throttle that I get a almost "torque converter" feel like it's slipping slightly in and out. my passenger can't feel it, but I feel it in the pedal and in the driveline.
Is this common or considered "acceptable" ? I don't know if it's maybe my truck needs to be broken in (350 miles on it ) or what.
Any advice would be great.
2015 Sierra SLE with 20" wheels
Looks like I'll be bringing this bulletin and tool to front and center and my local dealer. Still vibrating.
Sent from my iPhone
Sent from my iPhone
If the dealer doesn't know about this tool, the equipment part number is 733-CH-51450, known as "Pico Oscilloscope Diagnostic Kit with NVH".
Edited by CounterMeasure
    • Hello hello looking forward to expanding my knowledge of the 2026 2500 HD that I just bought.   Truck has 3500 miles on it four-wheel-drive crew cab and I’m about to put a 6 1/2 inch BDS lift on it 18 x 10 -25 offset with 37’s   Already have the wheels and tires just waiting on the lift install in about three weeks   Question what surprises am I not gonna be happy with?  I’m not new to lifted trucks so I know that acceleration towing gas mileage all that is affected..   Question is those of you that have this truck this powertrain with a 10 speed Allison and have done the mods that I’m doing,,, how bad is it? Is that Allison constantly gonna be hunting for the right gear to go into? And what about towing, acceleration, fuel consumption as mentioned?    Lastly how come I can’t find any ring pinion gear set up for these axles and when could I expect to see them?   I apologize if there’s any typos I’m doing speech to text on my iPhone.
    • I've got a 2013 2500 6.0L Flexfuel. Drove the truck earlier today with no issues. Went to run an errand tonight and noticed key fob wouldn't work. Figured battery was dead, so replaced fob batter. Still wasn't working. Grabbed my other set of keys with the other fob and that one wasn't working either. So I manually unlock truck and insert key. Interior lights come on, dashboard lights up, turn key and truck starts. Turn truck off, like a moron, and try starting again. This time no crank, no click, no nothing. Lights still come on and dash lights up, but now I'm getting a service 4wheel drive, service tire monitor, etc. Check voltage on battery and Im showing 12.2v. Throw my battery charger on it and give it 15 mins and try starting again. But still no crank no start. Decide maybe its a bad battery, run to autozone grab a new one and put it in. Same issue. Disconnect battery and let it sit for 15 mins. Try again and still nothing. I had managed to roll the windows down earlier as its a humid night, but now I can't get them to roll up. Power locks are also not working now. Then randomly I try the key again, and it fires right up. Immediately I roll up the windows as we have nothing but rain forecast this week. I shut it back off wait 30 seconds and start up again. Worked a 2nd time. So turn it off, start putting things back together. Try one more time, and back to no crank no start. And now the car alarm starts going off. Had to disconnect battery and leave it that way for the night as I don't think my neighbors would appreciate my alarm going off again tonight. Any thoughts or help would be appreciated.
    • No one will care for you like you care for you. Do what you can for as long as you can. IMHO of course.
    • How about them NICKS!!!
    • Hi there.  Long time lurker, first post.    i have read the previous posts regarding the water ingress problem with this emblem.  I bought my 1500 SLT the  summer of 2025 new and after reading the MANY problems with these emblems failing I decided to install one anyways.  As per a YouTube video, I sealed ( or tried to) this sign with silicone sealant around the outer perimeter joint and the holes that were already somewhat sealed on the rear plate of the emblem.  And installed the connector assembly using dielectric grease on the connectors. The installation looked great and worked well for about 4 months……then FAILURE.  Grrrrrr…… I live in the great white north and wash my truck weekly in an automatic car wash  to keep the salt off.  Let me tell you that removing the old, failed emblem is a whole different animal than removing the OEM individual letters without removing the grill assembly. Mainly because the illuminated logo is built differently than the original letters which  you can remove the red surface lettering with a knife or some kind of blade which gives access to the tabs which hold the logo onto the grill. So I had to essentially destroyed the old emblem to remove it. Doing so killed my chance of doing somekind of autopsy on the failed , old logo.  But there was plenty of water inside when I ripped it apart.  Prior to installing the new assembly I tried it with the old harness and it works fine.   Does anyone have any insight as to where the water is getting into this emblem? I intend to seal the new logo with slow curing epoxy this time around using a syringe.  I think this newer emblem may be an updated unit which I hope GM got the vendor to fix. It has an October 2025 date on it.    If this one  fails,  I am just going to revert back to the non-illuminated letters….AFTER PULLING THE GRILL.    Any thoughts on sealing with epoxy would be appreciated. Thx!   Doug
